t4014(1)
Name
tplot, t300, t300s, t4014, t450, tek, ver - graphics filters for various plotters
Synopsis
/usr/bin/tplot [-T terminal]
Description
tplot reads plotting instructions from the standard input and produces plotting instructions suitable for a particular terminal on the standard output.
If no terminal is specified, the environment variable TERM is used. The default terminal is tek.
Note -
This commands are obsolete and will be removed in a future release of Oracle Solaris.
Files
- /usr/lib/t300
- /usr/lib/t300s
- /usr/lib/t4014
- /usr/lib/t450
- /usr/lib/tek
- /usr/lib/vplot
Attributes
Availability
system/core-os
See also
vi(1), attributes(5)
