man pages section 1: User Commands
Exit Print View
Updated: July 2014
rsync (1)
Name
rsync - copying tool
Synopsis
Local:  rsync [OPTION...] SRC... [DEST]
Access via remote shell:
Pull: rsync [OPTION...] [USER@]HOST:SRC... [DEST]
Push: rsync [OPTION...] SRC... [USER@]HOST:DEST
Access via rsync daemon:
Pull: rsync [OPTION...] [USER@]HOST::SRC... [DEST]
rsync [OPTION...] rsync://[USER@]HOST[:PORT]/SRC... [DEST]
Push: rsync [OPTION...] SRC... [USER@]HOST::DEST
rsync [OPTION...] SRC... rsync://[USER@]HOST[:PORT]/DEST
Usages with just one SRC arg and no DEST arg will  list  the
source files instead of copying.
Description
User Commands                                            rsync(1)
NAME
     rsync  -  a fast, versatile, remote (and local) file-copying
     tool
SYNOPSIS
DESCRIPTION
     Rsync  is  a fast and extraordinarily versatile file copying
     tool.  It can copy locally, to/from another  host  over  any
     remote shell, or to/from a remote rsync daemon.  It offers a
     large number of options that control  every  aspect  of  its
     behavior  and  permit very flexible specification of the set
     of files to be copied.  It is famous for its  delta-transfer
     algorithm,  which  reduces  the amount of data sent over the
     network by sending only the differences between  the  source
     files  and  the existing files in the destination.  Rsync is
     widely used for backups and mirroring  and  as  an  improved
     copy command for everyday use.
     Rsync finds files that need to be transferred using a "quick
     check" algorithm (by default) that looks for files that have
     changed  in  size  or in last-modified time.  Any changes in
     the other preserved attributes (as requested by options) are
     made  on  the destination file directly when the quick check
     indicates that the file's data does not need to be  updated.
     Some of the additional features of rsync are:
     o    support for copying links, devices, owners, groups, and
          permissions
     o    exclude and exclude-from options similar to GNU tar
     o    a CVS exclude mode for ignoring the same files that CVS
          would ignore
     o    can  use any transparent remote shell, including ssh or
SunOS 5.11           Last change: 28 Sep 2013                   1
          rsh
     o    does not require super-user privileges
     o    pipelining of file transfers to minimize latency costs
     o    support for anonymous or  authenticated  rsync  daemons
          (ideal for mirroring)
GENERAL
     Rsync  copies  files  either  to  or  from a remote host, or
     locally on the current host (it  does  not  support  copying
     files between two remote hosts).
     There  are  two different ways for rsync to contact a remote
     system: using a remote-shell program as the transport  (such
     as  ssh  or  rsh) or contacting an rsync daemon directly via
     TCP.  The remote-shell transport is used whenever the source
     or  destination  path  contains a single colon (:) separator
     after a host  specification.   Contacting  an  rsync  daemon
     directly  happens  when  the source or destination path con-
     tains a double colon (::) separator after a host  specifica-
     tion,  OR  when  an  rsync:// URL is specified (see also the
     "USING RSYNC-DAEMON FEATURES VIA A REMOTE-SHELL  CONNECTION"
     section for an exception to this latter rule).
     As a special case, if a single source arg is specified with-
     out a destination, the files are listed in an output  format
     similar to "ls -l".
     As expected, if neither the source or destination path spec-
     ify a remote host, the copy occurs  locally  (see  also  the
     --list-only option).
     Rsync  refers  to  the  local  side  as the "client" and the
     remote side as the "server".  Don't confuse "server" with an
     rsync  daemon  --  a daemon is always a server, but a server
     can be either a daemon or a remote-shell spawned process.
SETUP
     See the file README for installation instructions.
     Once installed, you can use rsync to any  machine  that  you
     can  access via a remote shell (as well as some that you can
     access using the rsync daemon-mode  protocol).   For  remote
     transfers,  a  modern rsync uses ssh for its communications,
     but it may have been configured to use  a  different  remote
     shell by default, such as rsh or remsh.
     You  can  also  specify any remote shell you like, either by
     using  the  -e  command  line  option,  or  by  setting  the
SunOS 5.11           Last change: 28 Sep 2013                   2
     RSYNC_RSH environment variable.
     Note  that  rsync  must  be installed on both the source and
     destination machines.
USAGE
     You use rsync in the same way you use rcp. You must  specify
     a source and a destination, one of which may be remote.
     Perhaps  the  best  way  to  explain the syntax is with some
     examples:
          rsync -t *.c foo:src/
     This would transfer all files matching the pattern *.c  from
     the  current  directory  to the directory src on the machine
     foo. If any of the files already exist on the remote  system
     then  the rsync remote-update protocol is used to update the
     file by sending only the differences. See  the  tech  report
     for details.
          rsync -avz foo:src/bar /data/tmp
     This would recursively transfer all files from the directory
     src/bar on the machine foo into the /data/tmp/bar  directory
     on the local machine. The files are transferred in "archive"
     mode,  which   ensures   that   symbolic   links,   devices,
     attributes,  permissions,  ownerships, etc. are preserved in
     the transfer.  Additionally, compression  will  be  used  to
     reduce the size of data portions of the transfer.
          rsync -avz foo:src/bar/ /data/tmp
     A  trailing  slash  on  the  source changes this behavior to
     avoid creating an additional directory level at the destina-
     tion.   You can think of a trailing / on a source as meaning
     "copy the contents of this directory" as  opposed  to  "copy
     the  directory by name", but in both cases the attributes of
     the containing directory are transferred to  the  containing
     directory  on  the destination.  In other words, each of the
     following commands copies the files in the same way, includ-
     ing their setting of the attributes of /dest/foo:
          rsync -av /src/foo /dest
          rsync -av /src/foo/ /dest/foo
     Note  also  that  host and module references don't require a
     trailing  slash  to  copy  the  contents  of   the   default
SunOS 5.11           Last change: 28 Sep 2013                   3
     directory.   For  example,  both  of  these  copy the remote
     directory's contents into "/dest":
          rsync -av host: /dest
          rsync -av host::module /dest
     You can also use rsync in local-only mode,  where  both  the
     source and destination don't have a ':' in the name. In this
     case it behaves like an improved copy command.
     Finally, you can list all the (listable)  modules  available
     from  a  particular  rsync  daemon by leaving off the module
     name:
          rsync somehost.mydomain.com::
     See the following section for more details.
ADVANCED USAGE
     The syntax for requesting multiple files from a remote  host
     is  done  by  specifying  additional remote-host args in the
     same style as the first, or with the hostname omitted.   For
     instance, all these work:
          rsync -av host:file1 :file2 host:file{3,4} /dest/
          rsync  -av  host::modname/file{1,2} host::modname/file3
          /dest/
          rsync -av host::modname/file1 ::modname/file{3,4}
     Older versions of rsync required using quoted spaces in  the
     SRC, like these examples:
          rsync -av host:'dir1/file1 dir2/file2' /dest
          rsync   host::'modname/dir1/file1   modname/dir2/file2'
          /dest
     This word-splitting still works (by default) in  the  latest
     rsync, but is not as easy to use as the first method.
     If you need to transfer a filename that contains whitespace,
     you can either specify the --protect-args  (-s)  option,  or
     you'll  need  to  escape  the  whitespace  in a way that the
     remote shell will understand.  For instance:
          rsync -av host:'file\ name\ with\ spaces' /dest
SunOS 5.11           Last change: 28 Sep 2013                   4
CONNECTING TO AN RSYNC DAEMON
     It is also possible to use rsync without a remote  shell  as
     the  transport.  In this case you will directly connect to a
     remote rsync daemon, typically using TCP  port  873.   (This
     obviously  requires  the  daemon to be running on the remote
     system, so refer to the STARTING AN RSYNC DAEMON  TO  ACCEPT
     CONNECTIONS section below for information on that.)
     Using  rsync  in  this  way  is  the same as using it with a
     remote shell except that:
     o    you either use a double colon :: instead  of  a  single
          colon  to  separate  the hostname from the path, or you
          use an rsync:// URL.
     o    the first word of the "path" is actually a module name.
     o    the  remote  daemon may print a message of the day when
          you connect.
     o    if you specify no path name on the remote  daemon  then
          the  list  of  accessible  paths  on the daemon will be
          shown.
     o    if you specify no local destination then a  listing  of
          the specified files on the remote daemon is provided.
     o    you must not specify the --rsh (-e) option.
     An  example  that  copies  all  the files in a remote module
     named "src":
         rsync -av host::src /dest
     Some modules on the remote daemon  may  require  authentica-
     tion.  If  so,  you  will receive a password prompt when you
     connect. You can avoid the password prompt  by  setting  the
     environment variable RSYNC_PASSWORD to the password you want
     to use or using the --password-file option. This may be use-
     ful when scripting rsync.
     WARNING:  On  some systems environment variables are visible
     to all users. On those systems using --password-file is rec-
     ommended.
     You  may establish the connection via a web proxy by setting
     the environment variable RSYNC_PROXY to a hostname:port pair
     pointing to your web proxy.  Note that your web proxy's con-
     figuration must support proxy connections to port 873.
SunOS 5.11           Last change: 28 Sep 2013                   5
     You may also establish a daemon connection using  a  program
     as  a  proxy  by setting the environment variable RSYNC_CON-
     NECT_PROG to the commands you wish to run in place of making
     a  direct  socket  connection.   The  string may contain the
     escape "%H" to represent the hostname specified in the rsync
     command  (so  use  "%%"  if  you  need  a single "%" in your
     string).  For example:
       export RSYNC_CONNECT_PROG='ssh proxyhost nc %H 873'
       rsync -av targethost1::module/src/ /dest/
       rsync -av rsync:://targethost2/module/src/ /dest/
     The command specified above uses ssh to run nc (netcat) on a
     proxyhost,  which  forwards  all data to port 873 (the rsync
     daemon) on the targethost (%H).
     It is sometimes useful to use various features of  an  rsync
     daemon (such as named modules) without actually allowing any
     new socket connections into a system  (other  than  what  is
     already  required to allow remote-shell access).  Rsync sup-
     ports connecting to a host using a  remote  shell  and  then
     spawning  a  single-use "daemon" server that expects to read
     its config file in the home dir of the  remote  user.   This
     can  be  useful if you want to encrypt a daemon-style trans-
     fer's data, but since the daemon is started up fresh by  the
     remote  user,  you  may  not be able to use features such as
     chroot or change the uid used by the daemon.   (For  another
     way to encrypt a daemon transfer, consider using ssh to tun-
     nel a local port to a remote machine and configure a  normal
     rsync  daemon  on that remote host to only allow connections
     from "localhost".)
     From  the  user's  perspective,  a  daemon  transfer  via  a
     remote-shell  connection  uses  nearly the same command-line
     syntax as a normal  rsync-daemon  transfer,  with  the  only
     exception  being  that  you  must  explicitly set the remote
     shell program on the  command-line  with  the  --rsh=COMMAND
     option.   (Setting the RSYNC_RSH in the environment will not
     turn on this functionality.)  For example:
         rsync -av --rsh=ssh host::module /dest
     If you need to specify a different remote-shell  user,  keep
     in mind that the user@ prefix in front of the host is speci-
     fying the rsync-user  value  (for  a  module  that  requires
     user-based  authentication).   This means that you must give
     the  '-l  user'  option   to   ssh   when   specifying   the
     remote-shell, as in this example that uses the short version
     of the --rsh option:
SunOS 5.11           Last change: 28 Sep 2013                   6
         rsync -av -e "ssh -l ssh-user" rsync-user@host::module /dest
     The  "ssh-user"  will  be  used  at  the  ssh   level;   the
     "rsync-user" will be used to log-in to the "module".
STARTING AN RSYNC DAEMON TO ACCEPT CONNECTIONS
     WARNING:  Daemon  mode  does  not  participate  in  the core
     Solaris security policies, including  Authentication,  limit
     of privileges, Audit and Audit of any subprocessing.
     In  order  to  connect to an rsync daemon, the remote system
     needs to have a daemon already running (or it needs to  have
     configured something like inetd to spawn an rsync daemon for
     incoming connections on a particular port).  For full infor-
     mation  on how to start a daemon that will handling incoming
     socket connections, see the rsyncd.conf(5) man page --  that
     is  the config file for the daemon, and it contains the full
     details for how to run the daemon (including stand-alone and
     inetd configurations).
     If  you're  using one of the remote-shell transports for the
     transfer, there is no need to manually start an  rsync  dae-
     mon.
SORTED TRANSFER ORDER
     Rsync always sorts the specified filenames into its internal
     transfer list.  This handles the  merging  together  of  the
     contents  of identically named directories, makes it easy to
     remove duplicate filenames, and may confuse someone when the
     files  are  transferred  in  a different order than what was
     given on the command-line.
     If you need a particular file to  be  transferred  prior  to
     another,  either  separate  the  files  into different rsync
     calls, or  consider  using  --delay-updates  (which  doesn't
     affect  the  sorted  transfer order, but does make the final
     file-updating phase happen much more rapidly).
EXAMPLES
     Here are some examples of how I use rsync.
     To backup my wife's home directory, which consists of  large
     MS Word files and mail folders, I use a cron job that runs
          rsync -Cavz . arvidsjaur:backup
     each night over a PPP connection to a duplicate directory on
     my machine "arvidsjaur".
SunOS 5.11           Last change: 28 Sep 2013                   7
     To synchronize my samba source trees  I  use  the  following
     Makefile targets:
         get:
                 rsync -avuzb --exclude '*~' samba:samba/ .
         put:
                 rsync -Cavuzb . samba:samba/
         sync: get put
     this allows me to sync with a CVS directory at the other end
     of the connection. I then do CVS operations  on  the  remote
     machine,  which saves a lot of time as the remote CVS proto-
     col isn't very efficient.
     I mirror a directory between my "old" and  "new"  ftp  sites
     with the command:
     rsync    -az    -e    ssh   --delete   ~ftp/pub/samba   nim-
     bus:"~ftp/pub/tridge"
     This is launched from cron every few hours.
OPTIONS SUMMARY
     Here is a short summary of the options available  in  rsync.
     Please  refer  to  the detailed description below for a com-
     plete description.
      -v, --verbose               increase verbosity
          --info=FLAGS            fine-grained informational verbosity
          --debug=FLAGS           fine-grained debug verbosity
          --msgs2stderr           special output handling for debugging
      -q, --quiet                 suppress non-error messages
          --no-motd               suppress daemon-mode MOTD (see caveat)
      -c, --checksum              skip based on checksum, not mod-time & size
      -a, --archive               archive mode; equals -rlptgoD (no -H,-A,-X)
          --no-OPTION             turn off an implied OPTION (e.g. --no-D)
      -r, --recursive             recurse into directories
      -R, --relative              use relative path names
          --no-implied-dirs       don't send implied dirs with --relative
      -b, --backup                make backups (see --suffix & --backup-dir)
          --backup-dir=DIR        make backups into hierarchy based in DIR
          --suffix=SUFFIX         backup suffix (default ~ w/o --backup-dir)
      -u, --update                skip files that are newer on the receiver
          --inplace               update destination files in-place
          --append                append data onto shorter files
          --append-verify         --append w/old data in file checksum
      -d, --dirs                  transfer directories without recursing
      -l, --links                 copy symlinks as symlinks
      -L, --copy-links            transform symlink into referent file/dir
          --copy-unsafe-links     only "unsafe" symlinks are transformed
          --safe-links            ignore symlinks that point outside the tree
SunOS 5.11           Last change: 28 Sep 2013                   8
          --munge-links           munge symlinks to make them safer
      -k, --copy-dirlinks         transform symlink to dir into referent dir
      -K, --keep-dirlinks         treat symlinked dir on receiver as dir
      -H, --hard-links            preserve hard links
      -p, --perms                 preserve permissions
      -E, --executability         preserve executability
          --chmod=CHMOD           affect file and/or directory permissions
      -A, --acls                  preserve ACLs (implies -p)
      -X, --xattrs                preserve extended attributes
      -o, --owner                 preserve owner (super-user only)
      -g, --group                 preserve group
          --devices               preserve device files (super-user only)
          --specials              preserve special files
      -D                          same as --devices --specials
      -t, --times                 preserve modification times
      -O, --omit-dir-times        omit directories from --times
      -J, --omit-link-times       omit symlinks from --times
          --super                 receiver attempts super-user activities
          --fake-super            store/recover privileged attrs using xattrs
      -S, --sparse                handle sparse files efficiently
          --preallocate           allocate dest files before writing
      -n, --dry-run               perform a trial run with no changes made
      -W, --whole-file            copy files whole (w/o delta-xfer algorithm)
      -x, --one-file-system       don't cross filesystem boundaries
      -B, --block-size=SIZE       force a fixed checksum block-size
      -e, --rsh=COMMAND           specify the remote shell to use
          --rsync-path=PROGRAM    specify the rsync to run on remote machine
          --existing              skip creating new files on receiver
          --ignore-existing       skip updating files that exist on receiver
          --remove-source-files   sender removes synchronized files (non-dir)
          --del                   an alias for --delete-during
          --delete                delete extraneous files from dest dirs
          --delete-before         receiver deletes before xfer, not during
          --delete-during         receiver deletes during the transfer
          --delete-delay          find deletions during, delete after
          --delete-after          receiver deletes after transfer, not during
          --delete-excluded       also delete excluded files from dest dirs
          --ignore-missing-args   ignore missing source args without error
          --delete-missing-args   delete missing source args from destination
          --ignore-errors         delete even if there are I/O errors
          --force                 force deletion of dirs even if not empty
          --max-delete=NUM        don't delete more than NUM files
          --max-size=SIZE         don't transfer any file larger than SIZE
          --min-size=SIZE         don't transfer any file smaller than SIZE
          --partial               keep partially transferred files
          --partial-dir=DIR       put a partially transferred file into DIR
          --delay-updates         put all updated files into place at end
      -m, --prune-empty-dirs      prune empty directory chains from file-list
          --numeric-ids           don't map uid/gid values by user/group name
          --usermap=STRING        custom username mapping
          --groupmap=STRING       custom groupname mapping
          --chown=USER:GROUP      simple username/groupname mapping
SunOS 5.11           Last change: 28 Sep 2013                   9
          --timeout=SECONDS       set I/O timeout in seconds
          --contimeout=SECONDS    set daemon connection timeout in seconds
      -I, --ignore-times          don't skip files that match size and time
          --size-only             skip files that match in size
          --modify-window=NUM     compare mod-times with reduced accuracy
      -T, --temp-dir=DIR          create temporary files in directory DIR
      -y, --fuzzy                 find similar file for basis if no dest file
          --compare-dest=DIR      also compare received files relative to DIR
          --copy-dest=DIR         ... and include copies of unchanged files
          --link-dest=DIR         hardlink to files in DIR when unchanged
      -z, --compress              compress file data during the transfer
          --compress-level=NUM    explicitly set compression level
          --skip-compress=LIST    skip compressing files with suffix in LIST
      -C, --cvs-exclude           auto-ignore files in the same way CVS does
      -f, --filter=RULE           add a file-filtering RULE
      -F                          same as --filter='dir-merge /.rsync-filter'
                                  repeated: --filter='- .rsync-filter'
          --exclude=PATTERN       exclude files matching PATTERN
          --exclude-from=FILE     read exclude patterns from FILE
          --include=PATTERN       don't exclude files matching PATTERN
          --include-from=FILE     read include patterns from FILE
          --files-from=FILE       read list of source-file names from FILE
      -0, --from0                 all *from/filter files are delimited by 0s
      -s, --protect-args          no space-splitting; wildcard chars only
          --address=ADDRESS       bind address for outgoing socket to daemon
          --port=PORT             specify double-colon alternate port number
          --sockopts=OPTIONS      specify custom TCP options
          --blocking-io           use blocking I/O for the remote shell
          --outbuf=N|L|B          set out buffering to None, Line, or Block
          --stats                 give some file-transfer stats
      -8, --8-bit-output          leave high-bit chars unescaped in output
      -h, --human-readable        output numbers in a human-readable format
          --progress              show progress during transfer
      -P                          same as --partial --progress
      -i, --itemize-changes       output a change-summary for all updates
      -M, --remote-option=OPTION  send OPTION to the remote side only
          --out-format=FORMAT     output updates using the specified FORMAT
          --log-file=FILE         log what we're doing to the specified FILE
          --log-file-format=FMT   log updates using the specified FMT
          --password-file=FILE    read daemon-access password from FILE
          --list-only             list the files instead of copying them
          --bwlimit=RATE          limit socket I/O bandwidth
          --write-batch=FILE      write a batched update to FILE
          --only-write-batch=FILE like --write-batch but w/o updating dest
          --read-batch=FILE       read a batched update from FILE
          --protocol=NUM          force an older protocol version to be used
          --iconv=CONVERT_SPEC    request charset conversion of filenames
          --checksum-seed=NUM     set block/file checksum seed (advanced)
      -4, --ipv4                  prefer IPv4
      -6, --ipv6                  prefer IPv6
          --version               print version number
     (-h) --help                  show this help (see below for -h comment)
SunOS 5.11           Last change: 28 Sep 2013                  10
     Rsync can also be run as a daemon, in which case the follow-
     ing options are accepted:
          --daemon                run as an rsync daemon
          --address=ADDRESS       bind to the specified address
          --config=FILE           specify alternate rsyncd.conf file
      -M, --dparam=OVERRIDE       override global daemon config parameter
          --no-detach             do not detach from the parent
          --port=PORT             listen on alternate port number
          --log-file=FILE         override the "log file" setting
          --log-file-format=FMT   override the "log format" setting
      -h, --help                  show this help (if used after --daemon)
OPTIONS
     Rsync accepts both long (double-dash + word) and short (sin-
     gle-dash + letter) options.  The full list of the  available
     options  are described below.  If an option can be specified
     in more than one way, the choices are comma-separated.  Some
     options  only  have  a  long  variant,  not a short.  If the
     option takes a parameter, the parameter is only listed after
     the  long variant, even though it must also be specified for
     the short.  When specifying a parameter, you can either  use
     the  form --option=param or replace the '=' with whitespace.
