git-ls-remote
(1)
Name
git-ls-remote - List references in a remote repository
Synopsis
git ls-remote [--heads] [--tags] [-u <exec> | --upload-pack <exec>]
[--exit-code] <repository> [<refs>...]
Description
Git Manual GIT-LS-REMOTE(1)
NAME
SYNOPSIS
DESCRIPTION
Displays references available in a remote repository along
with the associated commit IDs.
OPTIONS
-h, --heads, -t, --tags
Limit to only refs/heads and refs/tags, respectively.
These options are not mutually exclusive; when given
both, references stored in refs/heads and refs/tags are
displayed.
-u <exec>, --upload-pack=<exec>
Specify the full path of git-upload-pack on the remote
host. This allows listing references from repositories
accessed via SSH and where the SSH daemon does not use
the PATH configured by the user.
--exit-code
Exit with status "2" when no matching refs are found in
the remote repository. Usually the command exits with
status "0" to indicate it successfully talked with the
remote repository, whether it found any matching refs.
<repository>
Location of the repository. The shorthand defined in
$GIT_DIR/branches/ can be used. Use "." (dot) to list
references in the local repository.
<refs>...
When unspecified, all references, after filtering done
with --heads and --tags, are shown. When <refs>... are
specified, only references matching the given patterns
are displayed.
EXAMPLES
$ git ls-remote --tags ./.
d6602ec5194c87b0fc87103ca4d67251c76f233a refs/tags/v0.99
f25a265a342aed6041ab0cc484224d9ca54b6f41 refs/tags/v0.99.1
7ceca275d047c90c0c7d5afb13ab97efdf51bd6e refs/tags/v0.99.3
c5db5456ae3b0873fc659c19fafdde22313cc441 refs/tags/v0.99.2
0918385dbd9656cab0d1d81ba7453d49bbc16250 refs/tags/junio-gpg-pub
$ git ls-remote http://www.kernel.org/pub/scm/git/git.git master pu rc
5fe978a5381f1fbad26a80e682ddd2a401966740 refs/heads/master
c781a84b5204fb294c9ccc79f8b3baceeb32c061 refs/heads/pu
Git 1.7.9.2 Last change: 02/22/2012 1
b1d096f2926c4e37c9c0b6a7bf2119bedaa277cb refs/heads/rc
$ echo http://www.kernel.org/pub/scm/git/git.git >.git/branches/public
$ git ls-remote --tags public v\*
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 2
