#include <netinet/tcp.h>
The <netinet/tcp.h> header defines the following macro for use as a socket option at the IPPROTO_TCP level:
Avoid coalescing of small segments.
The macro is defined in the header. The implementation need not allow the value of the option to be set with setsockopt() or retrieved with getsockopt().
getsockopt(3XNET), socket.h(3HEAD), attributes(5), standards(5) , tcp(7P)
