man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
stat.h(3HEAD)
Name
stat.h, stat - data returned by stat system call
Synopsis
#include <sys/types.h>
#include <sys/stat.h>
Description
The system calls stat(), lstat() and fstat() return data in a stat structure, which is defined in <stat.h>.
The constants used in the st_mode field are also defined in this file:
#define
S_IFMT
/* type of file */
#define
S_IAMB
/* access mode bits */
#define
S_IFIFO
/* fifo */
#define
S_IFCHR
/* character special */
#define
S_IFDIR
/* directory */
#define
S_IFNAM
/* XENIX special named file */
#define
S_INSEM
/* XENIX semaphore subtype of IFNAM */
#define
S_INSHD
/* XENIX shared data subtype of IFNAM */
#define
S_IFBLK
/* block special */
#define
S_IFREG
/* regular */
#define
S_IFLNK
/* symbolic link */
#define
S_IFSOCK
/* socket */
#define
S_IFDOOR
/* door */
#define
S_ISUID
/* set user id on execution */
#define
S_ISGID
/* set group id on execution */
#define
S_ISVTX
/* save swapped text even after use */
#define
S_IREAD
/* read permission, owner */
#define
S_IWRITE
/* write permission, owner */
#define
S_IEXEC
/* execute/search permission, owner */
#define
S_ENFMT
/* record locking enforcement flag */
#define
S_IRWXU
/* read, write, execute: owner */
#define
S_IRUSR
/* read permission: owner */
#define
S_IWUSR
/* write permission: owner */
#define
S_IXUSR
/* execute permission: owner */
#define
S_IRWXG
/* read, write, execute: group */
#define
S_IRGRP
/* read permission: group */
#define
S_IWGRP
/* write permission: group */
#define
S_IXGRP
/* execute permission: group */
#define
S_IRWXO
/* read, write, execute: other */
#define
S_IROTH
/* read permission: other */
#define
S_IWOTH
/* write permission: other */
#define
S_IXOTH
/* execute permission: other */
The following macros are for POSIX conformance (see standards(5)):
#define
S_ISBLK(mode)
block special file
#define
S_ISCHR(mode)
character special file
#define
S_ISDIR(mode)
directory file
#define
S_ISFIFO(mode)
pipe or fifo file
#define
S_ISREG(mode)
regular file
#define
S_ISSOCK(mode)
socket file
The following symbolic constants are defined as distinct integer values outside of the range [0, 999 999 999], for use with the futimens() and utimensat() functions:
#define    UTIME_NOW        use the current time
@define    UTIME_OMIT       no time change
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
futimens(2), stat(2), types.h(3HEAD), attributes(5), standards(5)
