Defining a Characteristic for the Market Product
Prerequisites
To define a characteristic to a market product, you should have:
Product defined in the application.
Characteristic type defined in the application.
Procedure
To define characteristic type to the product:
Ensure that the Additional Attributes section is expanded in the Other Details zone
of Basic Details page when you are defining
characteristic type to the product.
The Additional Attributes zone contains the following fields:
Field Name Field Description Mandatory (Yes or No) Effective Date Used to specify the date from when the characteristics type and characteristics value is effective. No Characteristics Type Used to associate a characteristics type to the product. No Characteristics Value Used to assign a characteristics value to the product. No - Enter the required details in the Additional Attribute section.
- Click Save as Draft, to save the product in the draft.
Click Next, to go to Other Detailspage.
The product is saved as draft in the application.
Related Topics
For more information on... | See... |
Other Details page | Market Product Information - Other Details |
Other Details zone | Other Details |