     The parameter may need to be quoted in some manner for it to
     survive the shell's command-line parsing.  Keep in mind that
     a leading tilde (~) in a filename  is  substituted  by  your
     shell, so --option=~/foo will not change the tilde into your
     home directory (remove the '=' for that).
     --help
          Print a short help page describing the  options  avail-
          able  in  rsync  and  exit.  For backward-compatibility
          with older versions of rsync, the  help  will  also  be
          output if you use the -h option without any other args.
     --version
          print the rsync version number and exit.
     -v, --verbose
          This option increases the amount of information you are
          given  during  the  transfer.   By default, rsync works
          silently. A single -v will give you  information  about
SunOS 5.11           Last change: 28 Sep 2013                  11
          what files are being transferred and a brief summary at
          the end. Two -v options will give  you  information  on
          what files are being skipped and slightly more informa-
          tion at the end. More than two -v options  should  only
          be used if you are debugging rsync.
          In  a  modern rsync, the -v option is equivalent to the
          setting of groups of --info and --debug  options.   You
          can  choose  to use these newer options in addition to,
          or in place of using  --verbose,  as  any  fine-grained
          settings  override  the  implied  settings of -v.  Both
          --info and --debug have a way  to  ask  for  help  that
          tells  you exactly what flags are set for each increase
          in verbosity.
     --info=FLAGS
          This option lets you have fine-grained control over the
          information output you want to see.  An individual flag
          name may be followed by a level number, with 0  meaning
          to  silence  that  output,  1  being the default output
          level, and higher numbers increasing the output of that
          flag  (for  those  that  support  higher  levels).  Use
          --info=help to see all the available flag  names,  what
          they  output,  and  what  flag names are added for each
          increase in the verbose level.  Some examples:
              rsync -a --info=progress2 src/ dest/
              rsync -avv --info=stats2,misc1,flist0 src/ dest/
          Note that  --info=name's  output  is  affected  by  the
          --out-format  and  --itemize-changes (-i) options.  See
          those options for more information on  what  is  output
          and when.
          This  option  was  added to 3.1.0, so an older rsync on
          the  server  side  might  reject   your   attempts   at
          fine-grained control (if one or more flags needed to be
          send to the server and the server was too old to under-
          stand them).
     --debug=FLAGS
          debug output you want to see.  An individual flag  name
          may  be  followed  by a level number, with 0 meaning to
          silence that output, 1 being the default output  level,
          and  higher  numbers increasing the output of that flag
SunOS 5.11           Last change: 28 Sep 2013                  12
          --debug=help  to see all the available flag names, what
              rsync -avvv --debug=none src/ dest/
              rsync -avA --del --debug=del2,acl src/ dest/
          Note  that some debug messages will only be output when
          --msgs2stderr is specified, especially those pertaining
          to I/O and buffer debugging.
          stand them).
     --msgs2stderr
          This  option  changes  rsync  to  send  all  its output
          directly to stderr rather than to send messages to  the
          client  side  via  the protocol (which normally outputs
          info messages via stdout).  This is mainly intended for
          debugging  in order to avoid changing the data sent via
          the protocol, since the extra protocol data can  change
          what  is being tested.  Keep in mind that a daemon con-
          nection does not have a stderr channel to send messages
          back  to  the client side, so if you are doing any dae-
          mon-transfer debugging using this  option,  you  should
          start up a daemon using --no-detach so that you can see
          the stderr output on the daemon side.
          This option has the side-effect of making stderr output
          get  line-buffered so that the merging of the output of
          3 programs happens in a more readable manner.
     -q, --quiet
          This option decreases the amount of information you are
          given during the transfer, notably suppressing informa-
          tion messages from the remote server.  This  option  is
          useful when invoking rsync from cron.
     --no-motd
          This  option  affects the information that is output by
SunOS 5.11           Last change: 28 Sep 2013                  13
          the client at the start of  a  daemon  transfer.   This
          suppresses  the  message-of-the-day (MOTD) text, but it
          also affects the list of modules that the daemon  sends
          in  response  to  the  "rsync host::" request (due to a
          limitation in the rsync protocol), so omit this  option
          if  you  want  to  request the list of modules from the
          daemon.
     -I, --ignore-times
          Normally rsync will skip any files that are already the
          same  size  and  have  the same modification timestamp.
          This option turns  off  this  "quick  check"  behavior,
          causing all files to be updated.
     --size-only
          This modifies rsync's "quick check" algorithm for find-
          ing files that need to be transferred, changing it from
          the default of transferring files with either a changed
          size or a changed last-modified time  to  just  looking
          for  files  that  have changed in size.  This is useful
          when starting to use rsync after using another  mirror-
          ing system which may not preserve timestamps exactly.
     --modify-window
          When  comparing  two timestamps, rsync treats the time-
          stamps as being equal if they differ by  no  more  than
          the  modify-window  value.   This is normally 0 (for an
          exact match), but you may find it useful to set this to
          a larger value in some situations.  In particular, when
          transferring to or from an MS  Windows  FAT  filesystem
          (which  represents  times  with a 2-second resolution),
          --modify-window=1 is useful (allowing times  to  differ
          by up to 1 second).
     -c, --checksum
          This  changes  the  way  rsync checks if the files have
          been changed and are in need of  a  transfer.   Without
          this  option,  rsync  uses  a  "quick  check"  that (by
          default) checks if each file's size and  time  of  last
          modification  match  between  the  sender and receiver.
          This option changes this to compare a 128-bit  checksum
          for each file that has a matching size.  Generating the
          checksums means that both sides will expend  a  lot  of
          disk  I/O  reading  all  the  data  in the files in the
SunOS 5.11           Last change: 28 Sep 2013                  14
          transfer (and this is prior to any reading that will be
          done  to  transfer  changed  files),  so  this can slow
          things down significantly.
          The sending side generates its checksums  while  it  is
          doing  the file-system scan that builds the list of the
          available files.  The receiver generates its  checksums
          when  it is scanning for changed files, and will check-
          sum any file that has the same size as the  correspond-
          ing sender's file:  files with either a changed size or
          a changed checksum are selected for transfer.
          Note that rsync always verifies that  each  transferred
          file  was correctly reconstructed on the receiving side
          by checking a whole-file checksum that is generated  as
          the   file   is   transferred,   but   that   automatic
          after-the-transfer verification has nothing to do  with
          this  option's before-the-transfer "Does this file need
          to be updated?" check.
          For protocol 30 and beyond (first supported in  3.0.0),
          the  checksum  used  is  MD5.  For older protocols, the
          checksum used is MD4.
     -a, --archive
          This is equivalent to -rlptgoD. It is a  quick  way  of
          saying  you  want recursion and want to preserve almost
          everything (with -H being  a  notable  omission).   The
          only   exception  to  the  above  equivalence  is  when
          --files-from is specified, in  which  case  -r  is  not
          implied.
          Note that -a does not preserve hardlinks, because find-
          ing multiply-linked files is expensive.  You must sepa-
          rately specify -H.
     --no-OPTION
          You may turn off one or more implied options by prefix-
          ing the option name with "no-".  Not all options may be
          prefixed with a "no-": only options that are implied by
          other options (e.g. --no-D, --no-perms) or have differ-
          ent    defaults    in   various   circumstances   (e.g.
          --no-whole-file, --no-blocking-io, --no-dirs).  You may
          specify  either the short or the long option name after
          the "no-" prefix (e.g. --no-R is the same as --no-rela-
          tive).
          For  example:  if  you  want  to use -a (--archive) but
SunOS 5.11           Last change: 28 Sep 2013                  15
          don't want -o (--owner), instead of converting -a  into
          -rlptgD,   you   could   specify   -a   --no-o  (or  -a
          --no-owner).
          The order of the options is important:  if you  specify
          --no-r  -a, the -r option would end up being turned on,
          the  opposite  of  -a  --no-r.   Note  also  that   the
          side-effects  of  the --files-from option are NOT posi-
          tional, as it affects  the  default  state  of  several
          options and slightly changes the meaning of -a (see the
          --files-from option for more details).
     -r, --recursive
          This tells rsync to copy directories recursively.   See
          also --dirs (-d).
          Beginning  with  rsync  3.0.0,  the recursive algorithm
          used is now an incremental scan  that  uses  much  less
          memory  than  before  and begins the transfer after the
          scanning of the first few directories  have  been  com-
          pleted.   This incremental scan only affects our recur-
          sion algorithm, and does  not  change  a  non-recursive
          transfer.   It  is also only possible when both ends of
          the transfer are at least version 3.0.0.
          Some options require rsync to know the full file  list,
          so  these  options  disable  the  incremental recursion
          mode.  These include: --delete-before,  --delete-after,
          --prune-empty-dirs,  and  --delay-updates.   Because of
          this, the default delete mode when you specify --delete
          is now --delete-during when both ends of the connection
          are at least 3.0.0 (use  --del  or  --delete-during  to
          request  this  improved deletion mode explicitly).  See
          also the --delete-delay option that is a better  choice
          than using --delete-after.
          Incremental   recursion   can  be  disabled  using  the
          --no-inc-recursive  option  or  its  shorter   --no-i-r
          alias.
     -R, --relative
          Use relative paths. This means that the full path names
          specified on the command line are sent  to  the  server
          rather  than just the last parts of the filenames. This
          is particularly useful when you want  to  send  several
          different directories at the same time. For example, if
          you used this command:
SunOS 5.11           Last change: 28 Sep 2013                  16
             rsync -av /foo/bar/baz.c remote:/tmp/
          ... this would create a file named baz.c  in  /tmp/  on
          the remote machine. If instead you used
             rsync -avR /foo/bar/baz.c remote:/tmp/
          then  a  file named /tmp/foo/bar/baz.c would be created
          on the remote machine, preserving its full path.  These
          extra  path  elements  are called "implied directories"
          (i.e. the "foo" and the "foo/bar"  directories  in  the
          above example).
          Beginning  with  rsync  3.0.0, rsync always sends these
          implied directories as real  directories  in  the  file
          list, even if a path element is really a symlink on the
          sending side.  This  prevents  some  really  unexpected
          behaviors when copying the full path of a file that you
          didn't realize had a symlink in its path.  If you  want
          to  duplicate  a  server-side symlink, include both the
          symlink via its path, and referent  directory  via  its
          real  path.   If  you're dealing with an older rsync on
          the  sending  side,   you   may   need   to   use   the
          --no-implied-dirs option.
          It  is also possible to limit the amount of path infor-
          mation that is sent as  implied  directories  for  each
          path  you  specify.  With a modern rsync on the sending
          side (beginning with 2.6.7), you can insert a dot and a
          slash into the source path, like this:
             rsync -avR /foo/./bar/baz.c remote:/tmp/
          That would create /tmp/bar/baz.c on the remote machine.
          (Note that the dot must be  followed  by  a  slash,  so
          "/foo/."  would  not  be abbreviated.)  For older rsync
          versions, you would need to use a chdir  to  limit  the
          source path.  For example, when pushing files:
             (cd /foo; rsync -avR bar/baz.c remote:/tmp/)
          (Note  that  the  parens  put  the  two commands into a
          sub-shell, so that the "cd" command doesn't  remain  in
          effect  for  future commands.)  If you're pulling files
SunOS 5.11           Last change: 28 Sep 2013                  17
          from an older rsync, use this idiom  (but  only  for  a
          non-daemon transfer):
             rsync -avR --rsync-path="cd /foo; rsync" \
                 remote:bar/baz.c /tmp/
     --no-implied-dirs
          This option affects the default behavior of the --rela-
          tive option.  When it is specified, the  attributes  of
          the  implied  directories from the source names are not
          included in the transfer.  This means that  the  corre-
          sponding  path  elements  on the destination system are
          left unchanged if they exist, and any  missing  implied
          directories  are created with default attributes.  This
          even allows these implied path  elements  to  have  big
          differences,  such as being a symlink to a directory on
          the receiving side.
          For instance, if a command-line  arg  or  a  files-from
          entry  told rsync to transfer the file "path/foo/file",
          the directories "path" and "path/foo" are implied  when
          --relative  is  used.   If  "path/foo"  is a symlink to
          "bar" on the destination system,  the  receiving  rsync
          would  ordinarily  delete  "path/foo", recreate it as a
          directory, and receive the file into the new directory.
          With  --no-implied-dirs,  the  receiving  rsync updates
          "path/foo/file" using the existing path elements, which
          means   that   the   file  ends  up  being  created  in
          "path/bar".   Another  way  to  accomplish  this   link
          preservation  is  to  use  the  --keep-dirlinks  option
          (which will also affect symlinks to directories in  the
          rest of the transfer).
          When  pulling files from an rsync older than 3.0.0, you
          may need to use this option if the sending side  has  a
          symlink  in  the  path  you  request  and  you wish the
          implied directories to be transferred as normal  direc-
          tories.
     -b, --backup
          With  this  option,  preexisting  destination files are
          renamed as each file is transferred  or  deleted.   You
          can  control  where  the  backup file goes and what (if
          any) suffix gets appended using  the  --backup-dir  and
          --suffix options.
SunOS 5.11           Last change: 28 Sep 2013                  18
          Note  that  if  you don't specify --backup-dir, (1) the
          --omit-dir-times option will be  implied,  and  (2)  if
          --delete is also in effect (without --delete-excluded),
          rsync will add a "protect" filter-rule for  the  backup
          suffix  to  the end of all your existing excludes (e.g.
          -f "P *~").  This  will  prevent  previously  backed-up
          files from being deleted.  Note that if you are supply-
          ing your own filter rules, you  may  need  to  manually
          insert  your  own exclude/protect rule somewhere higher
          up in the list so that it has a high enough priority to
          be  effective  (e.g.,  if your rules specify a trailing
          inclusion/exclusion of '*', the auto-added  rule  would
          never be reached).
     --backup-dir=DIR
          In  combination  with  the  --backup option, this tells
          rsync to store all backups in the  specified  directory
          on  the receiving side.  This can be used for incremen-
          tal backups.  You can  additionally  specify  a  backup
          suffix  using  the --suffix option (otherwise the files
          backed up in the specified directory  will  keep  their
          original filenames).
          Note  that  if  you specify a relative path, the backup
          directory will be relative to  the  destination  direc-
          tory,  so  you probably want to specify either an abso-
          lute path or a path that  starts  with  "../".   If  an
          rsync  daemon is the receiver, the backup dir cannot go
          outside the module's path hierarchy, so take extra care
          not to delete it or copy into it.
     --suffix=SUFFIX
          This  option  allows you to override the default backup
          suffix used with the --backup (-b) option. The  default
          suffix  is a ~ if no --backup-dir was specified, other-
          wise it is an empty string.
     -u, --update
          This forces rsync to skip any files which exist on  the
          destination and have a modified time that is newer than
          the source file.  (If an existing destination file  has
          a modification time equal to the source file's, it will
          be updated if the sizes are different.)
          Note that this does not affect the copying of  symlinks
          or  other  special  files.   Also, a difference of file
SunOS 5.11           Last change: 28 Sep 2013                  19
          format between the sender and receiver is  always  con-
          sidered to be important enough for an update, no matter
          what date is on the objects.  In other  words,  if  the
          source  has  a  directory  where  the destination has a
          file, the transfer would occur regardless of the  time-
          stamps.
          This  option  is a transfer rule, not an exclude, so it
          doesn't affect the data that goes into the  file-lists,
          and  thus  it doesn't affect deletions.  It just limits
          the files that the receiver requests to be transferred.
     --inplace
          This option changes how rsync transfers a file when its
          data needs to be updated: instead of the default method
          of  creating  a new copy of the file and moving it into
          place when it is complete,  rsync  instead  writes  the
          updated data directly to the destination file.
          This has several effects:
          o    Hard  links  are  not  broken.  This means the new
               data will be visible through other hard  links  to
               the  destination file.  Moreover, attempts to copy
               differing source files onto a multiply-linked des-
               tination  file  will result in a "tug of war" with
               the destination data changing back and forth.
          o    In-use binaries cannot be updated (either  the  OS
               will prevent this from happening, or binaries that
               attempt to swap-in their data  will  misbehave  or
               crash).
          o    The  file's  data will be in an inconsistent state
               during the transfer and will be left that  way  if
               the transfer is interrupted or if an update fails.
          o    A file  that  rsync  cannot  write  to  cannot  be
               updated. While a super user can update any file, a
               normal user needs to be granted  write  permission
               for  the  open  of the file for writing to be suc-
               cessful.
          o    The efficiency of rsync's delta-transfer algorithm
               may  be  reduced  if  some data in the destination
               file is overwritten before it can be copied  to  a
               position  later  in the file.  This does not apply
               if you use --backup, since rsync is  smart  enough
SunOS 5.11           Last change: 28 Sep 2013                  20
               to  use  the backup file as the basis file for the
               transfer.
          WARNING: you should not use this option to update files
          that  are  being accessed by others, so be careful when
          choosing to use this for a copy.
          This option is useful for transferring large files with
          block-based  changes or appended data, and also on sys-
          tems that are disk bound, not network  bound.   It  can
          also help keep a copy-on-write filesystem snapshot from
          diverging the entire contents of a file that  only  has
          minor changes.
          The  option  implies  --partial  (since  an interrupted
          transfer does not delete the file), but conflicts  with
          --partial-dir  and  --delay-updates.   Prior  to  rsync
          2.6.4  --inplace  was  also  incompatible  with  --com-
          pare-dest and --link-dest.
     --append
          This  causes  rsync  to update a file by appending data
          onto the end of the file, which presumes that the  data
          that  already exists on the receiving side is identical
          with the start of the file on the sending side.   If  a
          file  needs  to  be  transferred  and  its  size on the
          receiver is the same or longer than  the  size  on  the
          sender,  the  file is skipped.  This does not interfere
          with the updating of a  file's  non-content  attributes
          (e.g.  permissions, ownership, etc.) when the file does
          not need to be transferred,  nor  does  it  affect  the
          updating  of any non-regular files.  Implies --inplace,
          but does not conflict with --sparse (since it is always
          extending a file's length).
     --append-verify
          This  works  just  like  the  --append  option, but the
          existing data on the receiving side is included in  the
          full-file  checksum verification step, which will cause
          a file to be resent  if  the  final  verification  step
          fails  (rsync  uses  a  normal, non-appending --inplace
          transfer for the resend).
          Note: prior to rsync 3.0.0, the --append option  worked
          like --append-verify, so if you are interacting with an
          older rsync (or the transfer is using a protocol  prior
          to  30),  specifying either append option will initiate
SunOS 5.11           Last change: 28 Sep 2013                  21
          an --append-verify transfer.
