Power Off the Server (Oracle
ILOM)
You can use the SP to perform a graceful shutdown of the server, and to ensure that all of
your data is saved and the server is ready for restart.
- Prepare
to power off the server.
See Prepare to Power Off the Server.
- If you are consoled to the host, switch from the system console to the Oracle ILOM prompt by
typing the #. (Hash-Dot) key sequence.
- Power off the server.
-> stop /System
