man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
netdb.h(3HEAD)
Name
netdb.h, netdb - definitions for network database operations
Synopsis
#include <netdb.h>
Description
The <netdb.h> header defines the type in_port_t and the type in_addr_t as described in in.h(3HEAD).
The <netdb.h> header defines the hostent structure that includes the following members:
char *h_name          /* official name of the host */
char **h_aliases      /* pointer to an array of pointers to
                         alternative host names, terminated
                         by a null pointer */
int  h_addrtype       /* address type */
int  h_length         /* length, in bytes, of the address */
char **h_addr_list    /* pointer to an array of pointers to
                         network addresses (in network byte
                         order)for the host, terminated by a
                         null pointer */
The <netdb.h> header defines the netent structure that includes the following members:
char      *n_name     /* official, fully-qualified */
                         (including the domain) name
                         of the network */
char      **n_aliases /* pointer to an array of pointers to
                         alternative network names, terminated */
int       n_addrtype  /* the address type of the network */
in_addr_t n_net       /* the network number, in host byte order */
The <netdb.h> header defines the protoent structure that includes the following members:
char *p_name         /* official name of the protocol */
char **p_aliases     /* pointer to an array of pointers to
                        alternative protocol names, terminated
int  p_proto         /* protocol number */
The <netdb.h> header defines the servent structure that includes the following members:
char *s_name         /* oficial name of the service */
char **s_aliases     /* pointer to an array of pointers to
                        alternativeservice names, terminated by
                        a null pointer */
int  s_port          /* port number at which the service
                        resides, in network byte order */
char *s_proto        /* name of the protocol to use when
                        contacting the service */
The <netdb.h> header defines the macro IPPORT_RESERVED with the value of the highest reserved Internet port number.
The <netdb.h> header provides a declaration for h_errno:
extern int h_errno;
The <netdb.h> header defines the following macros for use as error values for gethostbyaddr() and gethostbyname():
HOST_NOT_FOUND
NO_DATA
NO_RECOVERY
TRY_AGAIN
Inclusion of the <netdb.h> header may also make visible all symbols from in.h(3HEAD).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
Intro(3), endhostent(3NSL) , endhostent(3XNET), endnetent (3SOCKET), endnetent(3XNET), endprotoent(3SOCKET), endprotoent(3XNET), endservent(3SOCKET), endservent(3XNET), in.h(3HEAD), attributes(5), standards(5)
