perl589delta
(1)
Name
perl589delta - what is new for perl v5.8.9
Synopsis
Please see following description for synopsis
Description
Perl Programmers Reference Guide PERL589DELTA(1)
NAME
DESCRIPTION
This document describes differences between the 5.8.8
release and the 5.8.9 release.
Notice
The 5.8.9 release will be the last significant release of
the 5.8.x series. Any future releases of 5.8.x will likely
only be to deal with security issues, and platform build
failures. Hence you should look to migrating to 5.10.x, if
you have not started already. See "Known Problems" for more
information.
Incompatible Changes
A particular construction in the source code of extensions
written in C++ may need changing. See "Changed Internals"
for more details. All extensions written in C, most written
in C++, and all existing compiled extensions are unaffected.
This was necessary to improve C++ support.
Other than this, there are no changes intentionally
incompatible with 5.8.8. If any exist, they are bugs and
reports are welcome.
Core Enhancements
Unicode Character Database 5.1.0.
The copy of the Unicode Character Database included in Perl
5.8 has been updated to 5.1.0 from 4.1.0. See
<http://www.unicode.org/versions/Unicode5.1.0/#NotableChanges>
for the notable changes.
stat and -X on directory handles
It is now possible to call "stat" and the "-X" filestat
operators on directory handles. As both directory and file
handles are barewords, there can be ambiguities over which
was intended. In these situations the file handle semantics
are preferred. Both also treat *FILE{IO} filehandles like
*FILE filehandles.
Source filters in @INC
It's possible to enhance the mechanism of subroutine hooks
in @INC by adding a source filter on top of the filehandle
opened and returned by the hook. This feature was planned a
long time ago, but wasn't quite working until now. See
"require" in perlfunc for details. (Nicholas Clark)
Exceptions in constant folding
The constant folding routine is now wrapped in an exception
handler, and if folding throws an exception (such as
attempting to evaluate 0/0), perl now retains the current
perl v5.12.5 Last change: 2012-11-03 1
optree, rather than aborting the whole program. Without
this change, programs would not compile if they had
expressions that happened to generate exceptions, even
though those expressions were in code that could never be
reached at runtime. (Nicholas Clark, Dave Mitchell)
"no VERSION"
You can now use "no" followed by a version number to specify
that you want to use a version of perl older than the
specified one.
Improved internal UTF-8 caching code
The code that caches calculated UTF-8 byte offsets for
character offsets for a string has been re-written. Several
bugs have been located and eliminated, and the code now
makes better use of the information it has, so should be
faster. In particular, it doesn't scan to the end of a
string before calculating an offset within the string, which
should speed up some operations on long strings. It is now
possible to disable the caching code at run time, to verify
that it is not the cause of suspected problems.
Runtime relocatable installations
There is now Configure support for creating a perl tree that
is relocatable at run time. see "Relocatable installations".
New internal variables
"${^CHILD_ERROR_NATIVE}"
This variable gives the native status returned by the
last pipe close, backtick command, successful call to
"wait" or "waitpid", or from the "system" operator. See
perlvar for details. (Contributed by Gisle Aas.)
"${^UTF8CACHE}"
This variable controls the state of the internal UTF-8
offset caching code. 1 for on (the default), 0 for off,
-1 to debug the caching code by checking all its results
against linear scans, and panicing on any discrepancy.
"readpipe" is now overridable
The built-in function "readpipe" is now overridable.
Overriding it permits also to override its operator
counterpart, "qx//" (also known as "``").
simple exception handling macros
Perl 5.8.9 (and 5.10.0 onwards) now provides a couple of
macros to do very basic exception handling in XS modules.
You can use these macros if you call code that may "croak",
but you need to do some cleanup before giving control back
to Perl. See "Exception Handling" in perlguts for more
details.
perl v5.12.5 Last change: 2012-11-03 2
-D option enhancements
o "-Dq" suppresses the EXECUTING... message when running
under "-D"
o "-Dl" logs runops loop entry and exit, and jump level
popping.
o "-Dv" displays the process id as part of the trace
output.
XS-assisted SWASHGET
Some pure-perl code that the regexp engine was using to
retrieve Unicode properties and transliteration mappings has
been reimplemented in XS for faster execution. (SADAHIRO
Tomoyuki)
Constant subroutines
The interpreter internals now support a far more memory
efficient form of inlineable constants. Storing a reference
to a constant value in a symbol table is equivalent to a
full typeglob referencing a constant subroutine, but using
about 400 bytes less memory. This proxy constant subroutine
is automatically upgraded to a real typeglob with subroutine
if necessary. The approach taken is analogous to the
existing space optimisation for subroutine stub
declarations, which are stored as plain scalars in place of
the full typeglob.
However, to aid backwards compatibility of existing code,
which (wrongly) does not expect anything other than
typeglobs in symbol tables, nothing in core uses this
feature, other than the regression tests.
Stubs for prototyped subroutines have been stored in symbol
tables as plain strings, and stubs for unprototyped
subroutines as the number -1, since 5.005, so code which
assumes that the core only places typeglobs in symbol tables
has been making incorrect assumptions for over 10 years.
New Platforms
Compile support added for:
o DragonFlyBSD
o MidnightBSD
o MirOS BSD
o RISC OS
o Cray XT4/Catamount
perl v5.12.5 Last change: 2012-11-03 3
Modules and Pragmata
New Modules
o "Module::Pluggable" is a simple framework to create
modules that accept pluggable sub-modules. The bundled
version is 3.8
o "Module::CoreList" is a hash of hashes that is keyed on
perl version as indicated in $]. The bundled version is
2.17
o "Win32API::File" now available in core on Microsoft
Windows. The bundled version is 0.1001_01
o "Devel::InnerPackage" finds all the packages defined by
a single file. It is part of the "Module::Pluggable"
distribution. The bundled version is 0.3
Updated Modules
o "attributes" upgraded to version 0.09
o "AutoLoader" upgraded to version 5.67
o "AutoSplit" upgraded to 1.06
o "autouse" upgraded to version 1.06
o "B" upgraded from 1.09_01 to 1.19
o provides new pad related abstraction macros
"B::NV::COP_SEQ_RANGE_LOW",
"B::NV::COP_SEQ_RANGE_HIGH",
"B::NV::PARENT_PAD_INDEX",
"B::NV::PARENT_FAKELEX_FLAGS", which hides the
difference in storage in 5.10.0 and later.
o provides "B::sub_generation", which exposes
"PL_sub_generation"
o provides "B::GV::isGV_with_GP", which on pre-5.10
perls always returns true.
o New type "B::HE" added with methods "VAL", "HASH"
and "SVKEY_force"
o The "B::GVf_IMPORTED_CV" flag is now set correctly
when a proxy constant subroutine is imported.
o bugs fixed in the handling of "PMOP"s.
o "B::BM::PREVIOUS" returns now "U32", not "U16".
