man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
mman(3HEAD)
Name
mman.h, mman - memory management declarations
Synopsis
#include <sys/mman.h>
Description
The <sys/mman.h> header supports the following options:
  • the Memory Mapped Files option
  • the Shared Memory Objects option
  • the Process Memory Locking option
  • the Memory Protection option
  • the Synchronized Input and Output option
For Memory Mapped Files and Shared Memory Objects options, the following protection options are defined:
PROT_READ
Page can be read.
PROT_WRITE
Page can be written.
PROT_EXEC
Page can be executed.
PROT_NONE
Page cannot be accessed.
The following flag options are defined:
MAP_SHARED
Share changes.
MAP_PRIVATE
Changes are private.
MAP_FIXED
Interpret addr exactly.
The flags immediately following are defined for msync(). See msync(3C).
MS_ASYNC
Perform asynchronous writes.
MS_SYNC
Perform synchronous writes.
MS_INVALIDATE
Invalidate mappings.
The symbolic constants immediately following are defined for the mlockall() function. See mlockall(3C).
MCL_CURRENT
Lock currently mapped pages.
MCL_FUTURE
Lock pages that become mapped.
The symbolic constant MAP_FAILED is defined to indicate a failure from the mmap() function. See mmap(2).
The mode_t, off_t, and size_t types are be defined as described in <sys/types.h>. See types(3HEAD).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
mmap(2), mprotect(2), munmap(2), madvise(3C), mlock(3C), mlockall(3C), msync(3C), shm_open(3C), shm_unlink(3C), attributes(5), standards(5)