     -d, --dirs
          Tell the sending side to include any  directories  that
          are  encountered.   Unlike  --recursive,  a directory's
          contents are not copied unless the directory name spec-
          ified  is  "." or ends with a trailing slash (e.g. ".",
          "dir/.", "dir/", etc.).  Without  this  option  or  the
          --recursive  option, rsync will skip all directories it
          encounters (and output a message  to  that  effect  for
          each one).  If you specify both --dirs and --recursive,
          --recursive takes precedence.
          The --dirs option is implied by the --files-from option
          or   the   --list-only  option  (including  an  implied
          --list-only usage) if --recursive wasn't specified  (so
          that  directories  are  seen  in the listing).  Specify
          --no-dirs (or --no-d) if you want to turn this off.
          There is also a backward-compatibility  helper  option,
          --old-dirs  (or --old-d) that tells rsync to use a hack
          of "-r --exclude='/*/*'" to get an older rsync to  list
          a single directory without recursing.
     -l, --links
          When  symlinks are encountered, recreate the symlink on
          the destination.
     -L, --copy-links
          When symlinks are encountered, the item that they point
          to  (the  referent) is copied, rather than the symlink.
          In older versions of rsync, this option  also  had  the
          side-effect  of  telling  the  receiving side to follow
          symlinks, such as symlinks to directories.  In a modern
          rsync   such  as  this  one,  you'll  need  to  specify
          --keep-dirlinks (-K) to get this extra  behavior.   The
          only  exception  is when sending files to an rsync that
          is too old to understand -K -- in  that  case,  the  -L
          option  will  still  have the side-effect of -K on that
          older receiving rsync.
     --copy-unsafe-links
          This tells rsync to copy the referent of symbolic links
          that  point outside the copied tree.  Absolute symlinks
SunOS 5.11           Last change: 28 Sep 2013                  22
          are also treated like ordinary files, and  so  are  any
          symlinks  in  the source path itself when --relative is
          used.   This  option  has  no  additional   effect   if
          --copy-links was also specified.
     --safe-links
          This  tells  rsync  to  ignore any symbolic links which
          point outside the copied tree.  All  absolute  symlinks
          are also ignored. Using this option in conjunction with
          --relative may give unexpected results.
     --munge-links
          This option tells rsync to (1) modify all  symlinks  on
          the  receiving  side  in a way that makes them unusable
          but recoverable (see below), or (2) to unmunge symlinks
          on  the  sending  side that had been stored in a munged
          state.  This is useful if you  don't  quite  trust  the
          source of the data to not try to slip in a symlink to a
          unexpected place.
          The way rsync disables the use of symlinks is to prefix
          each  one with the string "/rsyncd-munged/".  This pre-
          vents the links from being used as long as that  direc-
          tory  does  not  exist.   When  this option is enabled,
          rsync will refuse to run if that path is a directory or
          a symlink to a directory.
          The  option  only affects the client side of the trans-
          fer, so if you need it to affect the server, specify it
          via  --remote-option.   (Note that in a local transfer,
          the client side is the sender.)
          This option has no affect on a daemon, since the daemon
          configures  whether  it  wants  munged symlinks via its
          "munge symlinks" parameter.  See also  the  "munge-sym-
          links"  perl  script  in  the  support directory of the
          source code.
     -k, --copy-dirlinks
          This option causes the sending side to treat a  symlink
          to  a  directory  as  though  it were a real directory.
          This is useful if you don't want symlinks to non-direc-
          tories   to   be  affected,  as  they  would  be  using
          --copy-links.
          Without this option, if the sending side has replaced a
SunOS 5.11           Last change: 28 Sep 2013                  23
          directory  with a symlink to a directory, the receiving
          side will delete anything that is in the way of the new
          symlink,  including  a  directory hierarchy (as long as
          --force or --delete is in effect).
          See also --keep-dirlinks for an  analogous  option  for
          the receiving side.
          --copy-dirlinks  applies to all symlinks to directories
          in the source.  If you want to follow only a few speci-
          fied  symlinks,  a trick you can use is to pass them as
          additional source args with  a  trailing  slash,  using
          --relative to make the paths match up right.  For exam-
          ple:
          rsync -r --relative src/./ src/./follow-me/ dest/
          This works because rsync calls lstat(2) on  the  source
          arg  as  given,  and  the trailing slash makes lstat(2)
          follow the symlink, giving rise to a directory  in  the
          file-list  which overrides the symlink found during the
          scan of "src/./".
     -K, --keep-dirlinks
          This option causes the receiving side to treat  a  sym-
          link to a directory as though it were a real directory,
          but only if  it  matches  a  real  directory  from  the
          sender.   Without  this  option, the receiver's symlink
          would be deleted and replaced with a real directory.
          For example, suppose you  transfer  a  directory  "foo"
          that  contains a file "file", but "foo" is a symlink to
          directory   "bar"    on    the    receiver.     Without
          --keep-dirlinks,  the  receiver  deletes symlink "foo",
          recreates it as a directory, and receives the file into
          the  new directory.  With --keep-dirlinks, the receiver
          keeps the symlink and "file" ends up in "bar".
          One note of caution:  if you use  --keep-dirlinks,  you
          must trust all the symlinks in the copy!  If it is pos-
          sible for an untrusted user to create their own symlink
          to  any directory, the user could then (on a subsequent
          copy) replace the symlink with  a  real  directory  and
          affect  the  content  of whatever directory the symlink
          references.  For backup  copies,  you  are  better  off
          using  something like a bind mount instead of a symlink
          to modify your receiving hierarchy.
SunOS 5.11           Last change: 28 Sep 2013                  24
          See also --copy-dirlinks for an  analogous  option  for
          the sending side.
     -H, --hard-links
          This  tells  rsync to look for hard-linked files in the
          source and link together the corresponding files on the
          destination.  Without this option, hard-linked files in
          the source are treated as  though  they  were  separate
          files.
          This  option  does NOT necessarily ensure that the pat-
          tern of hard links on the destination  exactly  matches
          that on the source.  Cases in which the destination may
          end up with extra hard links include the following:
          o    If the destination contains extraneous  hard-links
               (more  linking  than what is present in the source
               file list), the copying algorithm will  not  break
               them  explicitly.   However, if one or more of the
               paths  have  content   differences,   the   normal
               file-update  process  will break those extra links
               (unless you are using the --inplace option).
          o    If you specify a --link-dest directory  that  con-
               tains  hard  links, the linking of the destination
               files against the --link-dest files can cause some
               paths in the destination to become linked together
               due to the --link-dest associations.
          Note that rsync can  only  detect  hard  links  between
          files  that  are  inside  the  transfer  set.  If rsync
          updates a file that has extra hard-link connections  to
          files  outside  the transfer, that linkage will be bro-
          ken.  If you are tempted to use the --inplace option to
          avoid  this breakage, be very careful that you know how
          your files are being updated so that  you  are  certain
          that no unintended changes happen due to lingering hard
          links (and see the --inplace option for more  caveats).
          If  incremental  recursion is active (see --recursive),
          rsync may transfer a missing hard-linked file before it
          finds  that another link for that contents exists else-
          where in the hierarchy.  This does not affect the accu-
          racy  of the transfer (i.e. which files are hard-linked
          together), just its efficiency (i.e. copying  the  data
          for  a new, early copy of a hard-linked file that could
          have been found later in the transfer in another member
SunOS 5.11           Last change: 28 Sep 2013                  25
          of  the  hard-linked  set  of files).  One way to avoid
          this inefficiency is to disable  incremental  recursion
          using the --no-inc-recursive option.
     -p, --perms
          This  option causes the receiving rsync to set the des-
          tination permissions to be the same as the source  per-
          missions.   (See  also  the --chmod option for a way to
          modify what rsync considers to be  the  source  permis-
          sions.)
          When  this  option  is off, permissions are set as fol-
          lows:
          o    Existing files (including  updated  files)  retain
               their  existing  permissions,  though  the  --exe-
               cutability option might change  just  the  execute
               permission for the file.
          o    New  files  get their "normal" permission bits set
               to the source file's permissions masked  with  the
               receiving  directory's default permissions (either
               the receiving process's umask, or the  permissions
               specified  via the destination directory's default
               ACL), and their special permission  bits  disabled
               except  in the case where a new directory inherits
               a setgid bit from its parent directory.
          Thus, when --perms and --executability  are  both  dis-
          abled,  rsync's  behavior  is the same as that of other
          file-copy utilities, such as cp(1) and tar(1).
          In summary: to give destination  files  (both  old  and
          new)  the source permissions, use --perms.  To give new
          files the destination-default permissions (while  leav-
          ing  existing  files  unchanged),  make  sure  that the
          --perms option is off and  use  --chmod=ugo=rwX  (which
          ensures  that  all  non-masked  bits  get enabled).  If
          you'd care to make this latter behavior easier to type,
          you  could  define a popt alias for it, such as putting
          this line in the file ~/.popt  (the  following  defines
          the  -Z  option, and includes --no-g to use the default
          group of the destination dir):
             rsync alias -Z --no-p --no-g --chmod=ugo=rwX
SunOS 5.11           Last change: 28 Sep 2013                  26
          You could then use this new option in a command such as
          this one:
             rsync -avZ src/ dest/
          (Caveat:  make  sure  that -a does not follow -Z, or it
          will  re-enable  the  two  "--no-*"  options  mentioned
          above.)
          The  preservation  of  the  destination's setgid bit on
          newly-created directories when --perms is off was added
          in  rsync 2.6.7.  Older rsync versions erroneously pre-
          served the three special permission bits for newly-cre-
          ated  files  when --perms was off, while overriding the
          destination's setgid bit  setting  on  a  newly-created
          directory.  Default ACL observance was added to the ACL
          patch for rsync 2.6.7, so  older  (or  non-ACL-enabled)
          rsyncs  use the umask even if default ACLs are present.
          (Keep in mind that it is the version of  the  receiving
          rsync that affects these behaviors.)
     -E, --executability
          This  option causes rsync to preserve the executability
          (or non-executability) of regular files when --perms is
          not  enabled.   A regular file is considered to be exe-
          cutable if at least one executability differs from that
          of  the  corresponding  source file, rsync modifies the
          destination file's permissions as follows:
          o    To make a file non-executable, rsync turns off all
               its 'x' permissions.
          o    To make a file executable, rsync turns on each 'x'
               permission that has a corresponding 'r' permission
               enabled.
          If --perms is enabled, this option is ignored.
     -A, --acls
          This option causes rsync to update the destination ACLs
          to be the same as the source  ACLs.   The  option  also
          implies --perms.
SunOS 5.11           Last change: 28 Sep 2013                  27
          The source and destination systems must have compatible
          ACL entries for this option to work properly.  See  the
          --fake-super  option  for  a  way to backup and restore
          ACLs that are not compatible.
     -X, --xattrs
          extended  attributes to be the same as the source ones.
          For systems that support extended-attribute namespaces,
          a copy being done by a super-user copies all namespaces
          except system.*.  A normal user only copies the  user.*
          namespace.   To  be able to backup and restore non-user
          namespaces as  a  normal  user,  see  the  --fake-super
          option.
          Note  that  this  option  does  not copy rsyncs special
          xattr values (e.g. those used by  --fake-super)  unless
          you  repeat the option (e.g. -XX).  This "copy all xat-
          trs" mode cannot be used with --fake-super.
     --chmod
          This option tells rsync to apply one or more comma-sep-
          arated  "chmod" modes to the permission of the files in
          the transfer.  The resulting value is treated as though
          it  were the permissions that the sending side supplied
          for the file, which means that this option can seem  to
          have  no  effect  on  existing  files if --perms is not
          enabled.
          In addition to the normal parsing  rules  specified  in
          the  chmod(1)  manpage,  you  can  specify an item that
          should only apply to a directory by prefixing it with a
          'D',  or  specify  an  item that should only apply to a
          file by prefixing it with a 'F'.  For example, the fol-
          lowing  will  ensure  that  all  directories get marked
          set-gid, that no files are  other-writable,  that  both
          are  user-writable  and  group-writable,  and that both
          have consistent executability across all bits:
          --chmod=Dg+s,ug+w,Fo-w,+X
          Using octal mode numbers is also allowed:
          --chmod=D2775,F664
SunOS 5.11           Last change: 28 Sep 2013                  28
          It is also legal to specify multiple  --chmod  options,
          as  each additional option is just appended to the list
          of changes to make.
          See the --perms and --executability options for how the
          resulting  permission value can be applied to the files
          in the transfer.
     -o, --owner
          This option causes rsync to set the owner of the desti-
          nation file to be the same as the source file, but only
          if the receiving rsync is being run as  the  super-user
          (see also the --super and --fake-super options).  With-
          out this option, the owner of  new  and/or  transferred
          files  are  set  to  the invoking user on the receiving
          side.
          The preservation of ownership will  associate  matching
          names  by  default,  but  may fall back to using the ID
          number   in   some   circumstances   (see   also    the
          --numeric-ids option for a full discussion).
     -g, --group
          This option causes rsync to set the group of the desti-
          nation file to be the same as the source file.  If  the
          receiving  program is not running as the super-user (or
          if --no-super was  specified),  only  groups  that  the
          invoking user on the receiving side is a member of will
          be preserved.  Without this option, the group is set to
          the default group of the invoking user on the receiving
          side.
          The preservation of group  information  will  associate
          matching  names  by default, but may fall back to using
          the ID number  in  some  circumstances  (see  also  the
     --devices
          This  option  causes  rsync  to  transfer character and
          block device files to the  remote  system  to  recreate
          these  devices.   This  option  has  no  effect  if the
          receiving rsync is not run as the super-user (see  also
SunOS 5.11           Last change: 28 Sep 2013                  29
     --specials
          This option causes rsync to transfer special files such
          as named sockets and fifos.
     -D   The -D option is equivalent to --devices --specials.
     -t, --times
          This tells rsync to transfer modification  times  along
          with  the  files  and update them on the remote system.
          Note that if this option is not used, the  optimization
          that  excludes files that have not been modified cannot
          be effective; in other words, a missing -t or  -a  will
          cause  the  next  transfer  to behave as if it used -I,
          causing  all  files  to  be  updated  (though   rsync's
          delta-transfer  algorithm  will  make the update fairly
          efficient if the files haven't actually changed, you're
          much better off using -t).
          This  tells  rsync  to omit directories when it is pre-
          serving modification times (see --times).   If  NFS  is
          sharing  the directories on the receiving side, it is a
          good idea to use -O.  This option is  inferred  if  you
          use --backup without --backup-dir.
          This tells rsync to omit symlinks when it is preserving
     --super
          This tells the receiving  side  to  attempt  super-user
          activities  even  if  the receiving rsync wasn't run by
          the super-user.  These activities  include:  preserving
          users  via  the  --owner  option, preserving all groups
          (not just the current user's groups) via  the  --groups
          option,  and  copying devices via the --devices option.
          This is useful for systems that allow  such  activities
          without  being  the  super-user,  and also for ensuring
          that you will get errors if the  receiving  side  isn't
          being  run  as  the super-user.  To turn off super-user
          activities, the super-user can use --no-super.
SunOS 5.11           Last change: 28 Sep 2013                  30
     --fake-super
          When this option is enabled, rsync simulates super-user
          activities    by    saving/restoring   the   privileged
          attributes via special  extended  attributes  that  are
          attached  to  each file (as needed).  This includes the
          file's owner and group (if it is not the default),  the
          file's  device info (device & special files are created
          as empty text files), and any permission bits  that  we
          won't  allow to be set on the real file (e.g.  the real
          file gets u-s,g-s,o-t for safety) or that  would  limit
          the  owner's  access  (since  the  real  super-user can
          always access/change a file, the files  we  create  can
          always be accessed/changed by the creating user).  This
          option also handles ACLs (if --acls was specified)  and
          non-user  extended  attributes  (if --xattrs was speci-
          fied).
          This is a good way  to  backup  data  without  using  a
          super-user,  and  to  store ACLs from incompatible sys-
          tems.
          The --fake-super option only affects the side where the
          option  is  used.   To  affect  the  remote  side  of a
          remote-shell connection, use the  --remote-option  (-M)
          option:
            rsync -av -M--fake-super /src/ host:/dest/
          For  a  local copy, this option affects both the source
          and the destination.  If  you  wish  a  local  copy  to
          enable  this  option  just  for  the destination files,
          specify -M--fake-super.  If you wish a  local  copy  to
          enable  this  option just for the source files, combine
          --fake-super with -M--super.
          This  option  is  overridden  by   both   --super   and
          --no-super.
          See  also  the  "fake  super"  setting  in the daemon's
          rsyncd.conf file.
     -S, --sparse
          Try to handle sparse files efficiently so they take  up
          less   space   on   the  destination.   Conflicts  with
          --inplace because it's not possible to  overwrite  data
          in a sparse fashion.
SunOS 5.11           Last change: 28 Sep 2013                  31
     --preallocate
          This  tells  the  receiver to allocate each destination
          file to its eventual size before writing  data  to  the
          file.   Rsync  will  only use the real filesystem-level
          preallocation support provided by Linux's  fallocate(2)
          system  call  or  Cygwin's  posix_fallocate(3), not the
          slow glibc implementation that writes a zero byte  into
          each block.
          Without  this  option, larger files may not be entirely
          contiguous on the  filesystem,  but  with  this  option
          rsync  will probably copy more slowly.  If the destina-
          tion is not an extent-supporting  filesystem  (such  as
          ext4,  xfs,  NTFS, etc.), this option may have no posi-
          tive effect at all.
     -n, --dry-run
          This makes rsync perform a trial run that doesn't  make
          any  changes  (and produces mostly the same output as a
          real run).  It is most  commonly  used  in  combination
          with  the  -v,  --verbose  and/or -i, --itemize-changes
          options to see what an rsync command  is  going  to  do
          before one actually runs it.
          The  output  of  --itemize-changes  is  supposed  to be
          exactly the same on a dry run and a subsequent real run
          (barring  intentional  trickery  and  system call fail-
          ures); if it isn't, that's a bug.  Other output  should
          be  mostly  unchanged,  but  may  differ in some areas.
          Notably, a dry run does not send the  actual  data  for
          file transfers, so --progress has no effect, the "bytes
          sent", "bytes received", "literal data",  and  "matched
          data" statistics are too small, and the "speedup" value
          is equivalent to a run where  no  file  transfers  were
          needed.
     -W, --whole-file
          With  this  option  rsync's delta-transfer algorithm is
          not used and the whole file is sent as-is instead.  The
          transfer  may be faster if this option is used when the
          bandwidth between the source and  destination  machines
          is  higher  than the bandwidth to disk (especially when
          the "disk" is actually a networked  filesystem).   This
          is the default when both the source and destination are
          specified as local paths, but only if no  batch-writing
          option is in effect.
SunOS 5.11           Last change: 28 Sep 2013                  32
User Commands                                            rsync(1)
          This  tells rsync to avoid crossing a filesystem bound-
          ary when recursing.  This does  not  limit  the  user's
          ability to specify items to copy from multiple filesys-
          tems, just rsync's recursion through the  hierarchy  of
          each  directory  that  the user specified, and also the
          analogous recursion on the receiving side during  dele-
          tion.   Also  keep  in  mind that rsync treats a "bind"
          mount to the same device as being on the same  filesys-
          tem.
          If this option is repeated, rsync omits all mount-point
          directories from the copy.  Otherwise, it  includes  an
          empty  directory  at  each  mount-point  it  encounters
          (using the attributes of the mounted directory  because
          those of the underlying mount-point directory are inac-
          cessible).
          If rsync  has  been  told  to  collapse  symlinks  (via
          --copy-links  or  --copy-unsafe-links),  a symlink to a
          directory  on  another  device  is   treated   like   a
          mount-point.   Symlinks  to  non-directories  are unaf-
          fected by this option.
     --existing, --ignore-non-existing
          This tells rsync  to  skip  creating  files  (including
          directories)  that do not exist yet on the destination.
          If this option is combined with  the  --ignore-existing
          option,  no  files will be updated (which can be useful
          if all you want to do is delete extraneous files).
     --ignore-existing
          This tells rsync to skip updating  files  that  already
          exist on the destination (this does not ignore existing
          directories, or nothing  would  get  done).   See  also
          --existing.
