man pages section 1: User Commands
Exit Print View
Updated: July 2014
git-web--browse (1)
Name
git-web--browse - git helper script to launch a web browser
Synopsis
git web--browse [OPTIONS] URL/FILE ...
Description
Git Manual                                     GIT-WEB--BROWSE(1)
NAME
SYNOPSIS
DESCRIPTION
     This script tries, as much as possible, to display the URLs
     and FILEs that are passed as arguments, as HTML pages in new
     tabs on an already opened web browser.
     The following browsers (or commands) are currently
     supported:
     o   firefox (this is the default under X Window when not
         using KDE)
     o   iceweasel
     o   seamonkey
     o   iceape
     o   chromium (also supported as chromium-browser)
     o   google-chrome (also supported as chrome)
     o   konqueror (this is the default under KDE, see Note about
         konqueror below)
     o   opera
     o   w3m (this is the default outside graphical environments)
     o   elinks
     o   links
     o   lynx
     o   dillo
     o   open (this is the default under Mac OS X GUI)
     o   start (this is the default under MinGW)
     Custom commands may also be specified.
OPTIONS
     -b <browser>, --browser=<browser>
         Use the specified browser. It must be in the list of
Git 1.7.9.2          Last change: 02/22/2012                    1
         supported browsers.
     -t <browser>, --tool=<browser>
         Same as above.
     -c <conf.var>, --config=<conf.var>
         CONF.VAR is looked up in the git config files. If it's
         set, then its value specifies the browser that should be
         used.
CONFIGURATION VARIABLES
  CONF.VAR (from -c option) and web.browser
     The web browser can be specified using a configuration
     variable passed with the -c (or --config) command line
     option, or the web.browser configuration variable if the
     former is not used.
  browser.<tool>.path
     You can explicitly provide a full path to your preferred
     browser by setting the configuration variable
     browser.<tool>.path. For example, you can configure the
     absolute path to firefox by setting browser.firefox.path.
     Otherwise, git web--browse assumes the tool is available in
     PATH.
  browser.<tool>.cmd
     When the browser, specified by options or configuration
     variables, is not among the supported ones, then the
     corresponding browser.<tool>.cmd configuration variable will
     be looked up. If this variable exists then git web--browse
     will treat the specified tool as a custom command and will
     use a shell eval to run the command with the URLs passed as
     arguments.
NOTE ABOUT KONQUEROR
     When konqueror is specified by a command line option or a
     configuration variable, we launch kfmclient to try to open
     the HTML man page on an already opened konqueror in a new
     tab if possible.
     For consistency, we also try such a trick if
     browser.konqueror.path is set to something like
     A_PATH_TO/konqueror. That means we will try to launch
     A_PATH_TO/kfmclient instead.
     If you really want to use konqueror, then you can use
     something like the following:
                 [web]
                         browser = konq
                 [browser "konq"]
Git 1.7.9.2          Last change: 02/22/2012                    2
                         cmd = A_PATH_TO/konqueror
  Note about git-config --global
     Note that these configuration variables should probably be
     set using the --global flag, for example like this:
         $ git config --global web.browser firefox
     as they are probably more user specific than repository
     specific. See git-config(1) for more information about this.
GIT
     Part of the git(1) suite
ATTRIBUTES
     See attributes(5) for descriptions of the following
     attributes:
     |ATTRIBUTE TYPE |     ATTRIBUTE VALUE      |
     |Availability   | developer/versioning/git |
     |Stability      | Uncommitted              |
NOTES
     This software was built from source available at
     https://java.net/projects/solaris-userland.  The original
     community source was downloaded from  http://git-
     core.googlecode.com/files/git-1.7.9.2.tar.gz
     Further information about this software can be found on the
     open source community website at http://git-scm.com/.
Git 1.7.9.2          Last change: 02/22/2012                    3
