perl573delta
(1)
Name
perl573delta - what's new for perl v5.7.3
Synopsis
Please see following description for synopsis
Description
Perl Programmers Reference Guide PERL573DELTA(1)
NAME
DESCRIPTION
This document describes differences between the 5.7.2
release and the 5.7.3 release.
(To view the differences between the 5.6.0 release and the
5.7.0 release, see perl570delta. To view the differences
between the 5.7.0 release and the 5.7.1 release, see
perl571delta. To view the differences between the 5.7.1
release and the 5.7.2 release, see perl572delta.)
Changes
This is just a selected list of some of the more notable
changes. The numbers refer to the Perl repository change
numbers; see Changes58 (or Changes in Perl 5.8.1). In
addition to these changes, lots of work took place in
integrating threads, PerlIO, and Unicode; general code
cleanup; and last but not least porting to non-Unix lands
such as Win32, VMS, Cygwin, DJGPP, VOS, MacOS Classic, and
EBCDIC.
11362
add LC_MESSAGES to POSIX :locale_h export tag
11371
add DEL to [:cntrl:]
11375
make h2ph understand constants like 1234L and 5678LL
11405
Win32: fix bugs in handling of the virtualized
environment
11410
fix a bug in the security taint checking of open()
11423
make perl fork() safe even on platforms that don't have
pthread_atfork()
11459
make switching optimization and debugging levels during
Perl builds easier via the OPTIMIZE environment variable
11475
make split()'s unused captures to be undef, not ''
11485
Search::Dict: allow transforming lines before comparing
perl v5.12.5 Last change: 2012-11-03 1
11490
allow installing extra modules or bundles when building
Perl
11516
add -Wall in cflags when compiling with gcc to weed out
dubious C practices
11541
pluggable optimizer
11549
WinCE: integrate the port
11589
Win32: 4-arg select was broken
11594
introduce the perlivp utility for verifying the Perl
installation (IVP = Installation Verification Procedure)
11623
rename lib/unicode to lib/unicore to avoid case-
insensitivity problems with lib/Unicode
111631
remove Time::Piece
11643
document that use utf8 is not the right way most of the
time
11656
allow building perl with -DUSE_UTF8_SCRIPTS which makes
UTF-8 the default script encoding (not the default since
that would break all scripts having legacy eight-bit
data in them)
11725
division preserving 64-bit integers
11743
document the coderef-in-@INC feature
11794
modulo (%) preserving 64-bit integers
11825
update to Unicode 3.1.1
11865
add the \[$@%&*] prototype support
perl v5.12.5 Last change: 2012-11-03 2
11874
oct() and hex() in glorious 64 bit
11877
Class::Struct: allow recursive classes
11993
fix unpack U to be the reverse of pack U
12056
VMS: waitpid enhancements
12180
unpack("Z*Z*", pack("Z*Z*", ..)) was broken
12243
Devel::Peek: display UTF-8 SVs also as \x{...}
12288
Data::Dumper: option to sort hashes
12542
add perlpodspec
12652
threadsafe DynaLoader, re, Opcode, File::Glob, and B
12756
support BeOS better
12874
read-only hashes (user-level interface is Hash::Util)
13162
add Devel::PPPort
13179
add the sort pragma
13326
VMS: fix perl -P
13358
add perlpacktut
13452
SUPER-UX: add hints file
13575
Win32: non-blocking waitpid(-1,WNOHANG)
13684
perl v5.12.5 Last change: 2012-11-03 3
introduce the -t option for gentler taint checking
14694
add the if pragma
14832
implement IV/UV/NV/long double un/packing with j/J/F/D
14854
document the new taint behaviour of exec LIST and system
LIST
Reporting Bugs
If you find what you think is a bug, you might check the
articles recently posted to the comp.lang.perl.misc
newsgroup and the perl bug database at http://bugs.perl.org.
There may also be information at http://www.perl.com/, the
Perl Home Page.
If you believe you have an unreported bug, please run the
perlbug program included with your release. Be sure to trim
your bug down to a tiny but sufficient test case. Your bug
report, along with the output of "perl -V", will be sent off
to perlbug@perl.org to be analysed by the Perl porting team.
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | runtime/perl-512 |
|Stability | Uncommitted |
SEE ALSO
The Changes file for exhaustive details on what changed.
The INSTALL file for how to build Perl.
The README file for general stuff.
The Artistic and Copying files for copyright information.
HISTORY
Written by Jarkko Hietaniemi <jhi@iki.fi>, with many
contributions from The Perl Porters and Perl Users
submitting feedback and patches.
perl v5.12.5 Last change: 2012-11-03 4
Send omissions or corrections to <perlbug@perl.org>.
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://www.cpan.org/src/5.0/perl-5.12.5.tar.bz2
Further information about this software can be found on the
open source community website at http://www.perl.org/.
perl v5.12.5 Last change: 2012-11-03 5