SunOS 5.11           Last change: 28 Sep 2013                  33
          This option can be useful for those doing backups using
          the --link-dest option when they  need  to  continue  a
          backup  run  that got interrupted.  Since a --link-dest
          run is copied into a new directory hierarchy  (when  it
          is  used properly), using --ignore existing will ensure
          that the already-handled files don't get tweaked (which
          avoids  a  change  in  permissions  on  the hard-linked
          files).  This does mean that this option is only  look-
          ing  at the existing files in the destination hierarchy
          itself.
          This tells rsync to remove from the  sending  side  the
          files  (meaning non-directories) that are a part of the
          transfer and have been successfully duplicated  on  the
          receiving side.
          Note  that  you  should  only use this option on source
          files that are quiescent.  If you  are  using  this  to
          move  files that show up in a particular directory over
          to another host, make sure that the finished files  get
          renamed into the source directory, not directly written
          into it, so that rsync can't possibly transfer  a  file
          that  is  not  yet  fully  written.  If you can't first
          write the files into a different directory, you  should
          use  a  naming idiom that lets rsync avoid transferring
          files that are not yet finished  (e.g.  name  the  file
          "foo.new"  when  it is written, rename it to "foo" when
          it is done, and then use the  option  --exclude='*.new'
          for the rsync transfer).
          Starting  with  3.1.0,  rsync will skip the sender-side
          removal (and output an error) if  the  file's  size  or
          modify time has not stayed unchanged.
     --delete
          This  tells  rsync  to delete extraneous files from the
          receiving side (ones that aren't on the sending  side),
          but  only  for  the directories that are being synchro-
          nized.  You must have asked rsync  to  send  the  whole
          directory  (e.g. "dir" or "dir/") without using a wild-
          card for the directory's contents (e.g. "dir/*")  since
          the  wildcard  is  expanded by the shell and rsync thus
          gets a request to transfer individual  files,  not  the
          files'  parent directory.  Files that are excluded from
          the transfer  are  also  excluded  from  being  deleted
          unless you use the --delete-excluded option or mark the
          rules as only matching on the  sending  side  (see  the
SunOS 5.11           Last change: 28 Sep 2013                  34
          include/exclude modifiers in the FILTER RULES section).
          Prior to rsync 2.6.7, this option would have no  effect
          unless  --recursive was enabled.  Beginning with 2.6.7,
          deletions will also occur when --dirs (-d) is  enabled,
          but  only  for  directories  whose  contents  are being
          copied.
          This option can be dangerous if used  incorrectly!   It
          is  a  very  good  idea  to  first  try a run using the
          --dry-run option (-n) to see what files are going to be
          deleted.
          If  the  sending  side detects any I/O errors, then the
          deletion of any files at the destination will be  auto-
          matically   disabled.  This  is  to  prevent  temporary
          filesystem failures (such as NFS errors) on the sending
          side  from  causing  a massive deletion of files on the
          destination.   You   can   override   this   with   the
          --ignore-errors option.
          The  --delete  option  may  be combined with one of the
          --delete-WHEN options  without  conflict,  as  well  as
          --delete-excluded.     However,    if   none   of   the
          --delete-WHEN options are specified, rsync will  choose
          the  --delete-during  algorithm  when  talking to rsync
          3.0.0 or newer, and the --delete-before algorithm  when
          talking to an older rsync.  See also --delete-delay and
          --delete-after.
     --delete-before
          Request that the file-deletions on the  receiving  side
          be  done  before  the  transfer  starts.   See --delete
          (which is implied) for more details on file-deletion.
          Deleting before the transfer is helpful if the filesys-
          tem  is  tight  for space and removing extraneous files
          would help to make the transfer possible.  However,  it
          does  introduce  a delay before the start of the trans-
          fer, and this delay might cause the transfer to timeout
          (if  --timeout was specified).  It also forces rsync to
          use the old, non-incremental recursion  algorithm  that
          requires  rsync  to  scan all the files in the transfer
          into memory at once (see --recursive).
     --delete-during, --del
          be  done  incrementally  as  the transfer happens.  The
SunOS 5.11           Last change: 28 Sep 2013                  35
          per-directory delete scan is  done  right  before  each
          directory  is checked for updates, so it behaves like a
          more efficient  --delete-before,  including  doing  the
          deletions prior to any per-directory filter files being
          updated.  This option was first added in rsync  version
          2.6.4.   See  --delete  (which  is  implied)  for  more
     --delete-delay
          be computed during the transfer (like --delete-during),
          and then removed after the transfer completes.  This is
          useful   when   combined  with  --delay-updates  and/or
          --fuzzy,   and   is   more   efficient    than    using
          --delete-after   (but  can  behave  differently,  since
          --delete-after computes the  deletions  in  a  separate
          pass  after  all  updates  are done).  If the number of
          removed files overflows an internal buffer, a temporary
          file  will be created on the receiving side to hold the
          names (it is removed while open, so you  shouldn't  see
          it during the transfer).  If the creation of the tempo-
          rary file fails, rsync will try to fall back  to  using
          --delete-after  (which  it  cannot do if --recursive is
          doing an incremental scan).   See  --delete  (which  is
     --delete-after
          be done after the transfer has completed.  This is use-
          ful if you are sending new per-directory merge files as
          a part of the transfer and you want their exclusions to
          take  effect for the delete phase of the current trans-
          fer.  It also forces rsync to use the  old,  non-incre-
          mental  recursion algorithm that requires rsync to scan
          all the files in the transfer into memory at once  (see
          --recursive).  See --delete (which is implied) for more
     --delete-excluded
          In addition to deleting the files on the receiving side
          that  are  not on the sending side, this tells rsync to
          also delete any files on the receiving  side  that  are
          excluded (see --exclude).  See the FILTER RULES section
          for a way to make individual exclusions behave this way
          on  the  receiver,  and for a way to protect files from
          --delete-excluded.  See --delete (which is implied) for
SunOS 5.11           Last change: 28 Sep 2013                  36
          When rsync is first processing the explicitly requested
          source   files   (e.g.   command-line   arguments    or
          --files-from  entries),  it is normally an error if the
          file cannot be  found.   This  option  suppresses  that
          error,  and  does  not  try to transfer the file.  This
          does not affect subsequent vanished-file  errors  if  a
          file  was initially found to be present and later is no
          longer there.
          This  option  takes  the  behavior  of  (the   implied)
          --ignore-missing-args  option  a  step  farther:   each
          missing arg will become a deletion request of the  cor-
          responding  destination  file  on  the  receiving  side
          (should it  exist).   If  the  destination  file  is  a
          non-empty  directory,  it  will  only  be  successfully
          deleted if --force or --delete are  in  effect.   Other
          than that, this option is independent of any other type
          of delete processing.
          The missing source files  are  represented  by  special
          file-list  entries  which display as a "*missing" entry
          in the --list-only output.
     --ignore-errors
          Tells --delete to go ahead and delete files  even  when
          there are I/O errors.
     --force
          This option tells rsync to delete a non-empty directory
          when it is to be replaced by a non-directory.  This  is
          only relevant if deletions are not active (see --delete
          for details).
          Note for older rsync versions: --force used to still be
          required  when  using --delete-after, and it used to be
          non-functional unless the --recursive option  was  also
          enabled.
SunOS 5.11           Last change: 28 Sep 2013                  37
     --max-delete=NUM
          This  tells  rsync not to delete more than NUM files or
          directories.  If that limit is  exceeded,  all  further
          deletions  are skipped through the end of the transfer.
          At the end, rsync outputs a warning (including a  count
          of  the skipped deletions) and exits with an error code
          of 25 (unless some more important error condition  also
          occurred).
          Beginning   with   version   3.0.0,   you  may  specify
          --max-delete=0 to be warned about any extraneous  files
          in the destination without removing any of them.  Older
          clients interpreted this  as  "unlimited",  so  if  you
          don't  know what version the client is, you can use the
          less obvious --max-delete=-1 as  a  backward-compatible
          way  to  specify  that  no deletions be allowed (though
          really old versions didn't  warn  when  the  limit  was
          exceeded).
     --max-size=SIZE
          This tells rsync to avoid transferring any file that is
          larger than the specified SIZE. The SIZE value  can  be
          suffixed  with  a string to indicate a size multiplier,
          and may be a fractional value (e.g. "--max-size=1.5m").
          The  suffixes  are  as  follows:  "K"  (or  "KiB") is a
          kibibyte  (1024),  "M"  (or  "MiB")   is   a   mebibyte
          (1024*1024),   and   "G"   (or  "GiB")  is  a  gibibyte
          (1024*1024*1024).  If you want  the  multiplier  to  be
          1000  instead of 1024, use "KB", "MB", or "GB".  (Note:
          lower-case is also accepted for all values.)   Finally,
          if  the  suffix  ends in either "+1" or "-1", the value
          will be offset by one byte in the indicated  direction.
          Examples:  --max-size=1.5mb-1  is  1499999  bytes,  and
          --max-size=2g+1 is 2147483649 bytes.
          Note that rsync versions prior to 3.1.0 did  not  allow
          --max-size=0.
     --min-size=SIZE
          smaller than the specified SIZE, which can help in  not
SunOS 5.11           Last change: 28 Sep 2013                  38
          transferring  small,  junk  files.   See the --max-size
          option for a description of SIZE and other information.
          --min-size=0.
     -B, --block-size=BLOCKSIZE
          This forces the block size used in rsync's delta-trans-
          fer  algorithm  to  a  fixed  value.   It  is  normally
          selected based on the size of each file being  updated.
          See the technical report for details.
     -e, --rsh=COMMAND
          This  option allows you to choose an alternative remote
          shell program to  use  for  communication  between  the
          local  and  remote copies of rsync. Typically, rsync is
          configured to use ssh by default, but you may prefer to
          use rsh on a local network.
          If  this  option is used with [user@]host::module/path,
          then the remote shell COMMAND will be used  to  run  an
          rsync  daemon  on the remote host, and all data will be
          transmitted  through  that  remote  shell   connection,
          rather  than  through  a  direct socket connection to a
          running rsync daemon on the remote host.  See the  sec-
          tion  "USING  RSYNC-DAEMON  FEATURES VIA A REMOTE-SHELL
          CONNECTION" above.
          Command-line arguments are permitted  in  COMMAND  pro-
          vided  that  COMMAND  is presented to rsync as a single
          argument.  You must  use  spaces  (not  tabs  or  other
          whitespace)  to separate the command and args from each
          other, and you can use single- and/or double-quotes  to
          preserve  spaces  in an argument (but not backslashes).
          Note  that  doubling  a  single-quote  inside  a   sin-
          gle-quoted  string  gives  you a single-quote; likewise
          for double-quotes (though you need to pay attention  to
          which  quotes  your  shell  is parsing and which quotes
          rsync is parsing).  Some examples:
              -e 'ssh -p 2234'
              -e 'ssh -o "ProxyCommand nohup ssh firewall nc  -w1
          %h %p"'
          (Note   that   ssh   users  can  alternately  customize
          site-specific  connect  options  in  their  .ssh/config
SunOS 5.11           Last change: 28 Sep 2013                  39
          file.)
          You  can also choose the remote shell program using the
          RSYNC_RSH environment variable, which accepts the  same
          range of values as -e.
          See  also the --blocking-io option which is affected by
          this option.
          Use this to specify what program is to be  run  on  the
          remote  machine  to  start-up  rsync.   Often used when
          rsync is not in the default remote-shell's  path  (e.g.
          --rsync-path=/usr/local/bin/rsync).   Note that PROGRAM
          is run with the help of a shell, so it can be any  pro-
          gram, script, or command sequence you'd care to run, so
          long as it does not corrupt  the  standard-in  &  stan-
          dard-out that rsync is using to communicate.
          One tricky example is to set a different default direc-
          tory on the remote machine for use with the  --relative
          option.  For instance:
              rsync -avR --rsync-path="cd /a/b && rsync" host:c/d
          /e/
          This option is used for more advanced situations  where
          you  want  certain effects to be limited to one side of
          the transfer only.  For instance, if you want  to  pass
          --log-file=FILE  and --fake-super to the remote system,
          specify it like this:
              rsync -av  -M  --log-file=foo  -M--fake-super  src/
          dest/
          If  you  want  to  have an option affect only the local
          side of a transfer when it normally affects both sides,
          send its negation to the remote side.  Like this:
              rsync -av -x -M--no-x src/ dest/
SunOS 5.11           Last change: 28 Sep 2013                  40
          Be  cautious using this, as it is possible to toggle an
          option that will cause rsync to have a  different  idea
          about  what  data  to  expect next over the socket, and
          that will make it fail in a cryptic fashion.
          Note that it is best to use a separate  --remote-option
          for each option you want to pass.  This makes your use-
          age compatible with the --protect-args option.  If that
          option  is  off, any spaces in your remote options will
          be split by the remote shell unless you take  steps  to
          protect them.
          When  performing  a local transfer, the "local" side is
          the sender and the "remote" side is the receiver.
          Note some versions of the popt  option-parsing  library
          have  a  bug  in  them  that prevents you from using an
          adjacent arg with an equal in it next to a short option
          letter   (e.g.   -M--log-file=/tmp/foo.   If  this  bug
          affects your version of popt, you can use  the  version
          of popt that is included with rsync.
     -C, --cvs-exclude
          This  is a useful shorthand for excluding a broad range
          of files that you often don't want to transfer  between
          systems.  It  uses a similar algorithm to CVS to deter-
          mine if a file should be ignored.
          The exclude list is initialized to exclude the  follow-
          ing items (these initial items are marked as perishable
          -- see the FILTER RULES section):
               RCS SCCS CVS CVS.adm  RCSLOG  cvslog.*  tags  TAGS
               .make.state .nse_depinfo *~ #* .#* ,* _$* *$ *.old
               *.bak *.BAK *.orig  *.rej  .del-*  *.a  *.olb  *.o
               *.obj  *.so  *.exe *.Z *.elc *.ln core .svn/ .git/
               .hg/ .bzr/
          then, files listed in a $HOME/.cvsignore are  added  to
          the list and any files listed in the CVSIGNORE environ-
          ment variable (all cvsignore  names  are  delimited  by
          whitespace).
          Finally,  any  file  is  ignored  if  it is in the same
          directory as a .cvsignore file and matches one  of  the
          patterns listed therein.  Unlike rsync's filter/exclude
          files, these patterns are split on whitespace.  See the
          cvs(1) manual for more information.
SunOS 5.11           Last change: 28 Sep 2013                  41
          If  you're  combining  -C with your own --filter rules,
          you should note that these CVS excludes are appended at
          the  end  of your own rules, regardless of where the -C
          was placed on the  command-line.   This  makes  them  a
          lower priority than any rules you specified explicitly.
          If you want to control where  these  CVS  excludes  get
          inserted into your filter rules, you should omit the -C
          as a command-line  option  and  use  a  combination  of
          --filter=:C   and  --filter=-C  (either  on  your  com-
          mand-line or by putting the ":C" and "-C" rules into  a
          filter  file  with your other rules).  The first option
          turns on the per-directory scanning for the  .cvsignore
          file.   The second option does a one-time import of the
          CVS excludes mentioned above.
     -f, --filter=RULE
          This option allows you  to  add  rules  to  selectively
          exclude  certain  files  from  the  list of files to be
          transferred. This is most useful in combination with  a
          recursive transfer.
          You  may  use  as  many --filter options on the command
          line as you like to build  up  the  list  of  files  to
          exclude.  If the filter contains whitespace, be sure to
          quote it so that the shell gives the rule to rsync as a
          single argument.  The text below also mentions that you
          can use an underscore to replace the space  that  sepa-
          rates a rule from its arg.
          See  the  FILTER RULES section for detailed information
          on this option.
     -F   The -F option is a shorthand for  adding  two  --filter
          rules  to your command.  The first time it is used is a
          shorthand for this rule:
          This tells rsync to look for per-directory  .rsync-fil-
          ter  files that have been sprinkled through the hierar-
          chy and use their rules to  filter  the  files  in  the
          transfer.   If  -F  is  repeated, it is a shorthand for
          this rule:
             --filter='exclude .rsync-filter'
SunOS 5.11           Last change: 28 Sep 2013                  42
          This filters out  the  .rsync-filter  files  themselves
          from the transfer.
          on how these options work.
     --exclude=PATTERN
          This option is a simplified form of the --filter option
          that defaults to an exclude rule and does not allow the
          full rule-parsing syntax of normal filter rules.
          on this option.
     --exclude-from=FILE
          This  option is related to the --exclude option, but it
          specifies a FILE that contains  exclude  patterns  (one
          per  line).  Blank lines in the file and lines starting
          with ';' or '#' are ignored.  If FILE is  -,  the  list
          will be read from standard input.
     --include=PATTERN
          that defaults to an include rule and does not allow the
          on this option.
     --include-from=FILE
          This option is related to the --include option, but  it
          specifies  a  FILE  that contains include patterns (one
     --files-from=FILE
          Using this option allows you to specify the exact  list
          of  files  to transfer (as read from the specified FILE
          or - for standard input).  It also tweaks  the  default
          behavior  of rsync to make transferring just the speci-
          fied files and directories easier:
SunOS 5.11           Last change: 28 Sep 2013                  43
          o    The --relative (-R) option is implied, which  pre-
               serves  the path information that is specified for
               each item in the file (use --no-relative or --no-R
               if you want to turn that off).
          o    The --dirs (-d) option is implied, which will cre-
               ate directories specified in the list on the  des-
               tination  rather  than  noisily skipping them (use
               --no-dirs or --no-d if you want to turn that off).
          o    The  --archive  (-a)  option's  behavior  does not
               imply --recursive (-r), so specify it  explicitly,
               if you want it.
          o    These  side-effects  change  the  default state of
               rsync, so the position of the --files-from  option
               on  the  command-line  has no bearing on how other
               options are parsed (e.g. -a works the same  before
               or  after  --files-from,  as  does  --no-R and all
               other options).
          The filenames that are read from the FILE are all rela-
          tive  to  the  source  dir  --  any leading slashes are
          removed and no ".." references are allowed to go higher
          than the source dir.  For example, take this command:
             rsync -a --files-from=/tmp/foo /usr remote:/backup
          If /tmp/foo contains the string "bin" (or even "/bin"),
          the /usr/bin directory will be created  as  /backup/bin
          on  the  remote  host.  If it contains "bin/" (note the
          trailing slash), the immediate contents of  the  direc-
          tory  would also be sent (without needing to be explic-
          itly mentioned in the file --  this  began  in  version
          2.6.4).   In  both cases, if the -r option was enabled,
          that dir's entire hierarchy would also  be  transferred
          (keep  in mind that -r needs to be specified explicitly
          with --files-from, since it  is  not  implied  by  -a).
          Also  note  that the effect of the (enabled by default)
          --relative option is to duplicate only  the  path  info
          that  is  read  from  the file -- it does not force the
          duplication of  the  source-spec  path  (/usr  in  this
          case).
          In addition, the --files-from file can be read from the
          remote host instead of the local host if you specify  a
          "host:"  in  front of the file (the host must match one
SunOS 5.11           Last change: 28 Sep 2013                  44
          end of the transfer).  As a short-cut, you can  specify
          just a prefix of ":" to mean "use the remote end of the
          transfer".  For example:
             rsync   -a    --files-from=:/path/file-list    src:/
          /tmp/copy
          This   would  copy  all  the  files  specified  in  the
          /path/file-list file that was  located  on  the  remote
          "src" host.
          If the --iconv and --protect-args options are specified
          and the --files-from filenames are being sent from  one
          host  to another, the filenames will be translated from
          the sending host's  charset  to  the  receiving  host's
          charset.
          NOTE:  sorting  the  list  of files in the --files-from
          input helps rsync to be  more  efficient,  as  it  will
          avoid  re-visiting  the  path  elements that are shared
          between adjacent entries.  If the input is not  sorted,
          some  path  elements  (implied  directories) may end up
          being scanned multiple times, and rsync will eventually
          unduplicate  them  after they get turned into file-list
          elements.
     -0, --from0
          This tells rsync that the rules/filenames it reads from
          a file are terminated by a null ('\0') character, not a
          NL,  CR,  or  CR+LF.   This   affects   --exclude-from,
          --include-from,  --files-from,  and  any  merged  files
          specified in a  --filter  rule.   It  does  not  affect
          --cvs-exclude  (since  all names read from a .cvsignore
          file are split on whitespace).
