HBA Features and Specifications
The StorageTek Dual 8 Gb FC Dual GbE HBA (SG-XPCIEFCGBE-E8-Z,
SG-PCIEFCGBE-E8-Z, SG-XPCIEFCGBE-E8-N, SG-PCIEFCGBE-E8-N, and 7105393) consists
of a single-wide, ExpressModule bus expansion board. The board interfaces an
eight-lane PCI-Express bus, with four lanes supporting two Fibre
Channel (FC) optical media ports and four lanes supporting two UTP
(copper) Gigabit Ethernet (GbE) ports. The two independent FC ports
operate at 8 Gbit/second and feature 8/4/2 Gbit/second autonegotiation.
The HBA is also backward compatible with FC ports that operate
at 4 and 2 Gbit/second. The Gigabit Ethernet ports can be configured
to operate in 10-, 100-, or 1000-Mbit/second Ethernet networks.
See Figure 1, Table 1, HBA Features and Specifications for a list of the HBA
features.
Table 1 HBA Features and Specifications
PCI connector |
x8 |
PCI signaling environment |
PCI-Express x8 (8 active lanes) |
PCI lane usage |
FC x4 lanes
GbE x4 lanes |
PCI transfer rate (maximum) |
PCI-Express Generation Two (5 Gbit/second)
x8 |
Number of FC ports |
Two |
Number of devices supported |
126 devices per FC loop; 510 devices
in Fabric mode |
FC bus type (external) |
Fiber-optic media, short-wave laser,
multimode fiber (400‐M5- SN-S) |
FC data rates |
2.125, 4.25, 8.5 Gbit/second (auto-detected) |
FC topologies |
Switched fabric (N_Port), arbitrated
loop (NL_Port) and point-to-point (N_Port) |
Number of GbE ports |
Two |
GbE interface type (external) |
IEEE 802.3 compliant, copper, UTP RJ-45 |
GbE transfer rate |
10/100/1000-Mbit/second per port, autosensing,
full-duplex |
RAM |
1.5 MB, parity protected, per port |
BIOS ROM (FC) |
One 4-MB flash ROM, field-programmable |
BIOS ROM (GbE) |
One 1-MB flash ROM |
NVRAM (FC) |
One 2-KB EEPROM |
NVRAM (GbE) |
One 128-KB EEPROM |
External connectors |
Two Small Form-factor Pluggable (SFP)
optics with LC-style connectors and two RJ-45 GbE connectors |
Maximum FC cable length |
2 Gbit/second:
500 meters using 50/125 mm core OM3 fiber
300 meters using 50/125 mm core OM2 fiber
150 meters using 50/125 mm core OM1 fiber
150 meters using 62.5/125 mm core fiber
4 Gbit/second:
380 meters using 50/125 mm core OM3 fiber
150 meters using 50/125 mm core OM2 fiber
70 meters using 50/125 mm core OM1 fiber
70 meters using 62.5/125 mm core fiber
8 Gbit/second:
150 meters using 50/125 mm core OM3 fiber
21 meters using 62.5/125 mm core OM1 fiber |
LED indicators and button |
Two LEDs per channel (yellow and green)
on the front panel as status indicators
(Power LED, Attention LED) and a button on the front panel
to support hot-swap functionality |
Power dissipation |
18.2 watts maximum |
Form Factor |
PCI-Express ExpressModule, single-wide
(198 mm x 112 mm x 21 mm) |