"B::CV::START" and "B:CV::ROOT" return now "NULL" on
an XSUB, "B::CV::XSUB" and "B::CV::XSUBANY" return 0
perl v5.12.5 Last change: 2012-11-03 4
on a non-XSUB.
o "B::C" upgraded to 1.05
o "B::Concise" upgraded to 0.76
o new option "-src" causes the rendering of each
statement (starting with the nextstate OP) to be
preceded by the first line of source code that
generates it.
o new option "-stash="somepackage"", "require"s
"somepackage", and then renders each function
defined in its namespace.
o now has documentation of detailed hint symbols.
o "B::Debug" upgraded to version 1.05
o "B::Deparse" upgraded to version 0.87
o properly deparse "print readpipe $x, $y".
o now handles "''-"()>, "::()", "sub :: {}", etc.
correctly [RT #43010]. All bugs in parsing these
kinds of syntax are now fixed:
perl -MO=Deparse -e '"my %h = "->()'
perl -MO=Deparse -e '::->()'
perl -MO=Deparse -e 'sub :: {}'
perl -MO=Deparse -e 'package a; sub a::b::c {}'
perl -MO=Deparse -e 'sub the::main::road {}'
o does not deparse $^H{v_string}, which is
automatically set by the internals.
o "B::Lint" upgraded to version 1.11
o "B::Terse" upgraded to version 1.05
o "base" upgraded to version 2.13
o loading a module via base.pm would mask a global
$SIG{__DIE__} in that module.
o push all classes at once in @ISA
o "Benchmark" upgraded to version 1.10
o "bigint" upgraded to 0.23
o "bignum" upgraded to 0.23
perl v5.12.5 Last change: 2012-11-03 5
o "bigrat" upgraded to 0.23
o "blib" upgraded to 0.04
o "Carp" upgraded to version 1.10
The argument backtrace code now shows "undef" as
"undef", instead of a string "undef".
o "CGI" upgraded to version 3.42
o "charnames" upgraded to 1.06
o "constant" upgraded to version 1.17
o "CPAN" upgraded to version 1.9301
o "Cwd" upgraded to version 3.29 with some platform
specific improvements (including for VMS).
o "Data::Dumper" upgraded to version 2.121_17
o Fixes hash iterator current position with the pure
Perl version [RT #40668]
o Performance enhancements, which will be most evident
on platforms where repeated calls to C's "realloc()"
are slow, such as Win32.
o "DB_File" upgraded to version 1.817
o "DB_Filter" upgraded to version 0.02
o "Devel::DProf" upgraded to version 20080331.00
o "Devel::Peek" upgraded to version 1.04
o "Devel::PPPort" upgraded to version 3.14
o "diagnostics" upgraded to version 1.16
o "Digest" upgraded to version 1.15
o "Digest::MD5" upgraded to version 2.37
o "DirHandle" upgraded to version 1.02
o now localises $., $@, $!, $^E, and $? before closing
the directory handle to suppress leaking any side
effects of warnings about it already being closed.
o "DynaLoader" upgraded to version 1.09
perl v5.12.5 Last change: 2012-11-03 6
"DynaLoader" can now dynamically load a loadable object
from a file with a non-default file extension.
o "Encode" upgraded to version 2.26
"Encode::Alias" includes a fix for encoding "646" on
Solaris (better known as ASCII).
o "English" upgraded to version 1.03
o "Errno" upgraded to version 1.10
o "Exporter" upgraded to version 5.63
o "ExtUtils::Command" upgraded to version 1.15
o "ExtUtils::Constant" upgraded to version 0.21
o "ExtUtils::Embed" upgraded to version 1.28
o "ExtUtils::Install" upgraded to version 1.50_01
o "ExtUtils::Installed" upgraded to version 1.43
o "ExtUtils::MakeMaker" upgraded to version 6.48
o support for "INSTALLSITESCRIPT" and
"INSTALLVENDORSCRIPT" configuration.
o "ExtUtils::Manifest" upgraded to version 1.55
o "ExtUtils::ParseXS" upgraded to version 2.19
o "Fatal" upgraded to version 1.06
o allows built-ins in "CORE::GLOBAL" to be made fatal.
o "Fcntl" upgraded to version 1.06
o "fields" upgraded to version 2.12
o "File::Basename" upgraded to version 2.77
o "FileCache" upgraded to version 1.07
o "File::Compare" upgraded to 1.1005
o "File::Copy" upgraded to 2.13
o now uses 3-arg open.
o "File::DosGlob" upgraded to 1.01
perl v5.12.5 Last change: 2012-11-03 7
o "File::Find" upgraded to version 1.13
o "File::Glob" upgraded to version 1.06
o fixes spurious results with brackets inside braces.
o "File::Path" upgraded to version 2.07_02
o "File::Spec" upgraded to version 3.29
o improved handling of bad arguments.
o some platform specific improvements (including for
VMS and Cygwin), with an optimisation on "abs2rel"
when handling both relative arguments.
o "File::stat" upgraded to version 1.01
o "File::Temp" upgraded to version 0.20
o "filetest" upgraded to version 1.02
o "Filter::Util::Call" upgraded to version 1.07
o "Filter::Simple" upgraded to version 0.83
o "FindBin" upgraded to version 1.49
o "GDBM_File" upgraded to version 1.09
o "Getopt::Long" upgraded to version 2.37
o "Getopt::Std" upgraded to version 1.06
o "Hash::Util" upgraded to version 0.06
o "if" upgraded to version 0.05
o "IO" upgraded to version 1.23
Reduced number of calls to "getpeername" in "IO::Socket"
o "IPC::Open" upgraded to version 1.03
o "IPC::Open3" upgraded to version 1.03
o "IPC::SysV" upgraded to version 2.00
o "lib" upgraded to version 0.61
o avoid warning about loading .par files.
