Are you starting a new troubleshooting session with this task?
Do you access the SP from the network or terminal server?
Network – Go to Step 3.
Terminal server (serial
interface) – Go to Step 8.
Can you access the SP from the network?
See Access the SP (1GBase-T RJ-45 Port), then return to this step.
Can you ping the switch from the network?
Are you sure that the network parameters are configured correctly?
From the terminal server (serial interface), enable the network
administrative interface and network services through Oracle ILOM.
-> set /SP/network state=enabled
-> set /SP/services/ssh state=enabled
-> set /SP/services/https servicestate=enabled
Then return to Step 3.
From the terminal server (serial interface), configure the correct network
parameters through Oracle ILOM.
See Access the SP (SER MGT Port), then return to this step.
Type:
-> set /SP/network pendingipdiscovery=static
-> set /SP/network pendingipaddress=IP_address_for_SP
-> set /SP/network pendingipgateway=IP_address_for_gateway
-> set /SP/network pendingipnetmask=255.255.255.0
-> set /SP/network commitpending=true
Can you access the SP from the terminal server or serial interface?
Are you sure that the serial parameters are configured correctly?
Configure the correct serial parameters for the terminal server or serial
console.
Baud – 9600
Data bits – 8
Parity – N
Stop bits – 1
Flow control –
none
From the network, configure the correct serial parameters through Oracle
ILOM.
Type:
-> set /SP/serial/external pendingflowcontrol=none
-> set /SP/serial/external pendingspeed=9600
-> set /SP/serial/external commitpending=true
Then return to Step 8.
Are you sure that the cabling is wired correctly with good cables and firm
connections?
Inspect and replace cabling as necessary.
Then return to Step 2.
Are you sure that the communication hardware (NICs, hosts, terminals,
routers, and switches) is fully functional?
Inspect and replace communication hardware as necessary.
Perform a visual inspection of the switch.
See Perform Diagnostics at the Switch.
Display the log files from Oracle ILOM.
-> show /SP/logs/event/list Class==Fault Type==Fault
Do the log entries identify the problem?
Is the problem hardware or software related?
Has enough information been provided to justify a service
operation?
Remove the faulted component and install a new component.
See Faulted Item Replaceable Components or Oracle ILOM Legacy Target Replaceable Components for links to component service
tasks.
Perform Oracle ILOM target diagnostics.
See Perform Oracle ILOM Target Diagnostics.
