If you needed to turn the system power off to install the HBA, power on
the system.
Note -
If you do need to return power to the system, ensure that the power is
turned on to the SAS devices, SATA II devices, or both before or at the
same time that the power is turned on to the host system. If the system
is powered up before these devices, the devices might not be
recognized.