perl v5.12.5 Last change: 2012-11-03 8
o "libnet" upgraded to version 1.22
o "List::Util" upgraded to 1.19
o "Locale::Maketext" upgraded to 1.13
o "Math::BigFloat" upgraded to version 1.60
o "Math::BigInt" upgraded to version 1.89
o "Math::BigRat" upgraded to version 0.22
o implements new "as_float" method.
o "Math::Complex" upgraded to version 1.54.
o "Math::Trig" upgraded to version 1.18.
o "NDBM_File" upgraded to version 1.07
o improve g++ handling for systems using GDBM
compatibility headers.
o "Net::Ping" upgraded to version 2.35
o "NEXT" upgraded to version 0.61
o fix several bugs with "NEXT" when working with
"AUTOLOAD", "eval" block, and within overloaded
stringification.
o "ODBM_File" upgraded to 1.07
o "open" upgraded to 1.06
o "ops" upgraded to 1.02
o "PerlIO::encoding" upgraded to version 0.11
o "PerlIO::scalar" upgraded to version 0.06
o [RT #40267] "PerlIO::scalar" doesn't respect
readonly-ness.
o "PerlIO::via" upgraded to version 0.05
o "Pod::Html" upgraded to version 1.09
o "Pod::Parser" upgraded to version 1.35
o "Pod::Usage" upgraded to version 1.35
perl v5.12.5 Last change: 2012-11-03 9
o "POSIX" upgraded to version 1.15
o "POSIX" constants that duplicate those in "Fcntl"
are now imported from "Fcntl" and re-exported,
rather than being duplicated by "POSIX"
o "POSIX::remove" can remove empty directories.
o "POSIX::setlocale" safer to call multiple times.
o "POSIX::SigRt" added, which provides access to POSIX
realtime signal functionality on systems that
support it.
o "re" upgraded to version 0.06_01
o "Safe" upgraded to version 2.16
o "Scalar::Util" upgraded to 1.19
o "SDBM_File" upgraded to version 1.06
o "SelfLoader" upgraded to version 1.17
o "Shell" upgraded to version 0.72
o "sigtrap" upgraded to version 1.04
o "Socket" upgraded to version 1.81
o this fixes an optimistic use of "gethostbyname"
o "Storable" upgraded to 2.19
o "Switch" upgraded to version 2.13
o "Sys::Syslog" upgraded to version 0.27
o "Term::ANSIColor" upgraded to version 1.12
o "Term::Cap" upgraded to version 1.12
o "Term::ReadLine" upgraded to version 1.03
o "Test::Builder" upgraded to version 0.80
o "Test::Harness" upgraded version to 2.64
o this makes it able to handle newlines.
o "Test::More" upgraded to version 0.80
perl v5.12.5 Last change: 2012-11-03 10
o "Test::Simple" upgraded to version 0.80
o "Text::Balanced" upgraded to version 1.98
o "Text::ParseWords" upgraded to version 3.27
o "Text::Soundex" upgraded to version 3.03
o "Text::Tabs" upgraded to version 2007.1117
o "Text::Wrap" upgraded to version 2006.1117
o "Thread" upgraded to version 2.01
o "Thread::Semaphore" upgraded to version 2.09
o "Thread::Queue" upgraded to version 2.11
o added capability to add complex structures (e.g.,
hash of hashes) to queues.
o added capability to dequeue multiple items at once.
o added new methods to inspect and manipulate queues:
"peek", "insert" and "extract"
o "Tie::Handle" upgraded to version 4.2
o "Tie::Hash" upgraded to version 1.03
o "Tie::Memoize" upgraded to version 1.1
o "Tie::Memoize::EXISTS" now correctly caches its
results.
o "Tie::RefHash" upgraded to version 1.38
o "Tie::Scalar" upgraded to version 1.01
o "Tie::StdHandle" upgraded to version 4.2
o "Time::gmtime" upgraded to version 1.03
o "Time::Local" upgraded to version 1.1901
o "Time::HiRes" upgraded to version 1.9715 with various
build improvements (including VMS) and minor platform-
specific bug fixes (including for HP-UX 11 ia64).
o "threads" upgraded to 1.71
o new thread state information methods: "is_running",
perl v5.12.5 Last change: 2012-11-03 11
"is_detached" and "is_joinable". "list" method
enhanced to return running or joinable threads.
o new thread signal method: "kill"
o added capability to specify thread stack size.
o added capability to control thread exiting behavior.
Added a new "exit" method.
o "threads::shared" upgraded to version 1.27
o smaller and faster implementation that eliminates
one internal structure and the consequent level of
indirection.
o user locks are now stored in a safer manner.
o new function "shared_clone" creates a copy of an
object leaving shared elements as-is and deep-
cloning non-shared elements.
o added new "is_shared" method.
o "Unicode::Normalize" upgraded to version 1.02
o "Unicode::UCD" upgraded to version 0.25
o "warnings" upgraded to version 1.05_01
o "Win32" upgraded to version 0.38
o added new function "GetCurrentProcessId" which
returns the regular Windows process identifier of
the current process, even when called from within a
fork.
o "XSLoader" upgraded to version 0.10
o "XS::APItest" and "XS::Typemap" are for internal use
only and hence no longer installed. Many more tests have
been added to "XS::APItest".