     -s, --protect-args
          This option sends all filenames and most options to the
          remote  rsync  without  allowing  the  remote  shell to
          interpret them.  This means that spaces are  not  split
          in  names,  and any non-wildcard special characters are
          not translated (such as ~, $, ;, &,  etc.).   Wildcards
          are  expanded  on  the remote host by rsync (instead of
          the shell doing it).
          If you use this option with --iconv, the  args  related
          to  the  remote  side  will also be translated from the
SunOS 5.11           Last change: 28 Sep 2013                  45
          local to the  remote  character-set.   The  translation
          happens  before  wild-cards are expanded.  See also the
          --files-from option.
          You may also control this  option  via  the  RSYNC_PRO-
          TECT_ARGS environment variable.  If this variable has a
          non-zero value, this option will be enabled by default,
          otherwise it will be disabled by default.  Either state
          is overridden by a manually specified positive or nega-
          tive  version  of  this  option  (note  that --no-s and
          --no-protect-args are the  negative  versions).   Since
          this  option was first introduced in 3.0.0, you'll need
          to make sure it's disabled if you ever need to interact
          with a remote rsync that is older than that.
          Rsync  can  also  be configured (at build time) to have
          this option enabled by default (with is  overridden  by
          both  the  environment  and  the  command-line).   This
          option will eventually become a new default setting  at
          some as-yet-undetermined point in the future.
     -T, --temp-dir=DIR
          This  option  instructs  rsync  to use DIR as a scratch
          directory when creating temporary copies of  the  files
          transferred  on the receiving side.  The default behav-
          ior is to create each temporary file in the same direc-
          tory as the associated destination file.
          This  option is most often used when the receiving disk
          partition does not have enough free  space  to  hold  a
          copy of the largest file in the transfer.  In this case
          (i.e. when the scratch directory is on a different disk
          partition),  rsync  will  not  be  able  to rename each
          received temporary file over the top of the  associated
          destination  file, but instead must copy it into place.
          Rsync does this by copying the file over the top of the
          destination file, which means that the destination file
          will contain truncated data during this copy.  If  this
          were  not  done  this way (even if the destination file
          were first removed, the data locally copied to a tempo-
          rary  file  in  the  destination  directory,  and  then
          renamed into place) it would be possible  for  the  old
          file  to  continue taking up disk space (if someone had
          it open), and thus there might not be  enough  room  to
          fit the new version on the disk at the same time.
          If  you  are using this option for reasons other than a
          shortage of disk space, you may wish to combine it with
          the  --delay-updates option, which will ensure that all
          copied  files  get  put  into  subdirectories  in   the
SunOS 5.11           Last change: 28 Sep 2013                  46
          destination  hierarchy,  awaiting the end of the trans-
          fer.  If you don't have enough room  to  duplicate  all
          the   arriving  files  on  the  destination  partition,
          another way to tell rsync that you aren't  overly  con-
          cerned  about  disk  space  is to use the --partial-dir
          option with a relative path; because this  tells  rsync
          that it is OK to stash off a copy of a single file in a
          subdir in the destination hierarchy, rsync will use the
          partial-dir  as a staging area to bring over the copied
          file, and then rename it into place from there. (Speci-
          fying  a  --partial-dir  with an absolute path does not
          have this side-effect.)
     -y, --fuzzy
          This option tells rsync that it should look for a basis
          file  for  any  destination  file that is missing.  The
          current algorithm looks in the same  directory  as  the
          destination  file for either a file that has an identi-
          cal size and modified-time, or a similarly-named  file.
          If  found,  rsync  uses  the fuzzy basis file to try to
          speed up the transfer.
          If the option is repeated, the fuzzy scan will also  be
          done  in any matching alternate destination directories
          that are specified via --compare-dest, --copy-dest,  or
          --link-dest.
          Note  that the use of the --delete option might get rid
          of any  potential  fuzzy-match  files,  so  either  use
          --delete-after  or  specify some filename exclusions if
          you need to prevent this.
     --compare-dest=DIR
          This option instructs rsync to use DIR on the  destina-
          tion machine as an additional hierarchy to compare des-
          tination files against doing transfers  (if  the  files
          are  missing  in the destination directory).  If a file
          is found in DIR that is identical to the sender's file,
          the  file  will  NOT  be transferred to the destination
          directory.  This is useful for creating a sparse backup
          of just files that have changed from an earlier backup.
          This option is typically used to copy into an empty (or
          newly created) directory.
          Beginning  in  version  2.6.4,  multiple --compare-dest
          directories may be provided, which will cause rsync  to
          search  the  list  in  the order specified for an exact
          match.  If a  match  is  found  that  differs  only  in
SunOS 5.11           Last change: 28 Sep 2013                  47
          attributes,  a  local  copy  is made and the attributes
          updated.  If a match is not found, a  basis  file  from
          one of the DIRs will be selected to try to speed up the
          transfer.
          If DIR is a relative path, it is relative to the desti-
          nation    directory.     See   also   --copy-dest   and
          --link-dest.
          NOTE: beginning with version 3.1.0, rsync will remove a
          file from a non-empty destination hierarchy if an exact
          match is found in one of the  compare-dest  hierarchies
          (making  the  end  result  more  closely  match a fresh
          copy).
     --copy-dest=DIR
          This option behaves like --compare-dest, but rsync will
          also  copy unchanged files found in DIR to the destina-
          tion directory using a local copy.  This is useful  for
          doing  transfers  to  a  new  destination while leaving
          existing files intact, and then doing  a  flash-cutover
          when all files have been successfully transferred.
          Multiple --copy-dest directories may be provided, which
          will cause rsync to search the list in the order speci-
          fied for an unchanged file.  If a match is not found, a
          basis file from one of the DIRs will be selected to try
          to speed up the transfer.
          nation  directory.    See   also   --compare-dest   and
          --link-dest.
     --link-dest=DIR
          This  option  behaves  like  --copy-dest, but unchanged
          files are hard  linked  from  DIR  to  the  destination
          directory.   The  files  must  be identical in all pre-
          served attributes (e.g.  permissions,  possibly  owner-
          ship) in order for the files to be linked together.  An
          example:
            rsync  -av  --link-dest=$PWD/prior_dir  host:src_dir/
          new_dir/
          If    file's   aren't   linking,   double-check   their
          attributes.  Also check if some attributes are  getting
SunOS 5.11           Last change: 28 Sep 2013                  48
          forced  outside of rsync's control, such a mount option
          that squishes root to a single user, or mounts a remov-
          able  drive  with  generic  ownership  (such  as OS X's
          "Ignore ownership on this volume" option).
          Beginning in version 2.6.4, multiple --link-dest direc-
          transfer.
          This  option works best when copying into an empty des-
          tination hierarchy, as existing  files  may  get  their
          attributes  tweaked, and that can affect alternate des-
          tination files  via  hard-links.   Also,  itemizing  of
          changes can get a bit muddled.  Note that prior to ver-
          sion 3.1.0, an alternate-directory  exact  match  would
          never be found (nor linked into the destination) when a
          destination file already exists.
          Note   that   if   you   combine   this   option   with
          --ignore-times,  rsync will not link any files together
          because it only links identical  files  together  as  a
          substitute for transferring the file, never as an addi-
          tional check after the file is updated.
          --copy-dest.
          Note that rsync versions prior to 2.6.1 had a bug  that
          could  prevent  --link-dest from working properly for a
          non-super-user when -o was  specified  (or  implied  by
          -a).   You  can work-around this bug by avoiding the -o
          option when sending to an old rsync.
     -z, --compress
          With this option, rsync compresses the file data as  it
          is  sent  to the destination machine, which reduces the
          amount of data being transmitted -- something  that  is
          useful over a slow connection.
          Note  that  this  option typically achieves better com-
          pression ratios than can be achieved by  using  a  com-
          pressing   remote  shell  or  a  compressing  transport
          because it takes advantage of the implicit  information
          in  the  matching  data  blocks that are not explicitly
SunOS 5.11           Last change: 28 Sep 2013                  49
          sent over the connection.
          See the --skip-compress option for the default list  of
          file suffixes that will not be compressed.
     --compress-level=NUM
          Explicitly set the compression level to use (see --com-
          press) instead  of  letting  it  default.   If  NUM  is
          non-zero, the --compress option is implied.
     --skip-compress=LIST
          Override  the  list  of  file suffixes that will not be
          compressed.  The LIST should be one or more  file  suf-
          fixes (without the dot) separated by slashes (/).
          You  may  specify  an  empty string to indicate that no
          file should be skipped.
          Simple character-class matching is supported: each must
          consist of a list of letters inside the square brackets
          (e.g. no special classes, such as "[:alpha:]", are sup-
          ported, and '-' has no special meaning).
          The  characters asterisk (*) and question-mark (?) have
          no special meaning.
          Here's an example that specifies  6  suffixes  to  skip
          (since 1 of the 5 rules matches 2 suffixes):
              --skip-compress=gz/jpg/mp[34]/7z/bz2
          The  default  list  of  suffixes  that will not be com-
          pressed is this (in this version of rsync):
          7z ace avi bz2 deb gpg gz iso jpeg jpg lz lzma lzo  mov
          mp3 mp4 ogg png rar rpm rzip tbz tgz tlz txz xz z zip
          This list will be replaced by your --skip-compress list
          in all but one situation: a copy from  a  daemon  rsync
          will  add your skipped suffixes to its list of non-com-
          pressing files (and its list may  be  configured  to  a
          different default).
     --numeric-ids
SunOS 5.11           Last change: 28 Sep 2013                  50
          With  this option rsync will transfer numeric group and
          user IDs rather than using user  and  group  names  and
          mapping them at both ends.
          By default rsync will use the username and groupname to
          determine what ownership to give files. The special uid
          0  and  the  special  group  0  are  never  mapped  via
          user/group names even if the  --numeric-ids  option  is
          not specified.
          If  a user or group has no name on the source system or
          it has no match on the  destination  system,  then  the
          numeric ID from the source system is used instead.  See
          also the comments on the "use chroot"  setting  in  the
          rsyncd.conf  manpage  for information on how the chroot
          setting affects rsync's ability to look up the names of
          the users and groups and what you can do about it.
     --usermap=STRING, --groupmap=STRING
          These  options  allow  you  to specify users and groups
          that should be mapped to other values by the  receiving
          side.   The STRING is one or more FROM:TO pairs of val-
          ues separated by commas.  Any matching FROM value  from
          the  sender  is  replaced  with  a  TO  value  from the
          receiver.  You may specify usernames or  user  IDs  for
          the  FROM and TO values, and the FROM value may also be
          a wild-card string, which will be matched  against  the
          sender's names (wild-cards do NOT match against ID num-
          bers, though see below for why  a  '*'  matches  every-
          thing).   You may instead specify a range of ID numbers
          via an inclusive range: LOW-HIGH.  For example:
            --usermap=0-99:nobody,wayne:admin,*:normal --groupmap=usr:1,1:usr
          The first match in the list is the one  that  is  used.
          You  should specify all your user mappings using a sin-
          gle --usermap option, and/or all  your  group  mappings
          using a single --groupmap option.
          Note  that  the  sender's name for the 0 user and group
          are not transmitted to  the  receiver,  so  you  should
          either  match  these values using a 0, or use the names
          in effect on the  receiving  side  (typically  "root").
          All  other FROM names match those in use on the sending
          side.  All TO names match those in use on the receiving
          side.
          Any IDs that do not have a name on the sending side are
SunOS 5.11           Last change: 28 Sep 2013                  51
          treated as having an empty  name  for  the  purpose  of
          matching.   This allows them to be matched via a "*" or
          using an empty name.  For instance:
            --usermap=:nobody --groupmap=*:nobody
          When the --numeric-ids option is used, the sender  does
          not  send any names, so all the IDs are treated as hav-
          ing an empty name.  This means that you  will  need  to
          specify  numeric  FROM  values if you want to map these
          nameless IDs to different values.
          For the --usermap option to have  any  effect,  the  -o
          (--owner)  option  must  be  used (or implied), and the
          receiver will need to be running as a  super-user  (see
          also  the  --fake-super  option).   For  the --groupmap
          option to have any effect,  the  -g  (--groups)  option
          must  be  used (or implied), and the receiver will need
          to have permissions to set that group.
     --chown=USER:GROUP
          This option forces all files to be owned by  USER  with
          group  GROUP.   This  is a simpler interface than using
          --usermap and --groupmap directly,  but  it  is  imple-
          mented  using  those  options internally, so you cannot
          mix them.  If either the USER or  GROUP  is  empty,  no
          mapping  for  the  omitted  user/group  will occur.  If
          GROUP is empty, the trailing colon may be omitted,  but
          if USER is empty, a leading colon must be supplied.
          If  you  specify  "--chown=foo:bar, this is exactly the
          same as specifying "--usermap=*:foo  --groupmap=*:bar",
          only easier.
     --timeout=TIMEOUT
          This  option allows you to set a maximum I/O timeout in
          seconds. If no data is transferred  for  the  specified
          time  then  rsync  will  exit.  The default is 0, which
          means no timeout.
     --contimeout
          This option allows you to set the amount of  time  that
          rsync  will  wait for its connection to an rsync daemon
          to succeed.  If the timeout  is  reached,  rsync  exits
SunOS 5.11           Last change: 28 Sep 2013                  52
          with an error.
     --address
          By default rsync will bind to the wildcard address when
          connecting to an rsync daemon.   The  --address  option
          allows  you  to specify a specific IP address (or host-
          name) to bind to.  See also this option in the --daemon
          mode section.
     --port=PORT
          This  specifies  an  alternate  TCP  port number to use
          rather than the default of 873.  This is only needed if
          you  are  using the double-colon (::) syntax to connect
          with an rsync daemon (since the URL syntax has a way to
          specify  the port as a part of the URL).  See also this
          option in the --daemon mode section.
     --sockopts
          This option can provide endless fun for people who like
          to tune their systems to the utmost degree. You can set
          all sorts of socket options which  may  make  transfers
          faster (or slower!). Read the man page for the setsock-
          opt() system call for details on some  of  the  options
          you  may  be  able to set. By default no special socket
          options are set. This only affects direct  socket  con-
          nections  to  a  remote rsync daemon.  This option also
          exists in the --daemon mode section.
     --blocking-io
          This tells rsync to use blocking I/O when  launching  a
          remote  shell transport.  If the remote shell is either
          rsh or remsh, rsync defaults  to  using  blocking  I/O,
          otherwise it defaults to using non-blocking I/O.  (Note
          that ssh prefers non-blocking I/O.)
     --outbuf=MODE
          This sets the output buffering mode.  The mode  can  be
          None  (aka Unbuffered), Line, or Block (aka Full).  You
          may specify as little as a single letter for the  mode,
          and use upper or lower case.
          The main use of this option is to change Full buffering
SunOS 5.11           Last change: 28 Sep 2013                  53
          to Line buffering when rsync's output  is  going  to  a
          file or pipe.
          Requests a simple itemized list of the changes that are
          being made to each file, including  attribute  changes.
          This is exactly the same as specifying --out-format='%i
          %n%L'.  If you repeat the option, unchanged files  will
          also  be  output, but only if the receiving rsync is at
          least version 2.6.7 (you can use -vv  with  older  ver-
          sions  of  rsync,  but that also turns on the output of
          other verbose messages).
          The "%i" escape has a cryptic output that is 11 letters
          long.   The  general  format  is like the string YXcst-
          poguax, where Y is replaced by the type of update being
          done,  X  is  replaced  by the file-type, and the other
          letters represent attributes that may be output if they
          are being modified.
          The update types that replace the Y are as follows:
          o    A  < means that a file is being transferred to the
               remote host (sent).
          o    A > means that a file is being transferred to  the
               local host (received).
          o    A  c  means that a local change/creation is occur-
               ring for the item  (such  as  the  creation  of  a
               directory or the changing of a symlink, etc.).
          o    A  h means that the item is a hard link to another
               item (requires --hard-links).
          o    A . means that  the  item  is  not  being  updated
               (though  it  might  have attributes that are being
               modified).
          o    A * means that the  rest  of  the  itemized-output
               area contains a message (e.g. "deleting").
          The  file-types that replace the X are: f for a file, a
          d for a directory, an L  for  a  symlink,  a  D  for  a
          device,  and a S for a special file (e.g. named sockets
          and fifos).
SunOS 5.11           Last change: 28 Sep 2013                  54
          The other letters in the string above  are  the  actual
          letters that will be output if the associated attribute
          for the item is being updated or a "." for  no  change.
          Three  exceptions to this are: (1) a newly created item
          replaces each letter with a "+", (2) an identical  item
          replaces  the  dots  with  spaces,  and  (3) an unknown
          attribute replaces each letter with  a  "?"  (this  can
          happen when talking to an older rsync).
          The attribute that is associated with each letter is as
          follows:
          o    A c means either that a regular file has a differ-
               ent  checksum (requires --checksum) or that a sym-
               link, device, or special file has a changed value.
               Note  that  if  you  are sending files to an rsync
               prior to 3.0.1, this change flag will  be  present
               only for checksum-differing regular files.
          o    A  s means the size of a regular file is different
               and will be updated by the file transfer.
          o    A t means the modification time is  different  and
               is  being  updated to the sender's value (requires
               --times).  An alternate value of T means that  the
               modification  time  will  be  set  to the transfer
               time, which happens when a file/symlink/device  is
               updated  without  --times  and  when  a symlink is
               changed and  the  receiver  can't  set  its  time.
               (Note: when using an rsync 3.0.0 client, you might
               see the s flag combined  with  t  instead  of  the
               proper T flag for this time-setting failure.)
          o    A  p  means  the permissions are different and are
               --perms).
          o    An  o  means  the  owner is different and is being
               updated to the sender's  value  (requires  --owner
               and super-user privileges).
          o    A  g  means  the  group  is different and is being
               updated to the sender's  value  (requires  --group
               and the authority to set the group).
          o    The u slot is reserved for future use.
          o    The a means that the ACL information changed.
          o    The   x   means   that   the   extended  attribute
SunOS 5.11           Last change: 28 Sep 2013                  55
          One other output is possible:  when deleting files, the
          "%i"  will  output the string "*deleting" for each item
          that is being removed (assuming that you are talking to
          a recent enough rsync that it logs deletions instead of
          outputting them as a verbose message).
     --out-format=FORMAT
          This allows you  to  specify  exactly  what  the  rsync
          client  outputs to the user on a per-update basis.  The
          format  is  a  text  string  containing  embedded  sin-
          gle-character  escape sequences prefixed with a percent
          (%) character.   A default format of "%n%L" is  assumed
          if  either  --info=name  or -v is specified (this tells
          you just the name of the file and, if  the  item  is  a
          link,  where it points).  For a full list of the possi-
          ble escape characters, see the "log format" setting  in
          the rsyncd.conf manpage.
          Specifying   the   --out-format   option   implies  the
          --info=name option, which will mention each file,  dir,
          etc.  that  gets updated in a significant way (a trans-
          ferred file, a recreated symlink/device, or  a  touched
          directory).  In addition, if the itemize-changes escape
          (%i) is included in the string  (e.g.  if  the  --item-
          ize-changes  option  was  used),  the  logging of names
          increases to mention any item that is  changed  in  any
          way  (as long as the receiving side is at least 2.6.4).
          See the --itemize-changes option for a  description  of
          the output of "%i".
          Rsync  will  output  the  out-format  string prior to a
          file's transfer unless one  of  the  transfer-statistic
          escapes is requested, in which case the logging is done
          at the end of the file's transfer.  When this late log-
          ging  is  in  effect  and --progress is also specified,
          rsync will also output  the  name  of  the  file  being
          transferred  prior  to  its  progress information (fol-
          lowed, of course, by the out-format output).
     --log-file=FILE
          This option causes rsync to log what it is doing  to  a
          file.   This  is  similar  to the logging that a daemon
          does, but can be requested for the client  side  and/or
          the server side of a non-daemon transfer.  If specified
          as a client option, transfer logging  will  be  enabled
SunOS 5.11           Last change: 28 Sep 2013                  56
          with   a   default   format  of  "%i  %n%L".   See  the
          --log-file-format option if you wish to override  this.
