Go to main content
SPARC T8-1 Server Service Manual
Exit Print View
Updated: January 2022
Verify the Drive Backplane
  1. Use the Oracle ILOM show faulty command to verify that the fault has been cleared.
    See Identify Faulted Components for more information on using the show faulty command.
  2. Perform one of the following tasks based on your verification results:
    • If the previous steps did not clear the fault, see Detecting and Managing Faults for information about the tools and methods you can use to diagnose component faults.
    • If the previous steps indicate that no faults have been detected, then the component has been replaced successfully. No further action is required.
Related Information
