Go to main content
SPARC T7-1 Server Installation Guide
Exit Print View
Updated: March 2019
Install the Rackmount Hardware
Complete the following task to remove the mounting brackets from the slide rail assemblies before installation.
  1. Unpack the slide rails.
    The rackmount kit contains two slide rails, two mounting brackets, and optional securing screws.
    Note -  Refer to the rackmount kit installation card for simplified instructions about installing your server into a 4-post rack, using the slide rail and CMA options.
    image:Drawing of contents of the rackmount kit.
    No.
    Description
    1
    Slide rails
    2
    Mounting brackets
    3
    Four M4 x 5 fine-pitch mounting bracket securing screws (not used)
    4
    Installation card
  2. Position a mounting bracket against the chassis so that the slide rail lock is at the server front, and the five keyhole openings on the mounting bracket are aligned with the five locating pins on the side of the chassis.
    image:Figure showing how to attach a mounting bracket to each side of the                             server.
    No.
    Description
    1
    Server front
    2
    Slide rail lock
    3
    Mounting bracket
    4
    Mounting bracket clip
  3. With the heads of the five chassis locating pins protruding through the five keyhole openings in the mounting bracket, pull the mounting bracket toward the front of the chassis until the mounting bracket clip locks into place with an audible click.
  4. Verify that the rear locating pin has engaged the mounting bracket clip.
  5. Repeat Step 2 through Step 4 to install the remaining mounting bracket on the other side of the server.
  6. Attach slide rail assemblies to the rack.
    See Attach Slide Rail Assemblies to the Rack.
Related Information
