Go to main content
Oracle® Fabric Interconnect F2-12 Service Manual
Exit Print View
Updated: November 2016
Prevent ESD Damage
Many components housed within the chassis can be damaged by electrostatic discharge. To protect these components from damage, perform these steps before opening the chassis for service. See Safety Information.
  1. Prepare an antistatic surface to set parts on during the removal, installation, or replacement process.
    Place ESD-sensitive components, such as printed circuit boards, on an antistatic mat.
  2. Attach an antistatic wrist strap.
    When servicing or removing switch components, attach an antistatic strap to your wrist and then to a metal area on the chassis.
  3. Consider your next task.
Related Information