Utility Changes
debugger upgraded to version 1.31
o Andreas Koenig contributed two functions to save and
load the debugger history.
o "NEXT::AUTOLOAD" no longer emits warnings under the
debugger.
o The debugger should now correctly find tty the device on
perl v5.12.5 Last change: 2012-11-03 12
OS X 10.5 and VMS when the program "fork"s.
o LVALUE subs now work inside the debugger.
perlthanks
Perl 5.8.9 adds a new utility perlthanks, which is a variant
of perlbug, but for sending non-bug-reports to the authors
and maintainers of Perl. Getting nothing but bug reports
can become a bit demoralising - we'll see if this changes
things.
perlbug
perlbug now checks if you're reporting about a non-core
module and suggests you report it to the CPAN author
instead.
h2xs
o won't define an empty string as a constant [RT #25366]
o has examples for "h2xs -X"
h2ph
o now attempts to deal sensibly with the difference in
path implications between "" and "<>" quoting in
"#include" statements.
o now generates correct code for "#if defined A || defined
B" [RT #39130]
New Documentation
As usual, the documentation received its share of
corrections, clarifications and other nitfixes. More "" tags
were added for indexing.
perlunitut is a tutorial written by Juerd Waalboer on
Unicode-related terminology and how to correctly handle
Unicode in Perl scripts.
perlunicode is updated in section user defined properties.
perluniintro has been updated in the example of detecting
data that is not valid in particular encoding.
perlcommunity provides an overview of the Perl Community
along with further resources.
CORE documents the pseudo-namespace for Perl's core
routines.
Changes to Existing Documentation
perlglossary adds deprecated modules and features and to be
dropped modules.
perl v5.12.5 Last change: 2012-11-03 13
perlhack has been updated and added resources on smoke
testing.
The Perl FAQs (perlfaq1..perlfaq9) have been updated.
perlcheat is updated with better details on "\w", "\d", and
"\s".
perldebug is updated with information on how to call the
debugger.
perldiag documentation updated with subroutine with an
ampersand on the argument to "exists" and "delete" and also
several terminology updates on warnings.
perlfork documents the limitation of "exec" inside pseudo-
processes.
perlfunc:
o Documentation is fixed in section "caller" and "pop".
o Function "alarm" now mentions "Time::HiRes::ualarm" in
preference to "select".
o Regarding precedence in "-X", filetest operators are the
same as unary operators, but not regarding parsing and
parentheses (spotted by Eirik Berg Hanssen).
o reverse function documentation received scalar context
examples.
perllocale documentation is adjusted for number localization
and "POSIX::setlocale" to fix Debian bug #379463.
perlmodlib is updated with "CPAN::API::HOWTO" and
"Sys::Syslog::win32::Win32"
perlre documentation updated to reflect the differences
between "[[:xxxxx:]]" and "\p{IsXxxxx}" matches. Also added
section on "/g" and "/c" modifiers.
perlreguts describe the internals of the regular expressions
engine. It has been contributed by Yves Orton.
perlrebackslash describes all perl regular expression
backslash and escape sequences.
perlrecharclass describes the syntax and use of character
classes in Perl Regular Expressions.
perl v5.12.5 Last change: 2012-11-03 14
perlrun is updated to clarify on the hash seed
PERL_HASH_SEED. Also more information in options "-x" and
"-u".
perlsub example is updated to use a lexical variable for
"opendir" syntax.
perlvar fixes confusion about real GID $( and effective GID
Perl thread tutorial example is fixed in section "Queues:
Passing Data Around" in perlthrtut and perlothrtut.
perlhack documentation extensively improved by Jarkko
Hietaniemi and others.
perltoot provides information on modifying @UNIVERSAL::ISA.
perlport documentation extended to include different
"kill(-9, ...)" semantics on Windows. It also clearly
states "dump" is not supported on Win32 and cygwin.
INSTALL has been updated and modernised.
Performance Enhancements
o The default since perl 5.000 has been for perl to create
an empty scalar with every new typeglob. The increased
use of lexical variables means that most are now unused.
Thanks to Nicholas Clark's efforts, Perl can now be
compiled with "-DPERL_DONT_CREATE_GVSV" to avoid
creating these empty scalars. This will significantly
decrease the number of scalars allocated for all
configurations, and the number of scalars that need to
be copied for ithread creation. Whilst this option is
binary compatible with existing perl installations, it
does change a long-standing assumption about the
internals, hence it is not enabled by default, as some
third party code may rely on the old behaviour.
We would recommend testing with this configuration on
new deployments of perl, particularly for multi-threaded
servers, to see whether all third party code is
compatible with it, as this configuration may give
useful performance improvements. For existing
installations we would not recommend changing to this
configuration unless thorough testing is performed
before deployment.
o "diagnostics" no longer uses $&, which results in large
speedups for regexp matching in all code using it.
o Regular expressions classes of a single character are
perl v5.12.5 Last change: 2012-11-03 15
now treated the same as if the character had been used
as a literal, meaning that code that uses char-classes
as an escaping mechanism will see a speedup. (Yves
Orton)
o Creating anonymous array and hash references (ie. "[]"
and "{}") now incurs no more overhead than creating an
anonymous list or hash. Nicholas Clark provided changes
with a saving of two ops and one stack push, which was
measured as a slightly better than 5% improvement for
these operations.
o Many calls to "strlen()" have been eliminated, either
because the length was already known, or by adopting or
enhancing APIs that pass lengths. This has been aided by
the adoption of a "my_sprintf()" wrapper, which returns
the correct C89 value - the length of the formatted
string. Previously we could not rely on the return value
of "sprintf()", because on some ancient but extant
platforms it still returns "char *".
o "index" is now faster if the search string is stored in
UTF-8 but only contains characters in the Latin-1 range.
o The Unicode swatch cache inside the regexp engine is now
used. (the lookup had a key mismatch, present since the
initial implementation). [RT #42839]
Installation and Configuration Improvements
There is now Configure support for creating a relocatable
perl tree. If you Configure with "-Duserelocatableinc", then
the paths in @INC (and everything else in %Config) can be
optionally located via the path of the perl executable.
At start time, if any paths in @INC or "Config" that
Configure marked as relocatable (by starting them with
".../"), then they are prefixed the directory of $^X. This
allows the relocation can be configured on a per-directory
basis, although the default with "-Duserelocatableinc" is
that everything is relocated. The initial install is done to
the original configured prefix.
Configuration improvements
Configure is now better at removing temporary files. Tom
Callaway (from RedHat) also contributed patches that
complete the set of flags passed to the compiler and the
linker, in particular that "-fPIC" is now enabled on Linux.
It will also croak when your /dev/null isn't a device.
A new configuration variable "d_pseudofork" has been to
Configure, and is available as $Config{d_pseudofork} in the
perl v5.12.5 Last change: 2012-11-03 16
"Config" module. This distinguishes real "fork" support from
the pseudofork emulation used on Windows platforms.
