![]() | Caution - Hazardous voltages are present. To reduce the risk of electric shock and danger to personal health, follow the instructions. |
![]() | Caution - If a power supply fails and you do not have a replacement available, to ensure proper airflow, leave the failed power supply installed in the server until you replace it with a new power supply. |
You can perform this procedure while the server is running. See Component Service Categories for more information about hot service procedures.
See Release the CMA.
Do not allow the CMA to hang unsupported while it is unattached.
![]() | Caution - There is no restraint mechanism on the power supply to prevent it from sliding completely out of the chassis. Use care when removing the power supply to prevent it from falling. |
![]() | Caution - Whenever you remove a power supply, you should replace it with another power supply. Otherwise, the server might overheat due to improper airflow. If a new power supply is not available, leave the failed power supply installed until it can be replaced. |