          Here's  a example command that requests the remote side
          to log what is happening:
            rsync -av --remote-option=--log-file=/tmp/rlog src/ dest/
          This is very useful if you need to debug why a  connec-
          tion is closing unexpectedly.
     --log-file-format=FORMAT
          This allows you to specify exactly what per-update log-
          ging is put into the file specified by  the  --log-file
          option (which must also be specified for this option to
          have any effect).  If  you  specify  an  empty  string,
          updated  files  will  not be mentioned in the log file.
          For a list of the possible escape characters,  see  the
          "log format" setting in the rsyncd.conf manpage.
          The  default FORMAT used if --log-file is specified and
          this option is not is '%i %n%L'.
     --stats
          This tells rsync to print a verbose set  of  statistics
          on  the  file transfer, allowing you to tell how effec-
          tive rsync's delta-transfer algorithm is for your data.
          This  option is equivalent to --info=stats2 if combined
          with 0 or 1 -v options, or  --info=stats3  if  combined
          with 2 or more -v options.
          The current statistics are as follows:
          o    Number  of  files  is the count of all "files" (in
               the generic sense),  which  includes  directories,
               symlinks,  etc.   The total count will be followed
               by a list of counts by filetype (if the  total  is
               non-zero).   For  example: "(reg: 5, dir: 3, link:
               2, dev: 1, special: 1)" lists the totals for regu-
               lar  files,  directories,  symlinks,  devices, and
               special files.  If any of value is 0, it  is  com-
               pletely omitted from the list.
          o    Number  of  created files is the count of how many
               "files" (generic sense) were created  (as  opposed
               to  updated).  The total count will be followed by
SunOS 5.11           Last change: 28 Sep 2013                  57
               non-zero).
          o    Number  of  deleted files is the count of how many
               non-zero).   Note that this line is only output if
               deletions are in effect, and only if  protocol  31
               is being used (the default for rsync 3.1.x).
          o    Number  of  regular files transferred is the count
               of normal files  that  were  updated  via  rsync's
               delta-transfer  algorithm,  which does not include
               dirs, symlinks, etc.  Note that rsync 3.1.0  added
               the word "regular" into this heading.
          o    Total file size is the total sum of all file sizes
               in the transfer.  This does not count any size for
               directories or special files, but does include the
               size of symlinks.
          o    Total transferred file size is the  total  sum  of
               all files sizes for just the transferred files.
          o    Literal  data  is  how  much unmatched file-update
               data we had to send to  the  receiver  for  it  to
               recreate the updated files.
          o    Matched  data  is  how  much data the receiver got
               locally when recreating the updated files.
          o    File list size is how big the file-list  data  was
               when  the sender sent it to the receiver.  This is
               smaller than the in-memory size for the file  list
               due  to  some  compressing of duplicated data when
               rsync sends the list.
          o    File list generation time is the number of seconds
               that  the  sender  spent  creating  the file list.
               This requires a modern rsync on the  sending  side
               for this to be present.
          o    File  list  transfer time is the number of seconds
               that the sender spent sending the file list to the
               receiver.
          o    Total  bytes  sent  is  the count of all the bytes
               that rsync sent from the client side to the server
               side.
          o    Total   bytes   received   is  the  count  of  all
SunOS 5.11           Last change: 28 Sep 2013                  58
               non-message  bytes  that  rsync  received  by  the
               client  side  from the server side.  "Non-message"
               bytes means that we don't count the  bytes  for  a
               verbose  message that the server sent to us, which
               makes the stats more consistent.
     -8, --8-bit-output
          This tells  rsync  to  leave  all  high-bit  characters
          unescaped  in the output instead of trying to test them
          to see if they're  valid  in  the  current  locale  and
          escaping the invalid ones.  All control characters (but
          never tabs) are  always  escaped,  regardless  of  this
          option's setting.
          The  escape  idiom that started in 2.6.7 is to output a
          literal backslash (\)  and  a  hash  (#),  followed  by
          exactly  3  octal digits.  For example, a newline would
          output as "\#012".  A literal backslash that  is  in  a
          filename is not escaped unless it is followed by a hash
          and 3 digits (0-9).
     -h, --human-readable
          Output numbers in a more human-readable format.   There
          are 3 possible levels:  (1) output numbers with a sepa-
          rator between each set of 3 digits (either a comma or a
          period,  depending  on  if  the decimal point is repre-
          sented by a period or a comma); (2) output  numbers  in
          units of 1000 (with a character suffix for larger units
          -- see below); (3) output numbers in units of 1024.
          The default is human-readable level 1.  Each -h  option
          increases  the  level  by  one.  You can take the level
          down to 0 (to output numbers as pure digits) by specif-
          ing the --no-human-readable (--no-h) option.
          The  unit  letters  that are appended in levels 2 and 3
          are: K (kilo), M (mega), G (giga), or  T  (tera).   For
          example,  a  1234567-byte file would output as 1.23M in
          level-2 (assuming that a period is your  local  decimal
          point).
          Backward  compatibility  note:  versions of rsync prior
          to 3.1.0 do not support  human-readable  level  1,  and
          they  default  to level 0.  Thus, specifying one or two
          -h options will behave in a comparable  manner  in  old
          and new versions as long as you didn't specify a --no-h
          option prior to  one  or  more  -h  options.   See  the
SunOS 5.11           Last change: 28 Sep 2013                  59
          --list-only option for one difference.
     --partial
          By default, rsync will delete any partially transferred
          file if the transfer is interrupted.  In  some  circum-
          stances  it  is more desirable to keep partially trans-
          ferred files. Using the --partial option tells rsync to
          keep  the  partial  file which should make a subsequent
          transfer of the rest of the file much faster.
     --partial-dir=DIR
          A better way to keep partial files than  the  --partial
          option  is  to  specify a DIR that will be used to hold
          the partial data (instead of writing it out to the des-
          tination file).  On the next transfer, rsync will use a
          file found in this dir as data to speed up the  resump-
          tion  of  the  transfer and then delete it after it has
          served its purpose.
          Note that if --whole-file is  specified  (or  implied),
          any  partial-dir  file that is found for a file that is
          being updated will simply be removed  (since  rsync  is
          sending  files  without  using  rsync's  delta-transfer
          algorithm).
          Rsync will create the DIR if it is  missing  (just  the
          last dir -- not the whole path).  This makes it easy to
          use a relative path (such as "--partial-dir=.rsync-par-
          tial")  to  have  rsync create the partial-directory in
          the destination file's directory when needed, and  then
          remove it again when the partial file is deleted.
          If the partial-dir value is not an absolute path, rsync
          will add an exclude rule at the end of all your  exist-
          ing  excludes.   This  will  prevent the sending of any
          partial-dir files that may exist on the  sending  side,
          and  will  also  prevent  the untimely deletion of par-
          tial-dir items on the receiving side.  An example:  the
          above  --partial-dir option would add the equivalent of
          "-f '-p .rsync-partial/'" at the end of any other  fil-
          ter rules.
          If  you  are  supplying your own exclude rules, you may
          need to add your own exclude/hide/protect rule for  the
          partial-dir  because  (1)  the  auto-added  rule may be
          ineffective at the end of your other rules, or (2)  you
          may  wish  to  override  rsync's  exclude  choice.  For
          instance, if  you  want  to  make  rsync  clean-up  any
SunOS 5.11           Last change: 28 Sep 2013                  60
          left-over  partial-dirs  that  may be lying around, you
          should specify --delete-after and add a  "risk"  filter
          rule,  e.g.   -f  'R  .rsync-partial/'.   (Avoid  using
          --delete-before or  --delete-during  unless  you  don't
          need rsync to use any of the left-over partial-dir data
          during the current run.)
          IMPORTANT: the --partial-dir should not be writable  by
          other  users  or  it  is  a  security risk.  E.g. AVOID
          "/tmp".
          You can also set the partial-dir value  the  RSYNC_PAR-
          TIAL_DIR  environment  variable.   Setting  this in the
          environment does not force --partial to be enabled, but
          rather it affects where partial files go when --partial
          is specified.  For instance, instead  of  using  --par-
          tial-dir=.rsync-tmp  along  with  --progress, you could
          set RSYNC_PARTIAL_DIR=.rsync-tmp  in  your  environment
          and  then  just use the -P option to turn on the use of
          the .rsync-tmp dir for  partial  transfers.   The  only
          times  that the --partial option does not look for this
          environment value are (1) when --inplace was  specified
          (since --inplace conflicts with --partial-dir), and (2)
          when --delay-updates was specified (see below).
          For  the  purposes  of  the   daemon-config's   "refuse
          options"  setting,  --partial-dir does not imply --par-
          tial.  This is so  that  a  refusal  of  the  --partial
          option  can be used to disallow the overwriting of des-
          tination files with a  partial  transfer,  while  still
          allowing the safer idiom provided by --partial-dir.
     --delay-updates
          This  option  puts the temporary file from each updated
          file into a holding directory  until  the  end  of  the
          transfer,  at which time all the files are renamed into
          place in rapid succession.  This attempts to  make  the
          updating of the files a little more atomic.  By default
          the files are placed into a directory named ".~tmp~" in
          each file's destination directory, but if you've speci-
          fied the --partial-dir option, that directory  will  be
          used  instead.   See  the comments in the --partial-dir
          section for a discussion of how this ".~tmp~" dir  will
          be  excluded  from the transfer, and what you can do if
          you want rsync to cleanup old ".~tmp~" dirs that  might
          be   lying   around.    Conflicts  with  --inplace  and
          --append.
          This option uses more memory on the receiving side (one
          bit per file transferred) and also requires enough free
SunOS 5.11           Last change: 28 Sep 2013                  61
          disk space on the receiving side to hold an  additional
          copy  of  all  the  updated  files.  Note also that you
          should not use an absolute path to --partial-dir unless
          (1)  there  is  no  chance  of  any of the files in the
          transfer having the same name (since  all  the  updated
          files  will  be put into a single directory if the path
          is absolute) and (2) there are no mount points  in  the
          hierarchy  (since the delayed updates will fail if they
          can't be renamed into place).
          See also the "atomic-rsync" perl script  in  the  "sup-
          port"  subdir for an update algorithm that is even more
          atomic (it uses --link-dest and a parallel hierarchy of
          files).
     -m, --prune-empty-dirs
          This  option  tells  the  receiving rsync to get rid of
          empty directories from the file-list, including  nested
          directories  that have no non-directory children.  This
          is useful for avoiding the creation of a bunch of  use-
          less  directories when the sending rsync is recursively
          scanning     a     hierarchy     of     files     using
          include/exclude/filter rules.
          Note  that  the  use  of  transfer  rules,  such as the
          --min-size option, does not affect what goes  into  the
          file  list,  and thus does not leave directories empty,
          even if none of the files  in  a  directory  match  the
          transfer rule.
          Because  the  file-list  is actually being pruned, this
          option also affects what directories get deleted when a
          delete  is active.  However, keep in mind that excluded
          files and directories can prevent existing  items  from
          being  deleted  due  to  an  exclude both hiding source
          files and protecting destination files.  See  the  per-
          ishable filter-rule option for how to avoid this.
          You  can  prevent the pruning of certain empty directo-
          ries from the file-list by  using  a  global  "protect"
          filter.   For  instance,  this option would ensure that
          the directory "emptydir" was kept in the file-list:
          --filter 'protect emptydir/'
          Here's an example that copies all .pdf files in a hier-
          archy, only creating the necessary destination directo-
          ries to hold the  .pdf  files,  and  ensures  that  any
SunOS 5.11           Last change: 28 Sep 2013                  62
          superfluous  files  and  directories in the destination
          are removed (note the hide  filter  of  non-directories
          being used instead of an exclude):
          rsync  -avm --del --include='*.pdf' -f 'hide,! */' src/
          dest
          If you didn't want to  remove  superfluous  destination
          files, the more time-honored options of "--include='*/'
          --exclude='*'"  would  work  fine  in  place   of   the
          hide-filter (if that is more natural to you).
     --progress
          This  option  tells  rsync to print information showing
          the progress of the transfer. This gives a  bored  user
          something  to  watch.   With a modern rsync this is the
          same as specifying --info=flist2,name,progress, but any
          user-supplied  settings  for  those  info  flags  takes
          precedence (e.g. "--info=flist0 --progress").
          While rsync is transferring a regular file, it  updates
          a progress line that looks like this:
                782448  63%  110.64kB/s    0:00:04
          In  this example, the receiver has reconstructed 782448
          bytes or 63% of  the  sender's  file,  which  is  being
          reconstructed at a rate of 110.64 kilobytes per second,
          and the transfer will finish in 4 seconds if  the  cur-
          rent rate is maintained until the end.
          These   statistics   can   be   misleading  if  rsync's
          delta-transfer algorithm is in use.   For  example,  if
          the  sender's  file consists of the basis file followed
          by additional data, the  reported  rate  will  probably
          drop dramatically when the receiver gets to the literal
          data, and the transfer will probably take  much  longer
          to finish than the receiver estimated as it was finish-
          ing the matched part of the file.
          When the file transfer  finishes,  rsync  replaces  the
          progress line with a summary line that looks like this:
                1,238,099 100%  146.38kB/s    0:00:08  (xfr#5, to-chk=169/396)
SunOS 5.11           Last change: 28 Sep 2013                  63
          In this example, the file was 1,238,099 bytes  long  in
          total,  the average rate of transfer for the whole file
          was 146.38 kilobytes per second over the 8 seconds that
          it took to complete, it was the 5th transfer of a regu-
          lar file during the current rsync  session,  and  there
          are 169 more files for the receiver to check (to see if
          they are up-to-date or not) remaining out  of  the  396
          total files in the file-list.
          In  an incremental recursion scan, rsync won't know the
          total number of files in the file-list until it reaches
          the  ends  of the scan, but since it starts to transfer
          files during the scan, it will display a line with  the
          text "ir-chk" (for incremental recursion check) instead
          of "to-chk" until the point that it knows the full size
          of  the  list,  at  which point it will switch to using
          "to-chk".  Thus, seeing "ir-chk" lets you know that the
          total count of files in the file list is still going to
          increase (and each time it does,  the  count  of  files
          left to check  will increase by the number of the files
          added to the list).
     -P   The -P option is equivalent  to  --partial  --progress.
          Its  purpose is to make it much easier to specify these
          two options for a long  transfer  that  may  be  inter-
          rupted.
          There  is  also  a --info=progress2 option that outputs
          statistics based on the  whole  transfer,  rather  than
          individual  files.   Use this flag without outputting a
          filename (e.g. avoid -v or specify --info=name0 if  you
          want to see how the transfer is doing without scrolling
          the screen with a lot of names.   (You  don't  need  to
          specify   the   --progress   option  in  order  to  use
          --info=progress2.)
     --password-file=FILE
          This option  allows  you  to  provide  a  password  for
          accessing  an  rsync  daemon via a file or via standard
          input if FILE is -.  The file should contain  just  the
          password  on  the  first  line  (all  other  lines  are
          ignored).  Rsync will exit with an  error  if  FILE  is
          world  readable  or if a root-run rsync command finds a
          non-root-owned file.
          This option does not supply  a  password  to  a  remote
          shell  transport  such as ssh; to learn how to do that,
          consult  the  remote   shell's   documentation.    When
SunOS 5.11           Last change: 28 Sep 2013                  64
          accessing  an  rsync daemon using a remote shell as the
          transport, this option only comes into effect after the
          remote  shell  finishes its authentication (i.e. if you
          have also specified a password in the  daemon's  config
          file).
     --list-only
          This  option  will  cause the source files to be listed
          instead of transferred.  This  option  is  inferred  if
          there  is a single source arg and no destination speci-
          fied, so its main uses are: (1) to turn a copy  command
          that  includes  a  destination  arg into a file-listing
          command, or (2) to be able to  specify  more  than  one
          source  arg (note: be sure to include the destination).
          Caution:  keep  in  mind  that  a  source  arg  with  a
          wild-card  is expanded by the shell into multiple args,
          so it is never safe to try to list such an arg  without
          using this option.  For example:
              rsync -av --list-only foo* dest/
          Starting   with   rsync  3.1.0,  the  sizes  output  by
          --list-only  are  affected  by   the   --human-readable
          option.  By default they will contain digit separators,
          but higher levels of readability will output the  sizes
          with  unit  suffixes.   Note also that the column width
          for the size output has increased from 11 to 14 charac-
          ters  for all human-readable levels.  Use --no-h if you
          want just digits in the sizes, and the old column width
          of 11 characters.
          Compatibility  note:   when requesting a remote listing
          of files from an rsync that is version 2.6.3 or  older,
          you  may encounter an error if you ask for a non-recur-
          sive listing.  This is because a file  listing  implies
          the  --dirs  option  w/o  --recursive, and older rsyncs
          don't have that option.  To avoid this problem,  either
          specify  the  --no-dirs  option  (if  you don't need to
          expand a directory's content), or turn on recursion and
          exclude    the    content    of    subdirectories:   -r
          --exclude='/*/*'.
     --bwlimit=RATE
          This option allows you to specify the maximum  transfer
          rate  for  the  data sent over the socket, specified in
          units per second.  The RATE value can be suffixed  with
SunOS 5.11           Last change: 28 Sep 2013                  65
User Commands                                            rsync(1)
          a  string  to  indicate a size multiplier, and may be a
          fractional value (e.g.  "--bwlimit=1.5m").  If no  suf-
          fix  is  specified,  the value will be assumed to be in
          units of 1024 bytes  (as  if  "K"  or  "KiB"  had  been
          appended).  See the --max-size option for a description
          of all the available suffixes. A value of  zero  speci-
          fies no limit.
          For backward-compatibility reasons, the rate limit will
          be rounded to the nearest KiB unit, so no rate  smaller
          than 1024 bytes per second is possible.
          Rsync  writes  data over the socket in blocks, and this
          option both limits the size of the  blocks  that  rsync
          writes,  and tries to keep the average transfer rate at
          the requested limit.  Some  "burstiness"  may  be  seen
          where  rsync writes out a block of data and then sleeps
          to bring the average rate into compliance.
          Due to the internal buffering of data,  the  --progress
          option  may  not  be an accurate reflection on how fast
          the data is being sent.  This is because some files can
          show  up as being rapidly sent when the data is quickly
          buffered, while other can show up as very slow when the
          flushing  of  the  output  buffer  occurs.  This may be
          fixed in a future version.
     --write-batch=FILE
          Record a file that can  later  be  applied  to  another
          identical destination with --read-batch. See the "BATCH
          MODE"   section   for    details,    and    also    the
          --only-write-batch option.
     --only-write-batch=FILE
          Works  like  --write-batch,  except that no updates are
          made on the destination system when creating the batch.
          This  lets you transport the changes to the destination
          system via some other means and then apply the  changes
          via --read-batch.
          Note that you can feel free to write the batch directly
          to some portable media: if this media fills to capacity
          before the end of the transfer, you can just apply that
          partial transfer to  the  destination  and  repeat  the
          whole  process  to get the rest of the changes (as long
          as you don't mind a partially updated destination  sys-
          tem while the multi-update cycle is happening).
SunOS 5.11           Last change: 28 Sep 2013                  66
          Also  note  that  you  only save bandwidth when pushing
          changes to a remote  system  because  this  allows  the
          batched  data  to  be diverted from the sender into the
          batch file without having to flow over the wire to  the
          receiver  (when pulling, the sender is remote, and thus
          can't write the batch).
     --read-batch=FILE
          Apply all of the changes stored in FILE, a file  previ-
          ously  generated  by  --write-batch.  If FILE is -, the
          batch data will be read from standard input.   See  the
          "BATCH MODE" section for details.
     --protocol=NUM
          Force  an  older  protocol version to be used.  This is
          useful for creating a batch  file  that  is  compatible
          with an older version of rsync.  For instance, if rsync
          2.6.4 is being used with the --write-batch option,  but
          rsync   2.6.3   is   what  will  be  used  to  run  the
          --read-batch option,  you  should  use  "--protocol=28"
          when  creating the batch file to force the older proto-
          col version to be used in the batch file (assuming  you
          can't upgrade the rsync on the reading system).
     --iconv=CONVERT_SPEC
          Rsync  can  convert  filenames  between  character sets
          using this option.  Using a CONVERT_SPEC of  "."  tells
          rsync  to  look  up  the  default character-set via the
          locale setting.  Alternately,  you  can  fully  specify
          what  conversion  to  do by giving a local and a remote
          charset   separated   by   a   comma   in   the   order
          --iconv=LOCAL,REMOTE,    e.g.    --iconv=utf8,iso88591.
