Go to main content
SPARC T7-1 Server Installation Guide
Exit Print View
Updated: March 2019
ESD Precautions
Electronic equipment is susceptible to damage by static electricity. Use a grounded antistatic wrist strap, foot strap, or equivalent safety equipment to prevent electrostatic damage when you install or service the servers.
Caution
Caution  -  Electrostatic discharge can permanently disable the server or require repair by service techniciens. To protect electronic components from electrostatic damage, place components on an antistatic surface, such as an antistatic discharge mat, an antistatic bag, or a disposable antistatic mat. Wear an antistatic grounding strap connected to a metal surface on the chassis when you work on server components.
Related Information
