If a removable memory option is present, ensure that the module is seated
firmly in the dual-inline memory module (DIMM) socket.
Note -
This HBA has on-board, 72-bit direct DDR-3 memory.
Refer to the installation guide or service manual for your particular
system for instructions on how to locate an available PCIe slot in the
system.
Align the PCIe bus connector of the HBA to the PCIe slot.
Note -
Some PCIe slots support PCIe graphics cards only; if the HBA is
installed in one of those PCIe slots, the HBA will not function.
Press down gently and firmly to seat the HBA in the PCIe slot, and then
secure the bracket to the system chassis with the retention clip (see the
following figure).
Callout
Description
1
Retention clip
2
Press down here, on the edge by the internal
ports.
3
PCIe slot
4
Motherboard
Note -
The configuration of the enclosure might not be the same as shown in
this illustration.
