Go to main content
SPARC T7-1 Server Installation Guide
Exit Print View
Updated: March 2019
Airflow Precautions
Caution
Caution  - Proper airflow is essential for keeping the server's internal temperatures within a safe operating range.
Air flows from the front to the rear of the server.
image:A figure showing the direction of airflow through the server.
Follow these guidelines to ensure unrestricted airflow in the server:
  • Adhere to the minimum airflow clearance specifications. See Physical Specifications.
  • Install the server so the front faces the cool aisle and the rear faces the warm aisle.
  • Do not direct warm air into the server.
  • Prevent recirculation of air within a rack or cabinet.
  • When servicing server internal components, ensure that air ducts, baffles, and filler panels are properly installed.
  • Route cables so they do not interfere with airflow.
Related Information