          This order ensures that the option will stay  the  same
          whether  you're pushing or pulling files.  Finally, you
          can specify either --no-iconv or a CONVERT_SPEC of  "-"
          to  turn  off  any  conversion.  The default setting of
          this option is site-specific, and can also be  affected
          via the RSYNC_ICONV environment variable.
          For  a  list  of  what  charset  names your local iconv
          library supports, you can run "iconv --list".
          If you specify the --protect-args  option  (-s),  rsync
          will  translate  the  filenames you specify on the com-
          mand-line that are being sent to the remote host.   See
          also the --files-from option.
SunOS 5.11           Last change: 28 Sep 2013                  67
          Note  that rsync does not do any conversion of names in
          filter files (including include/exclude files).  It  is
          up  to  you  to  ensure that you're specifying matching
          rules that can match on both  sides  of  the  transfer.
          For  instance,  you  can  specify extra include/exclude
          rules if there are  filename  differences  on  the  two
          sides that need to be accounted for.
          When you pass an --iconv option to an rsync daemon that
          allows it, the daemon uses the charset specified in its
          "charset"  configuration  parameter  regardless  of the
          remote charset you actually pass.  Thus, you  may  feel
          free  to  specify  just  the local charset for a daemon
          transfer (e.g. --iconv=utf8).
     -4, --ipv4 or -6, --ipv6
          Tells rsync to prefer IPv4/IPv6 when creating  sockets.
          This only affects sockets that rsync has direct control
          over, such as the outgoing socket  when  directly  con-
          tacting an rsync daemon.  See also these options in the
          If rsync was complied without  support  for  IPv6,  the
          --ipv6  option will have no effect.  The --version out-
          put will tell you if this is the case.
     --checksum-seed=NUM
          Set the checksum seed to the integer NUM.  This 4  byte
          checksum  seed  is  included in each block and MD4 file
          checksum calculation (the more modern MD5  file  check-
          sums  don't  use a seed).  By default the checksum seed
          is generated by the server and defaults to the  current
          time()  .  This option is used to set a specific check-
          sum seed, which is useful for  applications  that  want
          repeatable  block  checksums,  or in the case where the
          user wants a more random checksum seed.  Setting NUM to
          0  causes rsync to use the default of time() for check-
          sum seed.
DAEMON OPTIONS
     The options allowed when starting an  rsync  daemon  are  as
     follows:
     --daemon
          This  tells  rsync  that it is to run as a daemon.  The
          daemon you start running may be accessed using an rsync
SunOS 5.11           Last change: 28 Sep 2013                  68
          client  using  the host::module or rsync://host/module/
          syntax.
          If standard input is a socket then  rsync  will  assume
          that  it  is  being  run  via  inetd, otherwise it will
          detach from the current terminal  and  become  a  back-
          ground  daemon.   The  daemon will read the config file
          (rsyncd.conf) on each connect  made  by  a  client  and
          respond    to    requests    accordingly.     See   the
          rsyncd.conf(5) man page for more details.
     --address
          run   as  a  daemon  with  the  --daemon  option.   The
          --address option allows you to specify  a  specific  IP
          address  (or  hostname) to bind to.  This makes virtual
          hosting  possible  in  conjunction  with  the  --config
          option.   See  also  the "address" global option in the
     --bwlimit=RATE
          rate  for  the  data  the daemon sends over the socket.
          The client can still specify a smaller --bwlimit value,
          but  no  larger  value will be allowed.  See the client
          version of this option (above) for some extra  details.
     --config=FILE
          This  specifies  an  alternate  config  file  than  the
          default.  This is only relevant when --daemon is speci-
          fied.   The default is /etc/rsyncd.conf unless the dae-
          mon is running over a  remote  shell  program  and  the
          remote  user  is  not  the super-user; in that case the
          default is rsyncd.conf in the current directory  (typi-
          cally $HOME).
     -M, --dparam=OVERRIDE
          This  option can be used to set a daemon-config parame-
          ter when starting up  rsync  in  daemon  mode.   It  is
          equivalent  to  adding  the parameter at the end of the
          global settings prior to the first module's definition.
          The parameter names can be specified without spaces, if
          you so desire.  For instance:
SunOS 5.11           Last change: 28 Sep 2013                  69
              rsync --daemon -M pidfile=/path/rsync.pid
     --no-detach
          When running as a daemon, this option  instructs  rsync
          to  not  detach itself and become a background process.
          This option is required when running as  a  service  on
          Cygwin, and may also be useful when rsync is supervised
          by a  program  such  as  daemontools  or  AIX's  System
          Resource  Controller.   --no-detach is also recommended
          when rsync is run under a debugger.  This option has no
          effect if rsync is run from inetd or sshd.
     --port=PORT
          This  specifies  an  alternate  TCP port number for the
          daemon to listen on rather than  the  default  of  873.
          See  also  the  "port" global option in the rsyncd.conf
          manpage.
     --log-file=FILE
          This option tells the rsync daemon  to  use  the  given
          log-file  name  instead of using the "log file" setting
          in the config file.
          FORMAT string instead of using the "log format" setting
          in the config file.  It also enables "transfer logging"
          unless the string is empty, in which case transfer log-
          ging is turned off.
     --sockopts
          This  overrides  the  socket  options  setting  in  the
          rsyncd.conf file and has the same syntax.
     -v, --verbose
          This  option  increases  the  amount of information the
          daemon logs during its startup phase.  After the client
          connects,   the   daemon's   verbosity  level  will  be
SunOS 5.11           Last change: 28 Sep 2013                  70
          controlled by the options that the client used and  the
          "max verbosity" setting in the module's config section.
          Tells rsync  to  prefer  IPv4/IPv6  when  creating  the
          incoming sockets that the rsync daemon will use to lis-
          ten for connections.   One  of  these  options  may  be
          required  in  older versions of Linux to work around an
          IPv6 bug in the kernel (if you see an "address  already
          in  use" error when nothing else is using the port, try
          specifying --ipv6 or --ipv4 when starting the  daemon).
     -h, --help
          When  specified after --daemon, print a short help page
          describing the options available for starting an  rsync
          daemon.
FILTER RULES
     The filter rules allow for flexible selection of which files
     to transfer (include) and which  files  to  skip  (exclude).
     The  rules  either directly specify include/exclude patterns
     or they specify a way to acquire more  include/exclude  pat-
     terns (e.g. to read them from a file).
     As the list of files/directories to transfer is built, rsync
     checks each name to  be  transferred  against  the  list  of
     include/exclude  patterns  in  turn,  and the first matching
     pattern is acted on:  if it is an exclude pattern, then that
     file is skipped; if it is an include pattern then that file-
     name is not skipped; if no matching pattern is  found,  then
     the filename is not skipped.
     Rsync builds an ordered list of filter rules as specified on
     the command-line.  Filter rules have the following syntax:
          RULE [PATTERN_OR_FILENAME]
          RULE,MODIFIERS [PATTERN_OR_FILENAME]
     You have your choice of using  either  short  or  long  RULE
     names,  as  described below.  If you use a short-named rule,
     the ',' separating the RULE from the MODIFIERS is  optional.
     The  PATTERN  or  FILENAME  that follows (when present) must
SunOS 5.11           Last change: 28 Sep 2013                  71
     come after either a single space or an underscore (_).  Here
     are the available rule prefixes:
          exclude, - specifies an exclude pattern.
          include, + specifies an include pattern.
          merge, . specifies a merge-file to read for more rules.
          dir-merge, : specifies a per-directory merge-file.
          hide, H specifies a pattern for hiding files  from  the
          transfer.
          show, S files that match the pattern are not hidden.
          protect,  P  specifies  a  pattern for protecting files
          from deletion.
          risk, R files that match the pattern are not protected.
          clear, ! clears the current include/exclude list (takes
          no arg)
     When rules are being read  from  a  file,  empty  lines  are
     ignored, as are comment lines that start with a "#".
     Note  that  the  --include/--exclude command-line options do
     not allow the full range of rule parsing as described  above
     -- they only allow the specification of include/exclude pat-
     terns plus a "!" token to clear the  list  (and  the  normal
     comment parsing when rules are read from a file).  If a pat-
     tern does not begin with "- " (dash, space) or "+  "  (plus,
     space), then the rule will be interpreted as if "+ " (for an
     include option) or "- " (for an exclude  option)  were  pre-
     fixed  to the string.  A --filter option, on the other hand,
     must always contain either a short or long rule name at  the
     start of the rule.
     Note  also  that  the  --filter,  --include,  and  --exclude
     options take one rule/pattern each. To  add  multiple  ones,
     you  can  repeat  the  options  on the command-line, use the
     merge-file  syntax  of   the   --filter   option,   or   the
     --include-from/--exclude-from options.
INCLUDE/EXCLUDE PATTERN RULES
     You  can  include  and  exclude files by specifying patterns
     using the "+", "-", etc. filter rules (as introduced in  the
     FILTER RULES section above).  The include/exclude rules each
     specify a pattern that is matched against the names  of  the
     files  that are going to be transferred.  These patterns can
     take several forms:
     o    if the pattern starts with a / then it is anchored to a
          particular spot in the hierarchy of files, otherwise it
          is matched against the end of the  pathname.   This  is
          similar  to  a  leading ^ in regular expressions.  Thus
          "/foo" would match a name of "foo" at either the  "root
          of  the  transfer"  (for  a  global  rule)  or  in  the
SunOS 5.11           Last change: 28 Sep 2013                  72
          merge-file's directory (for a per-directory rule).   An
          unqualified  "foo" would match a name of "foo" anywhere
          in the tree because the  algorithm  is  applied  recur-
          sively  from  the  top down; it behaves as if each path
          component gets a turn at being the end of the filename.
          Even  the unanchored "sub/foo" would match at any point
          in the hierarchy where  a  "foo"  was  found  within  a
          directory  named  "sub".   See the section on ANCHORING
          INCLUDE/EXCLUDE PATTERNS for a full discussion  of  how
          to  specify  a  pattern that matches at the root of the
          transfer.
     o    if the pattern ends with a / then it will only match  a
          directory, not a regular file, symlink, or device.
     o    rsync  chooses  between doing a simple string match and
          wildcard matching by checking if the  pattern  contains
          one  of  these three wildcard characters: '*', '?', and
     o    a '*' matches any  path  component,  but  it  stops  at
          slashes.
     o    use '**' to match anything, including slashes.
     o    a '?' matches any character except a slash (/).
     o    a  '['  introduces  a character class, such as [a-z] or
          [[:alpha:]].
     o    in a wildcard pattern,  a  backslash  can  be  used  to
          escape  a  wildcard character, but it is matched liter-
          ally when no wildcards are present.
     o    if the pattern contains a / (not counting a trailing /)
          or  a  "**",  then it is matched against the full path-
          name, including any leading directories. If the pattern
          doesn't  contain a / or a "**", then it is matched only
          against the final component of the filename.  (Remember
          that  the  algorithm  is  applied  recursively so "full
          filename" can actually be any portion of  a  path  from
          the starting directory on down.)
     o    a trailing "dir_name/***" will match both the directory
          (as if "dir_name/" had been specified)  and  everything
          in  the  directory (as if "dir_name/**" had been speci-
          fied).  This behavior was added in version 2.6.7.
     Note that, when using the --recursive (-r) option (which  is
     implied  by -a), every subcomponent of every path is visited
     from the top down, so include/exclude patterns  get  applied
SunOS 5.11           Last change: 28 Sep 2013                  73
     recursively  to  each  subcomponent's  full  name  (e.g.  to
     include  "/foo/bar/baz"   the   subcomponents   "/foo"   and
     "/foo/bar"  must  not  be  excluded).   The exclude patterns
     actually short-circuit the directory  traversal  stage  when
     rsync finds the files to send.  If a pattern excludes a par-
     ticular parent directory, it can  render  a  deeper  include
     pattern  ineffectual  because  rsync did not descend through
     that excluded section of the hierarchy.   This  is  particu-
     larly  important  when  using  a  trailing  '*'  rule.   For
     instance, this won't work:
          + /some/path/this-file-will-not-be-found
          + /file-is-included
     This fails because the parent directory "some"  is  excluded
     by  the  '*' rule, so rsync never visits any of the files in
     the "some" or "some/path" directories.  One solution  is  to
     ask  for  all directories in the hierarchy to be included by
     using a single rule: "+ */" (put it somewhere before the  "-
     *"  rule),  and  perhaps  use the --prune-empty-dirs option.
     Another solution is to add specific include  rules  for  all
     the parent dirs that need to be visited.  For instance, this
     set of rules works fine:
          + /some/
          + /some/path/
          + /some/path/this-file-is-found
          + /file-also-included
     Here are some examples of exclude/include matching:
     o    "- *.o" would exclude all names matching *.o
     o    "- /foo" would exclude a file (or directory) named  foo
          in the transfer-root directory
     o    "- foo/" would exclude any directory named foo
     o    "-  /foo/*/bar"  would exclude any file named bar which
          is at two levels below a directory  named  foo  in  the
     o    "- /foo/**/bar" would exclude any file named bar two or
          more levels below a directory named foo in  the  trans-
          fer-root directory
     o    The  combination  of  "+  */", "+ *.c", and "- *" would
          include all directories and C source files but  nothing
SunOS 5.11           Last change: 28 Sep 2013                  74
          else (see also the --prune-empty-dirs option)
     o    The  combination  of "+ foo/", "+ foo/bar.c", and "- *"
          would include only the foo directory and foo/bar.c (the
          foo  directory  must be explicitly included or it would
          be excluded by the "*")
     The following modifiers are accepted after a "+" or "-":
     o    A / specifies that the include/exclude rule  should  be
          matched  against  the  absolute pathname of the current
          item.  For example, "-/ /etc/passwd" would exclude  the
          passwd  file  any  time  the transfer was sending files
          from the "/etc" directory, and  "-/  subdir/foo"  would
          always  exclude  "foo"  when it is in a dir named "sub-
          dir", even if "foo" is  at  the  root  of  the  current
          transfer.
     o    A  !  specifies  that  the  include/exclude should take
          effect if the pattern fails to  match.   For  instance,
          "-! */" would exclude all non-directories.
     o    A C is used to indicate that all the global CVS-exclude
          rules should be inserted as excludes in  place  of  the
          "-C".  No arg should follow.
     o    An  s  is used to indicate that the rule applies to the
          sending side.  When a rule affects the sending side, it
          prevents  files from being transferred.  The default is
          for   a   rule   to   affect    both    sides    unless
          --delete-excluded  was specified, in which case default
          rules become sender-side only.  See also the  hide  (H)
          and show (S) rules, which are an alternate way to spec-
          ify sending-side includes/excludes.
     o    An r is used to indicate that the rule applies  to  the
          receiving  side.   When  a  rule  affects the receiving
          side, it prevents files from being deleted.  See the  s
          modifier  for  more info.  See also the protect (P) and
          risk (R) rules, which are an alternate way  to  specify
          receiver-side includes/excludes.
     o    A  p  indicates that a rule is perishable, meaning that
          it is ignored in directories that  are  being  deleted.
          For  instance,  the  -C  option's  default  rules  that
          exclude things like "CVS" and "*.o" are marked as  per-
          ishable,  and  will  not  prevent  a directory that was
          removed on the source from being deleted on the  desti-
          nation.
SunOS 5.11           Last change: 28 Sep 2013                  75
MERGE-FILE FILTER RULES
     You can merge whole files into your filter rules by specify-
     ing either a merge (.) or a dir-merge (:)  filter  rule  (as
     introduced in the FILTER RULES section above).
     There are two kinds of merged files -- single-instance ('.')
     and per-directory (':').  A single-instance  merge  file  is
     read  one time, and its rules are incorporated into the fil-
     ter list in the place of the "."  rule.   For  per-directory
     merge  files,  rsync  will scan every directory that it tra-
     verses for the named file, merging  its  contents  when  the
     file exists into the current list of inherited rules.  These
     per-directory rule files must be created on the sending side
     because it is the sending side that is being scanned for the
     available files to transfer.  These rule files may also need
     to  be transferred to the receiving side if you want them to
     affect what files don't get deleted (see PER-DIRECTORY RULES
     AND DELETE below).
     Some examples:
          merge /etc/rsync/default.rules
          dir-merge .per-dir-filter
          dir-merge,n- .non-inherited-per-dir-excludes
          :n- .non-inherited-per-dir-excludes
     The  following  modifiers  are  accepted  after  a  merge or
     dir-merge rule:
     o    A - specifies that the  file  should  consist  of  only
          exclude patterns, with no other rule-parsing except for
          in-file comments.
     o    A + specifies that the  file  should  consist  of  only
          include patterns, with no other rule-parsing except for
          in-file comments.
     o    A C is a way to specify that the file should be read in
          a  CVS-compatible  manner.  This turns on 'n', 'w', and
          '-', but also allows the list-clearing token (!) to  be
          specified.  If no filename is provided, ".cvsignore" is
          assumed.
     o    A e will exclude the merge-file name from the transfer;
          e.g.   "dir-merge,e  .rules" is like "dir-merge .rules"
          and "- .rules".
     o    An n specifies that the rules are not inherited by sub-
          directories.
     o    A   w  specifies  that  the  rules  are  word-split  on
SunOS 5.11           Last change: 28 Sep 2013                  76
          whitespace instead of the normal line-splitting.   This
          also  turns  off  comments.  Note: the space that sepa-
          rates the prefix from the rule is treated specially, so
          "-  foo  +  bar"  is parsed as two rules (assuming that
          prefix-parsing wasn't also disabled).
     o    You may also specify any of the modifiers for  the  "+"
          or  "-"  rules  (above) in order to have the rules that
          are read in from the file default to having that  modi-
          fier set (except for the ! modifier, which would not be
          useful).  For instance, "merge,-/  .excl"  would  treat
          the  contents of .excl as absolute-path excludes, while
          "dir-merge,s .filt" and ":sC" would each make all their
          per-directory rules apply only on the sending side.  If
          the merge rule specifies sides to affect (via the s  or
          r  modifier  or  both), then the rules in the file must
          not specify sides (via a modifier or a rule prefix such
          as hide).
     Per-directory  rules  are inherited in all subdirectories of
     the directory where the merge-file was found unless the  'n'
     modifier  was  used.  Each subdirectory's rules are prefixed
     to the inherited per-directory rules from its parents, which
     gives  the newest rules a higher priority than the inherited
     rules.  The  entire  set  of  dir-merge  rules  are  grouped
     together  in the spot where the merge-file was specified, so
     it is possible to override dir-merge rules via a  rule  that
     got specified earlier in the list of global rules.  When the
     list-clearing rule ("!") is read from a per-directory  file,
     it  only  clears  the  inherited rules for the current merge
     file.
     Another way to prevent a single rule from a  dir-merge  file
     from  being  inherited is to anchor it with a leading slash.
     Anchored rules in a per-directory merge-file are relative to
     the  merge-file's  directory, so a pattern "/foo" would only
     match the file "foo" in the directory  where  the  dir-merge
     filter file was found.
     Here's an example filter file which you'd specify via --fil-
     ter=". file":
          merge /home/user/.global-filter
          - *.gz
          dir-merge .rules
          + *.[ch]
          - *.o
     This will merge the contents of the  /home/user/.global-fil-
     ter  file  at  the  start  of  the  list  and also turns the
SunOS 5.11           Last change: 28 Sep 2013                  77
     ".rules" filename into a  per-directory  filter  file.   All
     rules  read in prior to the start of the directory scan fol-
     low the global anchoring rules (i.e. a leading slash matches
     at the root of the transfer).
     If  a per-directory merge-file is specified with a path that
     is a parent directory of the first transfer directory, rsync
     will  scan  all  the parent dirs from that starting point to
     the transfer directory for the indicated per-directory file.
     For instance, here is a common filter (see -F):
          --filter=': /.rsync-filter'
     That  rule tells rsync to scan for the file .rsync-filter in
     all directories from the root down through the parent direc-
     tory of the transfer prior to the start of the normal direc-
     tory scan of the file in the directories that are sent as  a
     part  of the transfer.  (Note: for an rsync daemon, the root
     is always the same as the module's "path".)
