Go to main content
Oracle® Storage 12 Gb/s SAS PCIe RAID HBA, Internal Installation Guide For HBA Models 7110116 and 7110117
Exit Print View
Updated: April 2020
Next Steps
If you are installing the HBA in a SPARC system, install the Oracle Solaris OS, as described in Installing the Oracle Solaris OS.
If you are installing the HBA in an x86 system, install a supported OS (for a list of supported operating systems, see Operating System and Technology Requirements). If you plan to install the Oracle Solaris OS on a system, follow the instructions in Installing the Oracle Solaris OS.
