Prerequisites
To setup the offset request feature, you need to do the following:
  • Define the required offset adjustment types where the A/P Request Type Code field is not set to REFUND.
  • Define a default offset amount algorithm using the C1-OFST-AMT algorithm type.
  • Assign the C1-OFSRQ To Do type to a To Do role whose users must receive a To Do while submitting an offset request for approval.
  • Assign the C1-OFSSB To Do type to a To Do role whose users must not approve an offset request.
  • Define the required offset request types in the system.
  • Define the required characteristic types where the characteristic entity is set to Offset Request Type.
  • Define the required characteristic types where the characteristic entity is set to Offset Request.
  • Define the values for the CAN_​RSN_​CD_​FLG lookup field.
  • Set the parameters of the C1-UPD-FUND, C1-DFRUNAPLY, C1-WTBS-CRBL, and C1-OFST-DIST algorithms.
  • Define the status reasons for the Rejected and Unapplied Offset statuses of the C1-OffsetRequest business object in the Status Reason screen.
  • Set the Allow Offsetting Across Persons option type of the C1-OFFSETREQ feature configuration.
  • Define the required exchange rates in the system.
  • Define a currency conversion algorithm for bill segments using the C1_​CURALGBS or C1_​EXCRTBS algorithm type.
  • Attach a currency conversion algorithm to the Currency Conversion For Bill Segments algorithm spot of the required divisions.
  • Define a currency conversion algorithm for adjustments using the C1_​CURALGAD or C1_​EXCRTAD algorithm type.
  • Attach a currency conversion algorithm to the Currency Conversion For Adjustments algorithm spot of the required divisions.
  • Set the batch control type of the Offset Request Periodic Monitor (C1-OFSRQ) batch to Timed and define the following attributes:
    • Time Interval
    • Timer Active
    • User ID
    • Batch Language
    • Email Address
    For more information about the Offset Request Periodic Monitor (C1-OFSRQ) batch, see Oracle Revenue Management and Billing Batch Guide.
Related Topics
For more information on... See...
How to setup the C1-OFFSETREQ feature configuration Setting the C1-OFFSETREQ Feature Configuration
C1-OFST-AMT algorithm C1-OFST-AMT
C1-UPD-FUND algorithm C1-UPD-FUND
C1-DFRUNAPLY algorithm C1-DFRUNAPLY
C1-WTBS-CRBL algorithm C1-WTBS-CRBL
C1-OFST-DIST algorithm C1-OFST-DIST
C1_​CURALGBS algorithm C1_​CURALGBS
C1_​EXCRTBS algorithm C1_​EXCRTBS
C1_​CURALGAD algorithm C1_​CURALGAD
C1_​EXCRTAD algorithm C1_​EXCRTAD
