man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
tcp.h(3HEAD)
Name
tcp.h, tcp - definitions for the Internet Transmission Control Protocol (TCP)
Synopsis
#include <netinet/tcp.h>
Description
The <netinet/tcp.h> header defines the following macro for use as a socket option at the IPPROTO_TCP level:
TCP_NODELAY
Avoid coalescing of small segments.
The macro is defined in the header. The implementation need not allow the value of the option to be set with setsockopt() or retrieved with getsockopt().
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
getsockopt(3XNET), socket.h(3HEAD), attributes(5), standards(5) , tcp(7P)
