Go to main content
SPARC T7-1 Server Installation Guide
Exit Print View
Updated: March 2019
NET MGT Port
The NET MGT RJ-45 port, located on the rear panel, provides an optional Ethernet connection to the SP. The NET MGT port is an optional connection to Oracle ILOM on the SP. The SP NET MGT port uses an RJ-45 cable for a 10/100BASE-T connection. If your network does not use a DHCP server, this port will not be available until you configure network settings through the SER MGT port.
This port does not support connections to Gigabit networks.
image:Figure showing the NET MGT port pin numbering
Pin
Signal Description
Pin
Signal Description
1
Transmit Data +
5
No Connect
2
Transmit Data –
6
Receive Data –
3
Receive Data +
7
No Connect
4
No Connect
8
No Connect
Related Information
