Go to main content
oracle home
Oracle
Fabric Interconnect F2-12 Service Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Fabric Interconnect F2-12 Documentation ...
Oracle
Fabric Interconnect ...
Identifying Components
Front Panel Components
Updated: November 2016
Oracle
Document Information
Using This Documentation
Product Documentation Library
Feedback
Switch Front Components
Switch Rear Components
Rear Panel Components
Detecting and Managing Faults
Troubleshooting the Switch
Begin the Diagnostic Process
Perform Diagnostics at the Switch
Perform Additional Diagnostics at the Switch
Perform Diagnostics Remotely
Perform Oracle ILOM Target Diagnostics
Identifying Components of Faulted Targets
Oracle ILOM /HOST and /SP Target Replaceable Components
Oracle ILOM /System Target Replaceable Components
Oracle ILOM Legacy Target Replaceable Components
Faulted Item Replaceable Components
Diagnostic Tools
Troubleshooting (LEDs)
Inspect the LEDs
Front Panel LEDs
RJ-45 Link LEDs
Component LEDs
Accessing the SP
Access the SP (1GBase-T RJ-45 Port)
Access the SP (SER MGT Port)
Configure and Enable Network Management (SER MGT Port)
Troubleshooting (Oracle ILOM /SP Targets)
Display Oracle ILOM Log Entries
Oracle ILOM Log Entry Filters
Display Network Management Configuration Properties
Display User Session Information
Display the SP Firmware Version
Troubleshooting (Oracle ILOM /System Targets)
Display Problematic Components
Open Problem Faults
Display the General Health of Components and Systems
Oracle ILOM Target Health States
Display Active Power Consumption
Troubleshooting (Oracle ILOM Legacy Targets)
Enable Oracle ILOM Legacy Targets
Display Status for Specific Components
Clear a Fault Manually
Oracle ILOM Legacy Targets for Fault State and FRUID
Oracle ILOM Legacy Targets for Power Consumption
Oracle ILOM Legacy Targets for Voltage
Oracle ILOM Legacy Targets for Temperature
Oracle ILOM Legacy Targets for Fan Speeds
Oracle ILOM Legacy Targets for LED States
Resettable Targets
Preparing for Service
Safety Information
Safety Symbols
ESD Measures
Antistatic Wrist Strap Use
Antistatic Mat
Service Tools
Read the Switch Serial Number (Oracle ILOM)
Locate the Switch
Prevent ESD Damage
Prepare to Power Off the Switch
Servicing Data Cables
Identifying Data Cable Types
PrizmMT Cables
QSFP Cables and Transceivers
RJ-45 Cables
LC Cables
Locate a Faulty Data Cable
Remove a Data Cable
(Optional) Assemble the QSFP and SFP+ Cables
Install a Data Cable
Verify a Data Cable
(Optional) Clean the PrizmMT Receptacle or Connector Ferrule
Servicing Fan Modules
Fan Module LED
Locate a Faulty Fan Module
Remove a Fan Module
Install a Fan Module
Verify a Fan Module
Servicing I/O Modules
Preparing I/O Modules for Service
I/O Module LEDs
Locate a Faulty I/O Module
Disconnect the I/O Module From the Switch Fabric
Remove an I/O Module
Install an I/O Module
Verify an I/O Module
Add the I/O Module to the Switch Fabric
Servicing Filler Panels
Remove a Filler Panel
Install a Filler Panel
Servicing Power Supplies
Power Supply LEDs
Locate a Faulty Power Supply
Remove a Power Supply
Install a Power Supply
Verify a Power Supply
Replacing the Switch
Switch LEDs
Determine if the Switch Is Faulty
Remove the SER MGT Cable
Remove the Switch
Install the Switch
Install the SER MGT Cable
Verify the Switch
Configure the Replacement Switch
Returning the Switch to Operation
Power On the Switch
Verify the Serviced Component
Glossary
Index
Index Numbers and Symbols
Index A
Index C
Index D
Index E
Index F
Index H
Index I
Index L
Index N
Index O
Index P
Index Q
Index R
Index S
Index T
Index U
Index V
Language:
English
Item
Description
Links
1
Serial number
2
Fan modules 0 to 3 starting with the left-most fan.
3
Chassis status LEDs
Front Panel LEDs
4
Power supplies 0 and 1 starting with the left-most power supply.
Related Information
Locate the Switch
Previous
Next
