Hardware Installation Overview
Hardware Installation Task Overview
Hardware Installation Documents
Preparing the Site (Storage Rack and Expansion Racks)
Prepare the Site for the Racks
Heat Dissipation Specifications
Network Infrastructure Requirements
Compute Server Default Host Names and IP Addresses
Compute Server Network Components
Storage Rack Network Components
Cable the ZFS Storage Appliance
ZFS Appliance Power Cord Connection Reference
ZFS Storage Appliance Cabling Reference
Leaf Switch 1 Cabling Reference
Leaf Switch 2 Cabling Reference
IB Switch-to-Switch Cabling Reference
Cable the Ethernet Management Switch
Ethernet Management Switch Cabling Reference
Connect SuperCluster M6-32 to the Facility Networks
Expansion Rack Default IP Addresses
Understanding Internal Cabling (Expansion Rack)
Administrative Gigabit Ethernet Port Cabling
In order to cool SuperCluster M6-32 properly, ensure that adequate airflow travels through the cabinets.
![]() | Caution - Do not restrict the movement of cool air from the air conditioner to the cabinet, or the movement of hot air out of the rear of the cabinet. |
Observe these requirements:
Allow a minimum clearance of 36 inches (914 mm) at the front of the rack, and 36 inches (914 mm) at the rear of the rack for ventilation. There is no airflow requirement for the left and right sides, or the top of the rack.
If the rack is not completely filled with components, cover the empty sections with filler panels.
Figure 1 Direction of Airflow Is Front to Back
Table 11 Airflow (Quantities Are Approximate)
