man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
poll.h(3HEAD)
Name
poll.h, poll - definitions for the poll() function
Synopsis
#include <poll.h>
Description
The <poll.h> header defines the pollfd structure, which includes the following members:
int fd
the following descriptor being polled
short events
the input event flags (see below)
short revents
the output event flags (see below)
The <poll.h> header defines the following type through typedef:
nfds_t
an unsigned integer type used for the number of file descriptors
The implementation supports one or more programming environments in which the width of nfds_t is no greater than the width of type long. The names of these programming environments can be obtained using the confstr() function or the getconf utility. See confstr(3C) and getconf( 1).
The following symbolic constants are defined, zero or more of which can be OR'ed together to form the events or revents members in the pollfd structure:
POLLIN
Data other than high-priority data can be read without blocking.
POLLRDNORM
Normal data can be read without blocking.
POLLRDBAND
Priority data can be read without blocking.
POLLPRI
High priority data can be read without blocking.
POLLOUT
Normal data can be written without blocking.
POLLWRNORM
Equivalent to POLLOUT.
POLLWRBAND
Priority data can be written.
POLLERR
An error has occurred (revents only).
POLLHUP
Device has been disconnected (revents only).
POLLNVAL
Invalid fd member (revents only).
The significance and semantics of normal, priority, and high-priority data are file and device-specific.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
getconf(1), poll(2), confstr(3C), attributes(5), standards(5)
