Operating System and Technology Requirements
The HBA requires the operating system (OS) and technology levels, at minimum, listed in the
following table.
Note -
If you need to contact Oracle Support, first verify that you have a supported OS
installed on the host system, and install the latest HBA driver, utility, and
firmware versions. Updating the system and HBA to the latest OS, driver, utility,
and firmware versions might address the issue, preventing the need to contact Oracle
Support about an issue that has already been fixed.
Table 1 Supported Operating System/Technology Versions
Oracle Solaris OS for the x86 (64-bit) platform
Note -
The MegaRAID Storage Manager (MSM) software is not supported
with the Oracle Solaris OS.
Oracle Linux 7.2 with Unbreakable Enterprise Kernel (UEK)
4
Oracle Linux 6.5 with Unbreakable Enterprise Kernel (UEK)
Release 3 (R3)
Red Hat Enterprise Linux (RHEL) 6.8
SUSE Linux Enterprise Server (SLES) 11 SP3
Virtual Machine Technology |
Microsoft Windows OS (64-bit) |
VMware Technology |
