man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
shm(3HEAD)
Name
shm.h, shm - shared memory facility
Synopsis
#include <sys/shm.h>
Description
The <sys/shm.h> header defines the following symbolic constants:
SHM_RDONLY
attach read-only (else read-write)
SHM_RND
round attach address to SHMLBA
The <sys/shm.h> header defines the following symbolic value:
SHMLBA
segment low boundary address multiple
The following data types are defined through typedef:
shmatt_t
Unsigned integer used for the number of current attaches that must be able to store values at least as large as a type unsigned short.
The shmid_ds structure contains the following members:
struct ipc_perm shm_perm       /* operation permission structure */
size_t          shm_segsz      /* size of segment in bytes */
pid_t           shm_lpid       /* process ID of last shared memory
                                  operation */
pid_t           shm_cpid       /* process ID of creator */
shmatt_t        shm_nattch     /* number of current attaches */
time_t          shm_atime      /* time of last shmat() */
time_t          shm_dtime      /* time of last shmdt() */
time_t          shm_ctime      /* time of last change by shmctl() */
The pid_t, time_t, key_t, and size_t types are defined as described in <sys/types.h>. See types.h(3HEAD).
In addition, all of the symbols from <sys/ipc.h> are defined when this header is included.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
shmctl(2), shmget(2), shmop(2), ipc.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
