Go to main content
SPARC T7-1 Server Installation Guide
Exit Print View
Updated: March 2019
Server Overview
This topic provides a high-level introduction to the main components and capabilities of the server.
image:Figure showing the SPARC T7-1 server.
Component
Description
Chassis
Rack-mountable server.
CPU
One processor installed on the motherboard assembly.
Memory
Eight DDR4 DIMMs connect to the motherboard. An additional eight DIMMs can connect to two memory risers (optional). A server with 16 64-GB DIMMs supports 1024 GB of system memory.
I/O expansion
Six PCIe Gen3 slots. All slots support x8 PCIe cards.
Storage devices
For internal storage, the server provides:
  • Eight 2.5-inch drive bays, accessible through the front panel.
  • A slot-loading DVD+/-RW SATA drive on the front of the server, above the right drive bays.
USB ports
  • Two external USB 3.0 ports (rear panel).
  • Two external USB 2.0 ports (front panel).
Video port
One high-density DB-15 video port (rear)
Ethernet ports
Four 10GbE 100/1000/10000 Mbps, RJ-45-based ports on the rear panel.
Power supplies
Two hot-swappable (1+1) AC 1000W power supplies.
Cooling fans
Four hot-swappable, redundant fan modules at chassis front (top-loading). Redundant fans in each power supply.
SP
Oracle Integrated Lights Out Manager (Oracle ILOM).
Related Information