Config.pod and config.sh are now placed correctly for cross-
compilation.
$Config{useshrplib} is now 'true' rather than 'yes' when
using a shared perl library.
Compilation improvements
Parallel makes should work properly now, although there may
still be problems if "make test" is instructed to run in
parallel.
Many compilation warnings have been cleaned up. A very
stubborn compiler warning in "S_emulate_eaccess()" was
killed after six attempts. g++ support has been tuned,
especially for FreeBSD.
mkppport has been integrated, and all ppport.h files in the
core will now be autogenerated at build time (and removed
during cleanup).
Installation improvements.
installman now works with "-Duserelocatableinc" and
"DESTDIR".
installperl no longer installs:
o static library files of statically linked extensions
when a shared perl library is being used. (They are not
needed. See "Windows" below).
o SIGNATURE and PAUSE*.pub (CPAN files)
o NOTES and PATCHING (ExtUtils files)
o perlld and ld2 (Cygwin files)
Platform Specific Changes
There are improved hints for AIX, Cygwin, DEC/OSF, FreeBSD,
HP/UX, Irix 6 Linux, MachTen, NetBSD, OS/390, QNX, SCO,
Solaris, SunOS, System V Release 5.x (UnixWare 7, OpenUNIX
8), Ultrix, UMIPS, uts and VOS.
FreeBSD
o Drop "-std=c89" and "-ansi" if using "long long" as the
main integral type, else in FreeBSD 6.2 (and perhaps
other releases), system headers do not declare some
functions required by perl.
perl v5.12.5 Last change: 2012-11-03 17
Solaris
o Starting with Solaris 10, we do not want versioned
shared libraries, because those often indicate a private
use only library. These problems could often be
triggered when SUNWbdb (Berkeley DB) was installed.
Hence if Solaris 10 is detected set
"ignore_versioned_solibs=y".
VMS
o Allow IEEE math to be deselected on OpenVMS I64 (but it
remains the default).
o Record IEEE usage in "config.h"
o Help older VMS compilers by using "ccflags" when
building "munchconfig.exe".
o Don't try to build old "Thread" extension on VMS when
"-Duseithreads" has been chosen.
o Passing a raw string of "NaN" to nawk causes a core dump
- so the string has been changed to "*NaN*"
o t/op/stat.t tests will now test hard links on VMS if
they are supported.
Windows
o When using a shared perl library installperl no longer
installs static library files, import library files and
export library files (of statically linked extensions)
and empty bootstrap files (of dynamically linked
extensions). This fixes a problem building PAR-Packer on
Win32 with a debug build of perl.
o Various improvements to the win32 build process,
including support for Visual C++ 2005 Express Edition
(aka Visual C++ 8.x).
o perl.exe will now have an icon if built with MinGW or
Borland.
o Improvements to the perl-static.exe build process.
o Add Win32 makefile option to link all extensions
statically.
o The WinCE directory has been merged into the Win32
directory.
perl v5.12.5 Last change: 2012-11-03 18
o "setlocale" tests have been re-enabled for Windows XP
onwards.
Selected Bug Fixes
Unicode
Many many bugs related to the internal Unicode
implementation (UTF-8) have been fixed. In particular, long
standing bugs related to returning Unicode via "tie",
overloading or $@ are now gone, some of which were never
reported.
"unpack" will internally convert the string back from UTF-8
on numeric types. This is a compromise between the full
consistency now in 5.10, and the current behaviour, which is
often used as a "feature" on string types.
Using ":crlf" and "UTF-16" IO layers together will now work.
Fixed problems with "split", Unicode "/\s+/" and "/ \0/".
Fixed bug RT #40641 - encoding of Unicode characters in
regular expressions.
Fixed a bug where using certain patterns in a regexp led to
a panic. [RT #45337]
Perl no longer segfaults (due to infinite internal
recursion) if the locale's character is not UTF-8 [RT
#41442]:
use open ':locale';
print STDERR "\x{201e}"; # „
PerlIO
Inconsistencies have been fixed in the reference counting
PerlIO uses to keep track of Unix file descriptors, and the
API used by XS code to manage getting and releasing "FILE
*"s
Magic
Several bugs have been fixed in Magic, the internal system
used to implement features such as "tie", tainting and
threads sharing.
"undef @array" on a tied array now correctly calls the
"CLEAR" method.
Some of the bitwise ops were not checking whether their
arguments were magical before using them. [RT #24816]
Magic is no longer invoked twice by the expression "\&$x"
perl v5.12.5 Last change: 2012-11-03 19
A bug with assigning large numbers and tainting has been
resolved. [RT #40708]
A new entry has been added to the MAGIC vtable -
"svt_local". This is used when copying magic to the new
value during "local", allowing certain problems with
localising shared variables to be resolved.
For the implementation details, see "Magic Virtual Tables"
in perlguts.
Reblessing overloaded objects now works
Internally, perl object-ness is on the referent, not the
reference, even though methods can only be called via a
reference. However, the original implementation of
overloading stored flags related to overloading on the
reference, relying on the flags being copied when the
reference was copied, or set at the creation of a new
reference. This manifests in a bug - if you rebless an
object from a class that has overloading, into one that does
not, then any other existing references think that they
(still) point to an overloaded object, choose these C code
paths, and then throw errors. Analogously, blessing into an
overloaded class when other references exist will result in
them not using overloading.
The implementation has been fixed for 5.10, but this fix
changes the semantics of flag bits, so is not binary
compatible, so can't be applied to 5.8.9. However, 5.8.9
has a work-around that implements the same bug fix. If the
referent has multiple references, then all the other
references are located and corrected. A full search is
avoided whenever possible by scanning lexicals outwards from
the current subroutine, and the argument stack.
A certain well known Linux vendor applied incomplete
versions of this bug fix to their /usr/bin/perl and then
prematurely closed bug reports about performance issues
without consulting back upstream. This not being enough,
they then proceeded to ignore the necessary fixes to these
unreleased changes for 11 months, until massive pressure was
applied by their long-suffering paying customers, catalysed
by the failings being featured on a prominent blog and
Slashdot.
"strict" now propagates correctly into string evals
Under 5.8.8 and earlier:
$ perl5.8.8 -e 'use strict; eval "use foo bar" or die $@'
Can't locate foo.pm in @INC (@INC contains: ... .) at (eval 1) line 2.
