Go to main content
SPARC T7-1 Server Installation Guide
Exit Print View
Updated: March 2019
Connect the SER MGT Cable
The SP serial management port is labeled SER MGT. Use the SER MGT port only for server management. This port is the default connection between the SP and a terminal or a computer.
Caution
Caution  - Do not attach a modem to this port.
  • Connect a Category 5 (or better) RJ-45 cable from the SER MGT port to a terminal device.
    When connecting a DB-9 cable, use an adapter to perform the crossovers given for each connector.
    image:Figure showing how to connect to the SER MGT port.
Related Information
