langinfo(3HEAD)
Name
langinfo.h, langinfo - language information constants
Synopsis
#include <langinfo.h>
Description
The <langinfo.h> header contains the constants used to identify items of langinfo data (see nl_langinfo(3C)).
The type of the constant, nl_item, is defined as described in <nl_types.h>.
The following constants are defined. The entries under Category indicate in which setlocale(3C) category each item is defined.
CODESET | LC_CTYPE | codeset name |
D_T_FMT | LC_TIME | string for formatting date and time |
D_FMT | LC_TIME | date format string |
T_FMT | LC_TIME | time format string |
T_FMT_AMPM | LC_TIME | a.m. or p.m. time format string |
AM_STR | LC_TIME | ante-meridiem affix |
PM_STR | LC_TIME | post-meridiem affix |
DAY_1 | LC_TIME | name of the first day of the week (for example, Sunday) |
DAY_2 | LC_TIME | name of the second day of the week (for example, Monday) |
DAY_3 | LC_TIME | name of the third day of the week (for example, Tuesday) |
DAY_4 | LC_TIME | name of the fourth day of the week (for example, Wednesday) |
DAY_5 | LC_TIME | name of the fifth day of the week (for example, Thursday) |
DAY_6 | LC_TIME | name of the sixth day of the week (for example, Friday) |
DAY_7 | LC_TIME | name of the seventh day of the week (for example, Saturday) |
ABDAY_1 | LC_TIME | abbreviated name of the first day of the week |
ABDAY_2 | LC_TIME | abbreviated name of the second day of the week |
ABDAY_3 | LC_TIME | abbreviated name of the third day of the week |
ABDAY_4 | LC_TIME | abbreviated name of the fourth day of the week |
ABDAY_5 | LC_TIME | abbreviated name of the fifth day of the week |
ABDAY_6 | LC_TIME | abbreviated name of the seventh day of the week |
ABDAY_7 | LC_TIME | abbreviated name of the seventh day of the week |
MON_1 | LC_TIME | name of the first month of the year |
MON_2 | LC_TIME | name of the second month |
MON_3 | LC_TIME | name of the third month |
MON_4 | LC_TIME | name of the fourth month |
MON_5 | LC_TIME | name of the fifth month |
MON_6 | LC_TIME | name of the sixth month |
MON_7 | LC_TIME | name of the seventh month |
MON_8 | LC_TIME | name of the eighth month |
MON_9 | LC_TIME | name of the ninth month |
MON_10 | LC_TIME | name of the tenth month |
MON_11 | LC_TIME | name of the eleventh month |
MON_12 | LC_TIME | name of the twelfth month |
ABMON_1 | LC_TIME | abbreviated name of the first month |
ABMON_2 | LC_TIME | abbreviated name of the second month |
ABMON_3 | LC_TIME | abbreviated name of the third month |
ABMON_4 | LC_TIME | abbreviated name of the fourth month |
ABMON_5 | LC_TIME | abbreviated name of the fifth month |
ABMON_6 | LC_TIME | abbreviated name of the sixth month |
ABMON_7 | LC_TIME | abbreviated name of the seventh month |
ABMON_8 | LC_TIME | abbreviated name of the eighth month |
ABMON_9 | LC_TIME | abbreviated name of the ninth month |
ABMON_10 | LC_TIME | abbreviated name of the tenth month |
ABMON_11 | LC_TIME | abbreviated name of the eleventh month |
ABMON_12 | LC_TIME | abbreviated name of the twelfth month |
ERA | LC_TIME | era description segments |
ERA_D_FMT | LC_TIME | era date format string |
ERA_D_T_FMT | LC_TIME | era date and time format string |
ERA_T_FMT | LC_TIME | era time format string |
ALT_DIGITS | LC_TIME | alternative symbols for digits |
RADIXCHAR | LC_NUMERIC | radix character |
THOUSEP | LC_NUMERIC | separator for thousands |
YESEXPR | LC_MESSAGES | affirmative response expression |
NOEXPR | LC_MESSAGES | negative response expression |
YESSTR | LC_MESSAGES | affirmative response for yes/no queries |
NOSTR | LC_MESSAGES | negative response ro yes/no queries |
CRNCYSTR | LC_MONETARY | local currency symbol, preceded by '-' if the symbol sould appear before the
value, '+' if the symbol should appear after the value, or '.' if the symbol should replace the radix character |
If the locale's values for p_cs_precedes and n_cs_precedes do not match, the value of nl_langinfo(CRNCYSTR) is unspecified.
The <langinfo.h> header declares the following as a function:
char *nl_langinfo(nl_item);
Inclusion of <langinfo.h> header may also make visible all symbols from <nl_types.h>.
Usage
Wherever possible, users are advised to use functions compatible with those in the ISO C standard to access items of langinfo data. In particular, the strftime(3C)
function should be used to access date and time information defined in category LC_TIME. The localeconv(3C) function
should be used to access information corresponding to RADIXCHAR, THOUSEP, and CRNCYSTR.
Attributes
Interface Stability | Committed |
Standard
See also
mkmsgs(1), localeconv(3C), nl_langinfo(3C), nl_types.h(3HEAD), setlocale(3C), strftime(3C), attributes(5), standards(5)