BEGIN failed--compilation aborted at (eval 1) line 2.
perl v5.12.5 Last change: 2012-11-03 20
Under 5.8.9 and later:
$ perl5.8.9 -e 'use strict; eval "use foo bar" or die $@'
Bareword "bar" not allowed while "strict subs" in use at (eval 1) line 1.
This may cause problems with programs that parse the error
message and rely on the buggy behaviour.
Other fixes
o The tokenizer no longer treats "=cute" (and other words
beginning with "=cut") as a synonym for "=cut".
o Calling "CORE::require"
"CORE::require" and "CORE::do" were always parsed as
"require" and "do" when they were overridden. This is
now fixed.
o Stopped memory leak on long /etc/groups entries.
o "while (my $x ...) { ...; redo }" shouldn't "undef $x".
In the presence of "my" in the conditional of a
"while()", "until()", or "for(;;)" loop, we now add an
extra scope to the body so that "redo" doesn't "undef"
the lexical.
o The "encoding" pragma now correctly ignores anything
following an "@" character in the "LC_ALL" and "LANG"
environment variables. [RT # 49646]
o A segfault observed with some gcc 3.3 optimisations is
resolved.
o A possible segfault when "unpack" used in scalar context
with "()" groups is resolved. [RT #50256]
o Resolved issue where $! could be changed by a signal
handler interrupting a "system" call.
o Fixed bug RT #37886, symbolic deferencing was allowed in
the argument of "defined" even under the influence of
"use strict 'refs'".
o Fixed bug RT #43207, where "lc"/"uc" inside "sort"
affected the return value.
o Fixed bug RT #45607, where "*{"BONK"} = \&{"BONK"}"
didn't work correctly.
o Fixed bug RT #35878, croaking from a XSUB called via
"goto &xsub" corrupts perl internals.
perl v5.12.5 Last change: 2012-11-03 21
o Fixed bug RT #32539, DynaLoader.o is moved into
libperl.so to avoid the need to statically link
DynaLoader into the stub perl executable. With this
libperl.so provides everything needed to get a
functional embedded perl interpreter to run.
o Fix bug RT #36267 so that assigning to a tied hash
doesn't change the underlying hash.
o Fix bug RT #6006, regexp replaces using large
replacement variables fail some of the time, i.e. when
substitution contains something like "${10}" (note the
bracket) instead of just $10.
o Fix bug RT #45053, "Perl_newCONSTSUB()" is now thread
safe.
Platform Specific Fixes
Darwin / MacOS X
o Various improvements to 64 bit builds.
o Mutex protection added in "PerlIOStdio_close()" to avoid
race conditions. Hopefully this fixes failures in the
threads tests free.t and blocks.t.
o Added forked terminal support to the debugger, with the
ability to update the window title.
OS/2
o A build problem with specifying "USE_MULTI" and
"USE_ITHREADS" but without "USE_IMP_SYS" has been fixed.
o "OS2::REXX" upgraded to version 1.04
Tru64
o Aligned floating point build policies for cc and gcc.
RedHat Linux
o Revisited a patch from 5.6.1 for RH7.2 for Intel's icc
[RT #7916], added an additional check for
$Config{gccversion}.
Solaris/i386
o Use "-DPTR_IS_LONG" when using 64 bit integers
VMS
perl v5.12.5 Last change: 2012-11-03 22
o Fixed "PerlIO::Scalar" in-memory file record-style
reads.
o pipe shutdown at process exit should now be more robust.
o Bugs in VMS exit handling tickled by "Test::Harness"
2.64 have been fixed.
o Fix "fcntl()" locking capability test in configure.com.
o Replaced "shrplib='define'" with "useshrplib='true'" on
VMS.
Windows
o "File::Find" used to fail when the target directory is a
bare drive letter and "no_chdir" is 1 (the default is
0). [RT #41555]
o The process id is no longer truncated to 16 bits on some
Windows platforms (
http://bugs.activestate.com/show_bug.cgi?id=72443 )
o Fixed bug RT #54828 in perlio.c where calling "binmode"
on Win32 and Cgywin may cause a segmentation fault.
Smaller fixes
o It is now possible to overload "eq" when using
"nomethod".
o Various problems using "overload" with 64 bit integers
corrected.
o The reference count of "PerlIO" file descriptors is now
correctly handled.
o On VMS, escaped dots will be preserved when converted to
Unix syntax.
o "keys %+" no longer throws an 'ambiguous' warning.
o Using "#!perl -d" could trigger an assertion, which has
been fixed.
o Don't stringify tied code references in @INC when
calling "require".
o Code references in @INC report the correct file name
when "__FILE__" is used.
perl v5.12.5 Last change: 2012-11-03 23
o Width and precision in sprintf didn't handle characters
above 255 correctly. [RT #40473]
o List slices with indices out of range now work more
consistently. [RT #39882]
o A change introduced with perl 5.8.1 broke the parsing of
arguments of the form "-foo=bar" with the "-s" on the
<#!> line. This has been fixed. See
http://bugs.activestate.com/show_bug.cgi?id=43483
o "tr///" is now threadsafe. Previously it was storing a
swash inside its OP, rather than in a pad.
o pod2html labels anchors more consistently and handles
nested definition lists better.
o "threads" cleanup veto has been extended to include
"perl_free()" and "perl_destruct()"
o On some systems, changes to $ENV{TZ} would not always be
respected by the underlying calls to "localtime_r()".
Perl now forces the inspection of the environment on
these systems.
o The special variable $^R is now more consistently set
when executing regexps using the "(?{...})" construct.
In particular, it will still be set even if
backreferences or optional sub-patterns "(?:...)?" are
used.
New or Changed Diagnostics
panic: sv_chop %s
This new fatal error occurs when the C routine
"Perl_sv_chop()" was passed a position that is not within
the scalar's string buffer. This is caused by buggy XS code,
and at this point recovery is not possible.
Maximal count of pending signals (%s) exceeded
This new fatal error occurs when the perl process has to
abort due to too many pending signals, which is bound to
prevent perl from being able to handle further incoming
signals safely.
panic: attempt to call %s in %s
This new fatal error occurs when the ACL version file test
operator is used where it is not available on the current
platform. Earlier checks mean that it should never be
possible to get this.
