This section provides host platform, storage, and software support information. This section contains the following topics:
The HBA is supported by the platforms listed in Figure 2, Table 2, Host Platform Support. For the latest information, refer to the product notes for your system.
For supported operating system and technology versions, see Figure 1, Table 1, Supported Operating System/Technology Versions .
Internal disk drives are the only storage supported by the HBA.
Install, Flash, and BIOS configuration utilities are provided. The HBA uses the MegaRAID Firmware Interface (MFI) architecture for all major operating systems, which allows for thinner drivers for better performance. To obtain a device driver that supports your operating system, go to: https://www.broadcom.com/support/oem/oracle/
Use the MegaRAID SAS Software to manage the HBA upon installation. For more information, see the 12 Gb/s MegaRAID SAS Software User's Guide at: https://www.broadcom.com/support/oem/oracle/