     Some examples of this pre-scanning for per-directory files:
          rsync -avF /src/path/ /dest/dir
          rsync -av --filter=':  ../../.rsync-filter'  /src/path/
          /dest/dir
          rsync   -av   --filter=':   .rsync-filter'   /src/path/
          /dest/dir
     The first two commands above will look  for  ".rsync-filter"
     in  "/" and "/src" before the normal scan begins looking for
     the file in "/src/path" and its  subdirectories.   The  last
     command  avoids  the  parent-dir scan and only looks for the
     ".rsync-filter" files in each directory that is  a  part  of
     the transfer.
     If  you  want  to  include the contents of a ".cvsignore" in
     your patterns, you should use the rule ":C", which creates a
     dir-merge  of  the .cvsignore file, but parsed in a CVS-com-
     patible manner.  You  can  use  this  to  affect  where  the
     --cvs-exclude  (-C)  option's inclusion of the per-directory
     .cvsignore file gets placed into your rules by  putting  the
     ":C"  wherever you like in your filter rules.  Without this,
     rsync would add the dir-merge rule for the  .cvsignore  file
     at the end of all your other rules (giving it a lower prior-
     ity than your command-line rules).  For example:
          cat <<EOT | rsync -avC --filter='. -' a/ b
          + foo.o
          :C
          - *.old
SunOS 5.11           Last change: 28 Sep 2013                  78
          EOT
          rsync -avC --include=foo.o -f :C --exclude='*.old' a/ b
     Both  of  the  above rsync commands are identical.  Each one
     will merge all the per-directory  .cvsignore  rules  in  the
     middle  of  the  list  rather  than at the end.  This allows
     their dir-specific rules to supersede the rules that  follow
     the  :C  instead of being subservient to all your rules.  To
     affect the other CVS exclude rules (i.e. the default list of
     exclusions,  the contents of $HOME/.cvsignore, and the value
     of $CVSIGNORE) you should omit the  -C  command-line  option
     and  instead insert a "-C" rule into your filter rules; e.g.
     "--filter=-C".
LIST-CLEARING FILTER RULE
     You can clear the current include/exclude list by using  the
     "!"  filter  rule (as introduced in the FILTER RULES section
     above).  The "current" list is either  the  global  list  of
     rules  (if  the rule is encountered while parsing the filter
     options) or a set of per-directory rules (which  are  inher-
     ited  in  their own sub-list, so a subdirectory can use this
     to clear out the parent's rules).
ANCHORING INCLUDE/EXCLUDE PATTERNS
     As mentioned earlier, global  include/exclude  patterns  are
     anchored  at  the  "root  of  the  transfer"  (as opposed to
     per-directory  patterns,   which   are   anchored   at   the
     merge-file's  directory).  If you think of the transfer as a
     subtree  of  names  that  are  being  sent  from  sender  to
     receiver,  the  transfer-root is where the tree starts to be
     duplicated in the destination directory.  This root  governs
     where patterns that start with a / match.
     Because  the  matching  is  relative  to  the transfer-root,
     changing the trailing slash on a  source  path  or  changing
     your  use of the --relative option affects the path you need
     to use in your matching (in addition to changing how much of
     the  file  tree is duplicated on the destination host).  The
     following examples demonstrate this.
     Let's say that we want to match two source files,  one  with
     an  absolute path of "/home/me/foo/bar", and one with a path
     of "/home/you/bar/baz".  Here is  how  the  various  command
     choices differ for a 2-source transfer:
          Example cmd: rsync -a /home/me /home/you /dest
          +/- pattern: /me/foo/bar
          +/- pattern: /you/bar/baz
          Target file: /dest/me/foo/bar
          Target file: /dest/you/bar/baz
SunOS 5.11           Last change: 28 Sep 2013                  79
          Example cmd: rsync -a /home/me/ /home/you/ /dest
          +/- pattern: /foo/bar               (note missing "me")
          +/-  pattern:  /bar/baz                 (note   missing
          "you")
          Target file: /dest/foo/bar
          Target file: /dest/bar/baz
          Example  cmd:  rsync  -a --relative /home/me/ /home/you
          /dest
          +/- pattern: /home/me/foo/bar       (note full path)
          +/- pattern: /home/you/bar/baz      (ditto)
          Target file: /dest/home/me/foo/bar
          Target file: /dest/home/you/bar/baz
          Example cmd: cd /home; rsync -a --relative me/foo  you/
          /dest
          +/-  pattern:  /me/foo/bar       (starts  at  specified
          path)
          +/- pattern: /you/bar/baz     (ditto)
     The easiest way to see what name you  should  filter  is  to
     just  look at the output when using --verbose and put a / in
     front of the name (use the --dry-run option  if  you're  not
     yet ready to copy any files).
PER-DIRECTORY RULES AND DELETE
     Without  a delete option, per-directory rules are only rele-
     vant on the sending side, so you can feel  free  to  exclude
     the  merge  files themselves without affecting the transfer.
     To make this easy, the 'e' modifier adds  this  exclude  for
     you, as seen in these two equivalent commands:
          rsync    -av    --filter=':    .excl'   --exclude=.excl
          host:src/dir /dest
          rsync -av --filter=':e .excl' host:src/dir /dest
     However, if you want to do a delete on  the  receiving  side
     AND  you  want some files to be excluded from being deleted,
     you'll need to be sure that the receiving  side  knows  what
     files  to  exclude.   The  easiest  way  is  to  include the
     per-directory  merge  files  in   the   transfer   and   use
     --delete-after, because this ensures that the receiving side
     gets all the same exclude rules as the sending  side  before
     it tries to delete anything:
SunOS 5.11           Last change: 28 Sep 2013                  80
          rsync -avF --delete-after host:src/dir /dest
     However,  if the merge files are not a part of the transfer,
     you'll need to either  specify  some  global  exclude  rules
     (i.e.  specified  on  the  command  line), or you'll need to
     maintain your own per-directory merge files on the receiving
     side.   An  example  of  the  first is this (assume that the
     remote .rules files exclude themselves):
     rsync -av --filter=': .rules' --filter='. /my/extra.rules'
        --delete host:src/dir /dest
     In the above example the extra.rules file  can  affect  both
     sides  of  the transfer, but (on the sending side) the rules
     are subservient to the rules merged from  the  .rules  files
     because  they  were  specified after the per-directory merge
     rule.
     In one final example,  the  remote  side  is  excluding  the
     .rsync-filter  files  from  the transfer, but we want to use
     our own .rsync-filter files to control what gets deleted  on
     the receiving side.  To do this we must specifically exclude
     the per-directory  merge  files  (so  that  they  don't  get
     deleted)  and then put rules into the local files to control
     what else should not get deleted.  Like one  of  these  com-
     mands:
         rsync -av --filter=':e /.rsync-filter' --delete \
             host:src/dir /dest
         rsync -avFF --delete host:src/dir /dest
BATCH MODE
     Batch  mode  can be used to apply the same set of updates to
     many identical systems. Suppose one  has  a  tree  which  is
     replicated  on  a number of hosts.  Now suppose some changes
     have been made to this source tree and those changes need to
     be  propagated to the other hosts. In order to do this using
     batch mode, rsync is run  with  the  write-batch  option  to
     apply the changes made to the source tree to one of the des-
     tination trees.  The write-batch  option  causes  the  rsync
     client to store in a "batch file" all the information needed
     to repeat this operation against other,  identical  destina-
     tion trees.
     Generating  the  batch file once saves having to perform the
     file status, checksum, and data block generation  more  than
     once  when  updating  multiple  destination trees. Multicast
     transport protocols can be used to transfer the batch update
     files  in parallel to many hosts at once, instead of sending
SunOS 5.11           Last change: 28 Sep 2013                  81
     the same data to every host individually.
     To apply the recorded changes to another  destination  tree,
     run rsync with the read-batch option, specifying the name of
     the same  batch  file,  and  the  destination  tree.   Rsync
     updates the destination tree using the information stored in
     the batch file.
     For your convenience, a script file is also created when the
     write-batch  option  is  used:  it will be named the same as
     the batch file with ".sh" appended.  This script  file  con-
     tains  a  command-line  suitable  for updating a destination
     tree using the associated batch file.  It  can  be  executed
     using a Bourne (or Bourne-like) shell, optionally passing in
     an alternate destination tree pathname which  is  then  used
     instead  of  the  original destination path.  This is useful
     when the destination tree path on the current  host  differs
     from the one used to create the batch file.
     Examples:
          $    rsync   --write-batch=foo   -a   host:/source/dir/
          /adest/dir/
          $ scp foo* remote:
          $ ssh remote ./foo.sh /bdest/dir/
          $ rsync --write-batch=foo -a /source/dir/ /adest/dir/
          $ ssh remote rsync --read-batch=- -a /bdest/dir/ <foo
     In these examples, rsync is used to update /adest/dir/  from
     /source/dir/ and the information to repeat this operation is
     stored in "foo" and "foo.sh".  The  host  "remote"  is  then
     updated  with  the  batched  data  going  into the directory
     /bdest/dir.   The  differences  between  the  two   examples
     reveals  some  of  the  flexibility you have in how you deal
     with batches:
     o    The first example shows that the initial  copy  doesn't
          have to be local -- you can push or pull data to/from a
          remote host using either  the  remote-shell  syntax  or
          rsync daemon syntax, as desired.
     o    The first example uses the created "foo.sh" file to get
          the right rsync options  when  running  the  read-batch
          command on the remote host.
     o    The  second  example  reads the batch data via standard
          input so that the batch file doesn't need to be  copied
          to  the  remote machine first.  This example avoids the
          foo.sh script because  it  needed  to  use  a  modified
SunOS 5.11           Last change: 28 Sep 2013                  82
          --read-batch option, but you could edit the script file
          if you wished to make use of it (just be sure  that  no
          other  option  is trying to use standard input, such as
          the "--exclude-from=-" option).
     Caveats:
     The read-batch option expects the destination tree  that  it
     is updating to be identical to the destination tree that was
     used to create the batch update fileset.  When a  difference
     between  the  destination  trees  is  encountered the update
     might be discarded with a warning (if the file appears to be
     up-to-date  already) or the file-update may be attempted and
     then, if the file fails to verify, the update discarded with
     an  error.   This  means  that it should be safe to re-run a
     read-batch operation if the command got interrupted.  If you
     wish  to  force  the  batched-update  to always be attempted
     regardless of the file's size and date, use  the  -I  option
     (when  reading the batch).  If an error occurs, the destina-
     tion tree will probably be in a partially updated state.  In
     that case, rsync can be used in its regular (non-batch) mode
     of operation to fix up the destination tree.
     The rsync version used on all destinations must be at  least
     as  new  as  the one used to generate the batch file.  Rsync
     will die with an error if the protocol version in the  batch
     file  is too new for the batch-reading rsync to handle.  See
     also the --protocol option for a way to  have  the  creating
     rsync  generate  a batch file that an older rsync can under-
     stand.  (Note that batch files  changed  format  in  version
     2.6.3,  so  mixing  versions older than that with newer ver-
     sions will not work.)
     When reading a batch file, rsync will  force  the  value  of
     certain  options  to match the data in the batch file if you
     didn't set them to the same as  the  batch-writing  command.
     Other  options  can  (and  should) be changed.  For instance
     --write-batch  changes  to  --read-batch,  --files-from   is
     dropped,  and  the  --filter/--include/--exclude options are
     not needed unless one of the --delete options is  specified.
     The  code that creates the BATCH.sh file transforms any fil-
     ter/include/exclude options  into  a  single  list  that  is
     appended  as a "here" document to the shell script file.  An
     advanced user can use this to modify the exclude list  if  a
     change  in what gets deleted by --delete is desired.  A nor-
     mal user can ignore this  detail  and  just  use  the  shell
     script  as  an  easy way to run the appropriate --read-batch
     command for the batched data.
SunOS 5.11           Last change: 28 Sep 2013                  83
     The original batch mode in rsync was based on "rsync+",  but
     the latest version uses a new implementation.
SYMBOLIC LINKS
     Three  basic  behaviors are possible when rsync encounters a
     symbolic link in the source directory.
     By default, symbolic links are not transferred  at  all.   A
     message  "skipping non-regular" file is emitted for any sym-
     links that exist.
     If --links is specified, then symlinks  are  recreated  with
     the  same  target  on  the destination.  Note that --archive
     implies --links.
     If --copy-links is specified, then symlinks are  "collapsed"
     by copying their referent, rather than the symlink.
     Rsync  can  also  distinguish  "safe"  and "unsafe" symbolic
     links.  An example where this might be used is  a  web  site
     mirror  that  wishes to ensure that the rsync module that is
     copied does not include symbolic links to /etc/passwd in the
     public  section of the site.  Using --copy-unsafe-links will
     cause any links to be copied as the file they  point  to  on
     the destination.  Using --safe-links will cause unsafe links
     to be omitted  altogether.   (Note  that  you  must  specify
     --links for --safe-links to have any effect.)
     Symbolic  links  are  considered unsafe if they are absolute
     symlinks (start with /), empty, or if  they  contain  enough
     ".."   components to ascend from the directory being copied.
     Here's a summary of how the symlink options are interpreted.
     The  list  is in order of precedence, so if your combination
     of options isn't mentioned, use the first  line  that  is  a
     complete subset of your options:
     --copy-links
          Turn  all  symlinks  into normal files (leaving no sym-
          links for any other options to affect).
     --links --copy-unsafe-links
          Turn all unsafe symlinks into files and  duplicate  all
          safe symlinks.
     --copy-unsafe-links
          Turn  all  unsafe symlinks into files, noisily skip all
          safe symlinks.
     --links --safe-links
          Duplicate safe symlinks and skip unsafe ones.
SunOS 5.11           Last change: 28 Sep 2013                  84
     --links
          Duplicate all symlinks.
DIAGNOSTICS
     rsync occasionally produces error messages that may  seem  a
     little  cryptic. The one that seems to cause the most confu-
     sion is "protocol version mismatch -- is your shell clean?".
     This  message  is  usually caused by your startup scripts or
     remote shell facility  producing  unwanted  garbage  on  the
     stream  that  rsync  is  using for its transport. The way to
     diagnose this problem is to run your remote shell like this:
          ssh remotehost /bin/true > out.dat
     then  look  at  out.dat.  If everything is working correctly
     then out.dat should be a zero length file. If you  are  get-
     ting  the above error from rsync then you will probably find
     that out.dat contains some text or data. Look  at  the  con-
     tents  and  try  to  work out what is producing it. The most
     common cause is incorrectly configured shell startup scripts
     (such  as .cshrc or .profile) that contain output statements
     for non-interactive logins.
     If you are having trouble debugging  filter  patterns,  then
     try  specifying  the -vv option.  At this level of verbosity
     rsync will show why each  individual  file  is  included  or
     excluded.
EXIT VALUES
     0    Success
     1    Syntax or usage error
     2    Protocol incompatibility
     3    Errors selecting input/output files, dirs
     4    Requested  action not supported: an attempt was made to
          manipulate 64-bit files on a platform that cannot  sup-
          port them; or an option was specified that is supported
          by the client and not by the server.
     5    Error starting client-server protocol
     6    Daemon unable to append to log-file
     10   Error in socket I/O
     11   Error in file I/O
SunOS 5.11           Last change: 28 Sep 2013                  85
     12   Error in rsync protocol data stream
     13   Errors with program diagnostics
     14   Error in IPC code
     20   Received SIGUSR1 or SIGINT
     21   Some error returned by waitpid()
     22   Error allocating core memory buffers
     23   Partial transfer due to error
     24   Partial transfer due to vanished source files
     25   The --max-delete limit stopped deletions
     30   Timeout in data send/receive
     35   Timeout waiting for daemon connection
ENVIRONMENT VARIABLES
     CVSIGNORE
          The  CVSIGNORE  environment  variable  supplements  any
          ignore   patterns   in   .cvsignore   files.   See  the
          --cvs-exclude option for more details.
     RSYNC_ICONV
          Specify a default --iconv setting using  this  environ-
          ment variable. (First supported in 3.0.0.)
     RSYNC_PROTECT_ARGS
          Specify a non-zero numeric value if you want the --pro-
          tect-args option to be enabled by default,  or  a  zero
          value  to  make  sure  that  it is disabled by default.
          (First supported in 3.1.0.)
     RSYNC_RSH
          The RSYNC_RSH environment variable allows you to  over-
          ride the default shell used as the transport for rsync.
          Command line options are permitted  after  the  command
          name, just as in the -e option.
     RSYNC_PROXY
          The  RSYNC_PROXY environment variable allows you to re-
          direct your rsync client to use a web proxy  when  con-
          necting  to  a rsync daemon. You should set RSYNC_PROXY
          to a hostname:port pair.
     RSYNC_PASSWORD
SunOS 5.11           Last change: 28 Sep 2013                  86
          Setting RSYNC_PASSWORD to the required password  allows
          you  to run authenticated rsync connections to an rsync
          daemon without user intervention. Note that  this  does
          not  supply a password to a remote shell transport such
          as ssh; to learn how to do  that,  consult  the  remote
     USER or LOGNAME
          The  USER  or LOGNAME environment variables are used to
          determine the default username sent to an rsync daemon.
          If neither is set, the username defaults to "nobody".
     HOME The  HOME  environment  variable  is  used  to find the
          user's default .cvsignore file.
FILES
     /etc/rsyncd.conf or rsyncd.conf
ATTRIBUTES
     See  attributes(5)  for  descriptions   of   the   following
     attributes:
     |ATTRIBUTE TYPE | ATTRIBUTE VALUE  |
     |Availability   | network/rsync    |
     |Stability      | Volatile         |
SEE ALSO
     rsyncd.conf(5)
BUGS
     times are transferred as *nix time_t values
     When  transferring  to  FAT  filesystems  rsync  may re-sync
     unmodified files.  See the comments on  the  --modify-window
     option.
     file  permissions,  devices,  etc. are transferred as native
     numerical values
     see also the comments on the --delete option
     Please    report    bugs!    See    the    web    site    at
     http://rsync.samba.org/
VERSION
     This man page is current for version 3.1.0 of rsync.
SunOS 5.11           Last change: 28 Sep 2013                  87
INTERNAL OPTIONS
     The  options  --server  and  --sender are used internally by
     rsync, and should never be typed by a user under normal cir-
     cumstances.   Some  awareness of these options may be needed
     in certain scenarios, such as when setting up a  login  that
     can  only  run  an rsync command.  For instance, the support
     directory of the rsync distribution has  an  example  script
     named  rrsync (for restricted rsync) that can be used with a
     restricted ssh login.
CREDITS
     rsync is distributed under the GNU General  Public  License.
     See the file COPYING for details.
     A  WEB  site  is  available at http://rsync.samba.org/.  The
     site includes an FAQ-O-Matic which may cover questions unan-
     swered by this manual page.
     The      primary      ftp      site     for     rsync     is
     ftp://rsync.samba.org/pub/rsync.
     We would be delighted to hear from you if you like this pro-
     gram.      Please     contact     the     mailing-list    at
     rsync@lists.samba.org.
     This program uses the  excellent  zlib  compression  library
     written by Jean-loup Gailly and Mark Adler.
THANKS
     Special  thanks  go  out to: John Van Essen, Matt McCutchen,
     Wesley W. Terpstra, David  Dykstra,  Jos  Backus,  Sebastian
     Krahmer,  Martin  Pool,  and our gone-but-not-forgotten com-
     padre, J.W. Schultz.
     Thanks also to Richard Brent, Brendan  Mackay,  Bill  Waite,
     Stephen  Rothwell and David Bell.  I've probably missed some
     people, my apologies if I have.
AUTHOR
     rsync was originally written by  Andrew  Tridgell  and  Paul
     Mackerras.  Many people have later contributed to it.  It is
     currently maintained by Wayne Davison.
     Mailing lists for support and development are  available  at
     http://lists.samba.org
NOTES
     This   software   was   built   from   source  available  at
     https://java.net/projects/solaris-userland.   The   original
     community       source       was       downloaded       from
SunOS 5.11           Last change: 28 Sep 2013                  88
     http://rsync.samba.org/ftp/rsync/src/rsync-3.1.0.tar.gz
     Further information about this software can be found on  the
     open source community website at http://rsync.samba.org/.
SunOS 5.11           Last change: 28 Sep 2013                  89
