Defining Eligibility Criteria for the Market Product
Prerequisites
To define eligibility criteria for the market product, you should have:
Parameter defined in the application.
Procedure
To define eligibility criteria for the market product:
Ensure that the Eligibility zone
is expanded in the Eligibility page when you
are defining eligibility criteria for the market product.
The Eligibility zone contains the following fields:
Field Name Field Description Mandatory (Yes or No) Eligibility Rule Used to specify a eligibility rule for the market product. Yes Start Date Used to specify the date from when the eligibility rule will be effective. Yes End Date Used to specify the date till when the eligibility rule will be effective. No Parameter Used to search the parameter which you want to associate with the eligibility rule. Note: The Search () appears corresponding to the fields. On clicking the Search icon, the Parameter Search window appears where you can search for the required parameter.
Yes Operator Used to specify the relational operator to define the relation between the parameter name and value. Yes Parameter Value Type Used to indicate the parameter value against which you want to compare the parameter. The valid values are: - Parameter
- Value
Yes Parameter Used to search the parameter (on the right hand side) against which you want to compare the parameter (on the left hand side). Note: The Search () appears corresponding to the fields. On clicking the Search icon, the Parameter Search window appears where you can search for the required parameter.
Yes Is True Used to indicate what happens when the condition is true (satisfied). The valid values are: - Check Next Condition - Indicates that the condition with consecutive sequence number should be executed.
- Rule Is Falsee - Indicates that the action specified in the Rule False Action field should be executed.
- Rule Is True - Indicates that the action specified in the Rule True Action field should be executed.
Yes Is False Used to indicate what happens when the condition is false (not satisfied). The valid values are: - Check Next Condition - Indicates that the condition with consecutive sequence number should be executed.
- Rule Is False - Indicates that the action specified in the Rule False Action field should be executed.
Yes Is Sufficient Used to indicate what happens when the data is insufficient. The valid values are: - Check Next Condition - Indicates that the condition with consecutive sequence number should be executed.
Yes TheEligibility zone contains the Eligibility Rules table which contain following columns:
Column Column Description Eligibility Rule Displays eligibility rule of the market product. Start Date Displays the date from when the eligibility rule is effective. End Date Displays the date till when the eligibility rule is effective. - Enter the required details in the Eligibility zone.
- Click Save as Draft, to save the market product in the draft.
Click Next, to go to Services page.
The market product is saved as draft in the application.
Related Topics
For more information on... | See... |
Eligibility zone | Eligibility |
How to define eligibility criteria for the market product | Defining Eligibility Criteria for the Market Product |
