Text Box
The following is an example of a basic text box:
Text Box
If the text box is a large field, the text box may be configured to enable scrolling. In this situation, an expanded edit icon, (a pencil), will appear adjacent to it.
Text Box Scrolling
Additional capabilities are provided to display and edit data in these text boxes:
  • If the field contains more text than is visible, a pop-up that displays the full text appears when you hover your mouse over the text box. The text in the pop-up can be selected and copied.
Text Mouse Over
  • If you click the expanded edit icon, an editable pop-up window appears. If the field is not protected as a result of business rules for the page, you may modify the text in this window.
Text Box Edit
Note: The following table highlights special characters that are converted to equivalent standard characters when entered in a text box.
Entered Character Description Unicode Converted Character Description
Curly left double quote.
U+201D
Straight double quote.
Curly right double quote.
U+201C
Curly left single quote.
U+2019
Straight single quote.
Curly right single quote.
U+2018
En dash.
U+2013
Simple hyphen.
Em dash.
U+2014
Simple hyphen.
Ellipse
U+2026
Three dots.
Middle dot (bullet / centered dot)
U+00B7
Asterisk.
Fraction 1/4 (using 1 character).
U+00BC
1/4 (using three separate characters).
Fraction 1/2 (using 1 character).
U+00BD
1/2 (using three separate characters).
Fraction 3/4 (using 1 character).
U+00BE
3/4 (using three separate characters).