FETCHSIZE returned a negative value
New error indicating that a tied array has claimed to have a
perl v5.12.5 Last change: 2012-11-03 24
negative number of elements.
Can't upgrade %s (%d) to %d
Previously the internal error from the SV upgrade code was
the less informative Can't upgrade that kind of scalar. It
now reports the current internal type, and the new type
requested.
%s argument is not a HASH or ARRAY element or a subroutine
This error, thrown if an invalid argument is provided to
"exists" now correctly includes "or a subroutine". [RT
#38955]
Cannot make the non-overridable builtin %s fatal
This error in "Fatal" previously did not show the name of
the builtin in question (now represented by %s above).
Unrecognized character '%s' in column %d
This error previously did not state the column.
Offset outside string
This can now also be generated by a "seek" on a file handle
using "PerlIO::scalar".
Invalid escape in the specified encoding in regexp; marked by
<-- HERE in m/%s/
New error, introduced as part of the fix to RT #40641 to
handle encoding of Unicode characters in regular expression
comments.
Your machine doesn't support dump/undump.
A more informative fatal error issued when calling "dump" on
Win32 and Cygwin. (Given that the purpose of "dump" is to
abort with a core dump, and core dumps can't be produced on
these platforms, this is more useful than silently exiting.)
Changed Internals
The perl sources can now be compiled with a C++ compiler
instead of a C compiler. A necessary implementation details
is that under C++, the macro "XS" used to define XSUBs now
includes an "extern "C"" definition. A side effect of this
is that C++ code that used the construction
typedef XS(SwigPerlWrapper);
now needs to be written
typedef XSPROTO(SwigPerlWrapper);
using the new "XSPROTO" macro, in order to compile. C
extensions are unaffected, although C extensions are
encouraged to use "XSPROTO" too. This change was present in
perl v5.12.5 Last change: 2012-11-03 25
the 5.10.0 release of perl, so any actively maintained code
that happened to use this construction should already have
been adapted. Code that needs changing will fail with a
compilation error.
"set" magic on localizing/assigning to a magic variable will
now only trigger for container magics, i.e. it will for %ENV
or %SIG but not for $#array.
The new API macro "newSVpvs()" can be used in place of
constructions such as "newSVpvn("ISA", 3)". It takes a
single string constant, and at C compile time determines its
length.
The new API function "Perl_newSV_type()" can be used as a
more efficient replacement of the common idiom
sv = newSV(0);
sv_upgrade(sv, type);
Similarly "Perl_newSVpvn_flags()" can be used to combine
"Perl_newSVpv()" with "Perl_sv_2mortal()" or the equivalent
"Perl_sv_newmortal()" with "Perl_sv_setpvn()"
Two new macros "mPUSHs()" and "mXPUSHs()" are added, to make
it easier to push mortal SVs onto the stack. They were then
used to fix several bugs where values on the stack had not
been mortalised.
A "Perl_signbit()" function was added to test the sign of an
"NV". It maps to the system one when available.
"Perl_av_reify()", "Perl_lex_end()", "Perl_mod()",
"Perl_op_clear()", "Perl_pop_return()", "Perl_qerror()",
"Perl_setdefout()", "Perl_vivify_defelem()" and
"Perl_yylex()" are now visible to extensions. This was
required to allow "Data::Alias" to work on Windows.
"Perl_find_runcv()" is now visible to perl core extensions.
This was required to allow "Sub::Current" to work on
Windows.
"ptr_table*" functions are now available in unthreaded perl.
"Storable" takes advantage of this.
There have been many small cleanups made to the internals.
In particular, "Perl_sv_upgrade()" has been simplified
considerably, with a straight-through code path that uses
"memset()" and "memcpy()" to initialise the new body, rather
than assignment via multiple temporary variables. It has
also benefited from simplification and de-duplication of the
arena management code.
perl v5.12.5 Last change: 2012-11-03 26
A lot of small improvements in the code base were made due
to reports from the Coverity static code analyzer.
Corrected use and documentation of "Perl_gv_stashpv()",
"Perl_gv_stashpvn()", "Perl_gv_stashsv()" functions (last
parameter is a bitmask, not boolean).
"PERL_SYS_INIT", "PERL_SYS_INIT3" and "PERL_SYS_TERM" macros
have been changed into functions.
"PERLSYS_TERM" no longer requires a context.
"PerlIO_teardown()" is now called without a context, and
debugging output in this function has been disabled because
that required that an interpreter was present, an invalid
assumption at termination time.
All compile time options which affect binary compatibility
have been grouped together into a global variable
("PL_bincompat_options").
The values of "PERL_REVISION", "PERL_VERSION" and
"PERL_SUBVERSION" are now baked into global variables (and
hence into any shared perl library). Additionally under
"MULTIPLICITY", the perl executable now records the size of
the interpreter structure (total, and for this version).
Coupled with "PL_bincompat_options" this will allow 5.8.10
(and later), when compiled with a shared perl library, to
perform sanity checks in "main()" to verify that the shared
library is indeed binary compatible.
Symbolic references can now have embedded NULs. The new
public function "Perl_get_cvn_flags()" can be used in
extensions if you have to handle them.
Macro cleanups
The core code, and XS code in ext that is not dual-lived on
CPAN, no longer uses the macros "PL_na", "NEWSV()",
"Null()", "Nullav", "Nullcv", "Nullhv", "Nullhv" etc. Their
use is discouraged in new code, particularly "PL_na", which
is a small performance hit.
