Servicing Data Cables
Data cables provide a conduit for high-speed Ethernet network and IB fabric communication.
The data cables are located across the rear of the switch. See Identifying Components.
Familiarize yourself with the three cable types.
Replace a faulty data cable.
Remove a data cable as part of another component's service
operation.
Install a data cable as part of another component's service
operation.
Add additional data cables.
Decrease the number of existing data cables.
Identify a faulty data cable.
