Go to main content
To Install the Linux Driver
Log in to the host.
In a browser, go to https://www.broadcom.com/support/oem/oracle/.
Select the type and then model of the HBA that you want to use (7110116,
7110117).
Select and download the Linux driver that is supported by the Linux
release (Oracle Linux, Red Hat Enterprise Linux, or SuSE Linux Enterprise
Server) on your hardware platform.
Select and download the corresponding Readme file for the Linux driver,
and follow the instructions in the Readme file to complete the driver
installation.
