Rack units |
2U |
2U |
Height
3.46 in.
88 mm
Width (chassis)
Maximum Width (from bezel front to rear protrusions)
16.73 in.
17.52 in.
425 mm
445 mm
Depth (chassis)
Maximum Depth (from bezel front to rear protrusions)
23.9 in.
25.2 in.
608 mm
640 mm
Weight (fully configured without PCIe cards)
47.3 lb
21.5 kg
Minimum service clearance (front) |
36 in. |
914.4 mm |
Minimum service clearance (rear) |
36 in. |
914.4 mm |
Minimum airflow clearance (front) |
2 in. |
50.8 mm |
Minimum airflow clearance (rear) |
3 in. |
76.2 mm |
