Exit Print View
These topics describe how to remove and install memory risers and DIMMs in the server.
Memory Riser and DIMM Configuration
Checking DIMM Compatibility
Memory Riser and DIMM FRU Names
Add Memory to the Server
Replace a Faulty DIMM
Locate a Faulty DIMM (Oracle ILOM)
Locate a Faulty DIMM (Fault Remind Button)
Remove a Memory Riser
Remove a DIMM
Install a DIMM
Install a Memory Riser
Enable and Verify a DIMM
DIMM Configuration Errors