New Tests
Many modules updated from CPAN incorporate new tests. Some
core specific tests have been added:
ext/DynaLoader/t/DynaLoader.t
Tests for the "DynaLoader" module.
t/comp/fold.t
Tests for compile-time constant folding.
t/io/pvbm.t
perl v5.12.5 Last change: 2012-11-03 27
Tests incorporated from 5.10.0 which check that there is
no unexpected interaction between the internal types
"PVBM" and "PVGV".
t/lib/proxy_constant_subs.t
Tests for the new form of constant subroutines.
t/op/attrhand.t
Tests for "Attribute::Handlers".
t/op/dbm.t
Tests for "dbmopen".
t/op/inccode-tie.t
Calls all tests in t/op/inccode.t after first tying
@INC.
t/op/incfilter.t
Tests for source filters returned from code references
in @INC.
t/op/kill0.t
Tests for RT #30970.
t/op/qrstack.t
Tests for RT #41484.
t/op/qr.t
Tests for the "qr//" construct.
t/op/regexp_qr_embed.t
Tests for the "qr//" construct within another regexp.
t/op/regexp_qr.t
t/op/rxcode.t
Tests for RT #32840.
t/op/studytied.t
Tests for "study" on tied scalars.
t/op/substT.t
Tests for "subst" run under "-T" mode.
t/op/symbolcache.t
Tests for "undef" and "delete" on stash entries that are
bound to subroutines or methods.
t/op/upgrade.t
Tests for "Perl_sv_upgrade()".
perl v5.12.5 Last change: 2012-11-03 28
t/mro/package_aliases.t
MRO tests for "isa" and package aliases.
t/pod/twice.t
Tests for calling "Pod::Parser" twice.
t/run/cloexec.t
Tests for inheriting file descriptors across "exec"
(close-on-exec).
t/uni/cache.t
Tests for the UTF-8 caching code.
t/uni/chr.t
Test that strange encodings do not upset
"Perl_pp_chr()".
t/uni/greek.t
Tests for RT #40641.
t/uni/latin2.t
t/uni/overload.t
Tests for returning Unicode from overloaded values.
t/uni/tie.t
Tests for returning Unicode from tied variables.
Known Problems
There are no known new bugs.
However, programs that rely on bugs that have been fixed
will have problems. Also, many bug fixes present in 5.10.0
can't be back-ported to the 5.8.x branch, because they
require changes that are binary incompatible, or because the
code changes are too large and hence too risky to
incorporate.
We have only limited volunteer labour, and the maintenance
burden is getting increasingly complex. Hence this will be
the last significant release of the 5.8.x series. Any future
releases of 5.8.x will likely only be to deal with security
issues, and platform build failures. Hence you should look
to migrating to 5.10.x, if you have not started already.
Alternatively, if business requirements constrain you to
continue to use 5.8.x, you may wish to consider commercial
support from firms such as ActiveState.
Platform Specific Notes
Win32
"readdir()", "cwd()", $^X and @INC now use the alternate
perl v5.12.5 Last change: 2012-11-03 29
(short) filename if the long name is outside the current
codepage (Jan Dubois).
Updated Modules
o "Win32" upgraded to version 0.38. Now has a documented
'WinVista' response from "GetOSName" and support for
Vista's privilege elevation in "IsAdminUser". Support
for Unicode characters in path names. Improved cygwin
and Win64 compatibility.
o "Win32API" updated to 0.1001_01
o "killpg()" support added to "MSWin32" (Jan Dubois).
o "File::Spec::Win32" upgraded to version 3.2701
OS/2
Updated Modules
o "OS2::Process" upgraded to 1.03
Ilya Zakharevich has added and documented several
"Window*" and "Clipbrd*" functions.
o "OS2::REXX::DLL", "OS2::REXX" updated to version 1.03
VMS
Updated Modules
o "DCLsym" upgraded to version 1.03
o "Stdio" upgraded to version 2.4
o "VMS::XSSymSet" upgraded to 1.1.
Obituary
Nick Ing-Simmons, long time Perl hacker, author of the "Tk"
and "Encode" modules, perlio.c in the core, and 5.003_02
pumpking, died of a heart attack on 25th September 2006. He
will be missed.
Acknowledgements
Some of the work in this release was funded by a TPF grant.
Steve Hay worked behind the scenes working out the causes of
the differences between core modules, their CPAN releases,
and previous core releases, and the best way to rectify
them. He doesn't want to do it again. I know this feeling,
and I'm very glad he did it this time, instead of me.
perl v5.12.5 Last change: 2012-11-03 30
Paul Fenwick assembled a team of 18 volunteers, who broke
the back of writing this document. In particular, Bradley
Dean, Eddy Tan, and Vincent Pit provided half the team's
contribution.
Schwern verified the list of updated module versions,
correcting quite a few errors that I (and everyone else) had
missed, both wrongly stated module versions, and changed
modules that had not been listed.
The crack Berlin-based QA team of Andreas Koenig and Slaven
Rezic tirelessly re-built snapshots, tested most everything
CPAN against them, and then identified the changes
responsible for any module regressions, ensuring that
several show-stopper bugs were stomped before the first
release candidate was cut.
The other core committers contributed most of the changes,
and applied most of the patches sent in by the hundreds of
contributors listed in AUTHORS.
And obviously, Larry Wall, without whom we wouldn't have
Perl.
Reporting Bugs
If you find what you think is a bug, you might check the
articles recently posted to the comp.lang.perl.misc
newsgroup and the perl bug database at http://bugs.perl.org.
There may also be information at http://www.perl.org, the
Perl Home Page.
If you believe you have an unreported bug, please run the
perlbug program included with your release. Be sure to trim
your bug down to a tiny but sufficient test case. Your bug
report, along with the output of "perl -V", will be sent off
to perlbug@perl.org to be analysed by the Perl porting team.
You can browse and search the Perl 5 bugs at
http://bugs.perl.org/
If the bug you are reporting has security implications,
which make it inappropriate to send to a publicly archived
mailing list, then please send it to
perl5-security-report@perl.org. This points to a closed
subscription unarchived mailing list, which includes all the
core committers, who be able to help assess the impact of
issues, figure out a resolution, and help co-ordinate the
release of patches to mitigate or fix the problem across all
platforms on which Perl is supported. Please only use this
address for security issues in the Perl core, not for
modules independently distributed on CPAN.
perl v5.12.5 Last change: 2012-11-03 31
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | runtime/perl-512 |
|Stability | Uncommitted |
SEE ALSO
The Changes file for exhaustive details on what changed.
The INSTALL file for how to build Perl.
The README file for general stuff.
The Artistic and Copying files for copyright information.
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://www.cpan.org/src/5.0/perl-5.12.5.tar.bz2
Further information about this software can be found on the
open source community website at http://www.perl.org/.
perl v5.12.5 Last change: 2012-11-03 32
