Exit Print View
These topics describe how to remove and install memory risers and DIMMs in the server.
Memory Riser and DIMM Configuration
Checking DIMM Compatibility
Memory Riser and DIMM FRU Names
Add Memory to the Server
Locating and Replacing a Faulty DIMM
Remove a Memory Riser
Remove a DIMM or DIMM Filler
Install a DIMM or DIMM Filler
Install a Memory Riser
Enable and Verify a DIMM
DIMM Configuration Errors
