man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
ipc.h(3HEAD)
Name
ipc.h, ipc - XSI interprocess communication access structure
Synopsis
#include <sys/ipc.h>
Description
The <sys/ipc.h> header is used by three mechanisms for interprocess communication (IPC): messages, semaphores, and shared memory. All use a common structure type, ipc_perm, to pass information used in determining permission to perform an IPC operation.
The ipc_perm structure contains the following members:
uid_t  uid     /* owner's user ID */
gid_t  gid     /* owner's group ID */
uid_t  cuid    /* creator's user ID */
gid_t  cgid    /* creator's group ID */
mode_t mode    /* read/write permission
The uid_t, gid_t, mode_t, and key_t types are defined as described in <sys/types.h>. See types.h(3HEAD).
Definitions are provided for the constants listed below.
Mode bits:
IPC_CREAT
Create entry if key does not exist.
IPC_EXCL
Fail if key exists.
IPC_NOWAIT
Error if request must wait.
Keys:
IPC_PRIVATE
Private key.
Control commands:
IPC_RMID
Remove identifier.
IPC_SET
Set options.
IPC_STAT
Get options.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
ftok(3C), types.h(3HEAD), attributes(5), standards(5)
