script [-a] [filename]
The script utility makes a record of everything printed on your screen. The record is written to filename. If no file name is given, the record is saved in the file typescript. See WARNINGS.
The script command forks and creates a sub-shell, according to the value of $SHELL, and records the text from this session. The script ends when the forked shell exits or when Control-d is typed.
The following option is supported:
Appends the session record to filename, rather than overwriting it.
script places everything that appears on the screen in filename, including prompts.
script can pose a security risk when used in directories that are writable by other users (for example, /tmp), especially when run by a privileged user, that is, root. Be sure that typescript is not a link before running script.
