SER MGT
Port
The SER MGT RJ-45 port, located on the rear panel, provides a TIA/EIA-232 serial Oracle/Cisco
standard connection to the SP. This port is the default connection to the Oracle
ILOM SP. For DTE to DTE communications, you can use the supplied RJ-45 to DB-9
crossover adapter with a standard RJ-45 cable to achieve the required null modem
configuration. See Rear Panel Components (Installation).
1 |
Request to Send |
5 |
Ground |
2 |
Data Terminal Ready |
6 |
Receive Data |
3 |
Transmit Data |
7 |
Data Set Ready |
4 |
Ground |
8 |
Clear to Send |
