VGA Port
The server has one 15-pin VGA video port on the rear of the server. See Rear Panel Components (Installation). Use a DB-15 video cable to connect to a
video adapter to achieve the required connection. Maximum supported resolution is
1024 x 768.
Note - The cable length used to connect between the monitor
and the VGA port should not be over 6 meters.
1 |
Red Video |
9 |
[KEY] |
2 |
Green Video |
10 |
Sync Ground |
3 |
Blue Video |
11 |
Monitor ID - Bit 1 |
4 |
Monitor ID - Bit 2 |
12 |
VGA 12C Serial Data |
5 |
Ground |
13 |
Horizontal Sync |
6 |
Red Ground |
14 |
Vertical Sync |
7 |
Green Ground |
15 |
VGA 12C Serial Clock |
8 |
Blue Ground |
