Go to main content
SPARC T8-1 Server Service Manual
Exit Print View
Updated: January 2022
Remove a Power Supply
Caution
Caution  - Hazardous voltages are present. To reduce the risk of electric shock and danger to personal health, follow the instructions.
Caution
Caution  - If a power supply fails and you do not have a replacement available, to ensure proper airflow, leave the failed power supply installed in the server until you replace it with a new power supply.
You can perform this procedure while the server is running. See Component Service Categories for more information about hot service procedures.
  1. Prepare for servicing.
    1. Attach an antistatic wrist strap.
    2. If necessary, release the CMA to access the power supplies.
      See Release the CMA.
      Do not allow the CMA to hang unsupported while it is unattached.
  2. Disconnect the power cord from the power supply that displays a lit amber Service Required LED.
  3. Press the release latch to the left to open the ejector arm.
    image:Figure showing how to remove a power supply.
  4. Slide the power supply out of the chassis.
    Caution
    Caution  -  There is no restraint mechanism on the power supply to prevent it from sliding completely out of the chassis. Use care when removing the power supply to prevent it from falling.
    Caution
    Caution  - Whenever you remove a power supply, you should replace it with another power supply. Otherwise, the server might overheat due to improper airflow. If a new power supply is not available, leave the failed power supply installed until it can be replaced.
  5. Install a new power supply.
    See Install a Power Supply.
Related Information
