Understanding the Installation
Understanding Management and Power Cabling
Single-Switch Location Guidelines
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Enable or Disable the Incremental Save Flag
Enable or Disable the Auto Save Flag
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Check Switch Status (Oracle ILOM)
If you leave a session idle for too long, the session might get disconnected and return you to the Oracle ILOM prompt. This procedure clears the timeout for line connections so that idle sessions are not disconnected.
See Connect to SEFOS.
SEFOS-1# configure terminal
SEFOS-1(config)# line vty SEFOS-1(config-line)# no exec-timeout SEFOS-1(config-line)# exit
