Exit Print View
This appendix contains the specifications for the HBA.
This appendix contains the following topics:
Physical Dimensions
Environmental Specifications
Fault Tolerance
Electrical Characteristics
The HBA card size is as follows:
Height: 94.31mm (2.731 inches)
Length: 167.64mm (6.6 inches)
