Prepare to Power Off the Switch
Perform this task before powering off the switch.
Notify affected users that the switch is to be shut down.
Set the priority of the switch to be removed to the lowest.
Wait for any handover to complete.
Create a backup of the switch configuration for the switch to be
removed.
Refer to Performing Backups in Oracle Fabric Manager 5.0.2 Administration Guide.
Disconnect the power cords at the rear of the switch to power it off.
See Power Off the Switch.
